New SdFat library (with and without DMA)
Please do not post requests
nicolas_soundforce
Re: New SdFat library (with and without DMA)
Post by nicolas_soundforce » Sun Aug 06, 2017 5:35 pm
I want to read 2 files at the same time. Can I just file.open() 2 files in parallel ? I am having problems at the moment and it doesn't work as expected.
Post by stevestrong » Sun Aug 06, 2017 6:31 pm
Would you be able to help if you read what you have written? I dont owm any magic ball...
Post by victor_pv » Mon Aug 07, 2017 2:04 am
you need to declare 2 "file" objects, for example file1 and file2, then you can work on each separately:
file1.open()
file2.open()
file2.read...
Check the sdfat library examples, I believe there are some that open more than 1 file.
nicolas_soundforce
Post by nicolas_soundforce » Tue Aug 08, 2017 9:02 pm
Thanks Victor, that worked without any problems.
Post by stevestrong » Mon Sep 18, 2017 8:12 pm
Just fyi, I added support for F4 (SPI and SDIO) to SdFat library from Greiman: https://github.com/stevstrong/SdFat
PR is ongoing: https://github.com/greiman/SdFat/pull/69
