[SOLVED] distance sensor VL6180
Please do not post requests
acronis
Post by acronis » Tue Jun 27, 2017 7:05 am
Hello. Tell me which library is better to use and how to physically connect STM32F103 distance sensor VL6180 https://ru.aliexpress.com/item/1PCS-VL6 ... 0.0.t4kPJc
zoomx
Re: distance sensor VL6180
Post by zoomx » Tue Jun 27, 2017 7:17 am
mmmm I bought a VL53L0X and used the first library I found, maybe these sensors use the same protocol.
acronis
Post by acronis » Tue Jun 27, 2017 8:20 am
How to connect the PIN SCL and SDA VL6180 Breakout to the STM32F103?
They are tolerant only to 2.8 V
https://cdn.sparkfun.com/datasheets/Sen ... ut_v10.pdf
https://learn.sparkfun.com/tutorials/vl ... okup-guide
zoomx
Post by zoomx » Tue Jun 27, 2017 10:51 am
If you have only the sensor you have to build a circuit similar to the sparkfun one.
For example this one
Wiring Diagram for VL6180 Breakout and 3.3v Pro-Mini
that you can find in the second link of your first post.
Since the promini is the 3.3V version, values are the same for the STM32 board
acronis
Post by acronis » Tue Jun 27, 2017 2:08 pm
NOTE: To use this diagram make sure the two pull-up resistors on the Pro-Mini are NOT populated.
such a connection possible if not soldered the resistors on the PRO MINI.
And how it on STM32 ?
Post by stevestrong » Tue Jun 27, 2017 2:24 pm
Which STM32 board do you use?
In general, on STM32 boards there are no resistors mounted on non-reserved IO pins.
acronis
Post by acronis » Tue Jun 27, 2017 2:36 pm
https://ru.aliexpress.com/item/2-STM32F ... 0.0.D46SwF
I'm doing a direct connection of pins SCL and SDA ? but what about the maximum voltage 2,8 V ?
Post by stevestrong » Tue Jun 27, 2017 3:13 pm
Yes.
You have to provide yourself, as @zoomx mentioned above (using LM317)
Post by RogerClark » Tue Jun 27, 2017 9:41 pm
How much current does it take?
Perhaps you can drop 3.3v to 2.7 with 2 diodes in series
acronis
Post by acronis » Thu Jul 13, 2017 5:28 am
https://github.com/adafruit/Adafruit_VL6180X
This library works fine on STM32.
