W5500 library is (finally) ported
Please do not post requests
yaqubap
Re: W5500 library is (finally) ported
Post by yaqubap » Thu Feb 18, 2016 8:44 am
Anyone use WIZ550io?
WIZ550io has PIC for store IP and MAC address. I use Serasidis STM32duino library. I got NULL when I am trying to get the MAC Address.
I have set the MAC address, but it was not stored to PIC (I always get NULL after WIZ550io rebooted). Anyone can help me?
Vassilis
Post by Vassilis » Thu Feb 18, 2016 12:09 pm
Edit the Ethernet_STM/src/utility/w5100.h file and comment out (enable) the line 22 by removing the double slash
//#define WIZ550io_WITH_MACADDRESS // Use assigned MAC address of WIZ550io
Then, re-compile your sketch.
yaqubap
Post by yaqubap » Fri Feb 19, 2016 7:42 am
I have commented out that line, but I still can't get the MAC address.
I finally know why I can't get it. Just comment line 45 in file w5500.cpp :
write(0x00, 0x05, 128); // Software reset the W5500 chip
Then my problem solved.
Thanks.
acronis
Post by acronis » Tue Jul 11, 2017 8:44 am
Hello.
Will this library work with BLACK Board STM32F407VET6 ?
Post by stevestrong » Tue Jul 11, 2017 8:50 am
Just try it (pay attention to the correct SPI port selection, the F4 board has 3 SPI ports), and post here if something does not work.
acronis
Post by acronis » Tue Jul 11, 2017 9:01 am
I use my library #include <Ethernet_STM.h>
a lot of errors.If I use my library a lot of errors
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\Dhcp.cpp: In member function 'uint8_t DhcpClass::parseDHCPResponse(long unsigned int, uint32_t&)':
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\Dhcp.cpp:332:55: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
                     if( *((uint32_t*)_dhcpDhcpServerIp) == 0 ||
In file included from C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\Dns.cpp:7:0:
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\Dns.cpp: In member function 'uint16_t DNSClient::ProcessResponse(uint16_t, IPAddress&)':
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\Dns.cpp:285:58: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
     uint16_t header_flags = htons(*((uint16_t*)&header[2]));
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility/util.h:4:22: note: in definition of macro 'htons'
 #define htons(x) ( ((x)<< 8 & 0xFF00) | \
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility/util.h:5:22: note: in definition of macro 'htons'
                    ((x)>> 8 & 0x00FF) )
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\Dns.cpp:287:50: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
     if ( ( iRequestId != (*((uint16_t*)&header[0])) ) ||
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\Dns.cpp:304:57: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
     uint16_t answerCount = htons(*((uint16_t*)&header[6]));
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\Dns.cpp:313:58: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
     for (uint16_t i =0; i < htons(*((uint16_t*)&header[4])); i++)
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\socket.cpp: In function 'uint16_t igmpsend(SOCKET, const uint8_t*, uint16_t)':
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\socket.cpp:322:11: warning: variable 'status' set but not used [-Wunused-but-set-variable]
   uint8_t status=0;
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp: In member function 'void W5500Class::init()':
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:37:19: error: no matching function for call to 'SPIClass::begin(int)'
   SPI.begin(SPI_CS);
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:37:19: note: candidate is:
In file included from C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src/utility/w5100.h:13:0,
                 from C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:13:
C:\Users\Admin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F4\libraries\SPI\src/SPI.h:170:10: note: void SPIClass::begin()
     void begin(void);
C:\Users\Admin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F4\libraries\SPI\src/SPI.h:170:10: note:   candidate expects 0 arguments, 1 provided
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:42:32: error: no matching function for call to 'SPIClass::setClockDivider(int, int)'
   SPI.setClockDivider(SPI_CS, 2); // 42 Mhz, ok
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:42:32: note: candidate is:
C:\Users\Admin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F4\libraries\SPI\src/SPI.h:198:7: note: void SPIClass::setClockDivider(uint32_t)
  void setClockDivider(uint32_t clockDivider);
C:\Users\Admin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F4\libraries\SPI\src/SPI.h:198:7: note:   candidate expects 1 argument, 2 provided
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:43:36: error: no matching function for call to 'SPIClass::setDataMode(int, spi_mode)'
   SPI.setDataMode(SPI_CS, SPI_MODE0);
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:43:36: note: candidate is:
C:\Users\Admin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F4\libraries\SPI\src/SPI.h:200:7: note: void SPIClass::setDataMode(uint8_t)
  void setDataMode(uint8_t dataMode);
C:\Users\Admin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F4\libraries\SPI\src/SPI.h:200:7: note:   candidate expects 1 argument, 2 provided
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp: In static member function 'static uint8_t W5500Class::write(uint16_t, uint8_t, uint8_t)':
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:132:36: error: 'SPI_CONTINUE' was not declared in this scope
   SPI.transfer(SPI_CS, _addr >> 8, SPI_CONTINUE);
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:135:29: error: no matching function for call to 'SPIClass::transfer(int, uint8_t&)'
   SPI.transfer(SPI_CS, _data);
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:135:29: note: candidate is:
C:\Users\Admin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F4\libraries\SPI\src/SPI.h:261:11: note: uint8 SPIClass::transfer(uint8) const
     uint8 transfer(uint8 data) const;
C:\Users\Admin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F4\libraries\SPI\src/SPI.h:261:11: note:   candidate expects 1 argument, 2 provided
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp: In static member function 'static uint16_t W5500Class::write(uint16_t, uint8_t, const uint8_t*, uint16_t)':
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:162:36: error: 'SPI_CONTINUE' was not declared in this scope
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:168:30: error: no matching function for call to 'SPIClass::transfer(int, const uint8_t&)'
  SPI.transfer(SPI_CS, _buf[i]);
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:168:30: note: candidate is:
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp: In static member function 'static uint8_t W5500Class::read(uint16_t, uint8_t)':
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:191:38: error: 'SPI_CONTINUE' was not declared in this scope
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:194:43: error: no matching function for call to 'SPIClass::transfer(int, int)'
     uint8_t _data = SPI.transfer(SPI_CS, 0);
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:194:43: note: candidate is:
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp: In static member function 'static uint16_t W5500Class::read(uint16_t, uint8_t, uint8_t*, uint16_t)':
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:221:38: error: 'SPI_CONTINUE' was not declared in this scope
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:227:42: error: no matching function for call to 'SPIClass::transfer(int, int)'
     _buf[_len-1] = SPI.transfer(SPI_CS, 0);
C:\Users\Admin\Documents\Arduino\libraries\Ethernet_STM-master\src\utility\w5500.cpp:227:42: note: candidate is:
zoomx
Post by zoomx » Tue Jul 11, 2017 9:21 am
acronis,
please provide
Which board are you using?
Which core are you using?
I loaded the Telnet example and it compiles withouth errors. Try using an example.
acronis
Post by acronis » Tue Jul 11, 2017 9:28 am
[libmaple] Black F407VET6 ( https://github.com/stevstrong/Arduino_STM32)
Post by stevestrong » Tue Jul 11, 2017 9:42 am
The problem is that this lib still has some defines for non-STM32 devices.
This lib is working for F1 family due to:
#if defined(__STM32F1__)
all over the code.
The solution for F4 is to replace these lines by:
#if defined(__STM32F1__) || defined (__STM32F4__)
For example, this line: https://github.com/rogerclarkmelbourne/ ... 0.cpp#L124
should be replaced by:
#elif defined(__STM32F1__) || defined (__STM32F4__)
otherwise the compiler takes code which is not designed for STM32.
The cleanest solution would be to remove all non-STM32 references from this lib, as its name already states that it should be adapted for STM32 only.
Post by stevestrong » Wed Jul 12, 2017 8:32 am
I will rework this library because it has many things which are not configurable but which should be, for instance the SPI class object (currently is fix coded).
And I will remove all non-STM32 references to avoid further issues.
