SoftwareSerial
Please do not post requests
Re: SoftwareSerial
Post by zmemw16 » Wed Mar 01, 2017 3:56 pm
check the properties file ? restricted platform ?
Re: SoftwareSerial
Post by stevestrong » Wed Mar 01, 2017 4:24 pm
I also have the problem not receiving signls from space... :mrgreen:
Nutsy
Re: SoftwareSerial
Post by Nutsy » Wed Mar 01, 2017 4:45 pm
wheres the properties file? cant find it for the library
Re: SoftwareSerial
Post by zmemw16 » Wed Mar 01, 2017 5:00 pm
library.properties - in the libraries folder; in my case /home/stephen/sketchbook/libraries/Adafruit_GFX/library.properties
contents are
name=Adafruit GFX Library
version=1.1.5
author=Adafruit
maintainer=Adafruit <info@adafruit.com>
sentence=Adafruit GFX graphics core library, this is the 'core' class that all our other graphics libraries derive from.
paragraph=Install this library in addition to the display library for your hardware.
category=Display
url=https://github.com/adafruit/Adafruit-GFX-Library
architectures=*
in your case if the architectures line AVR or something else - it maybe being ignored.
if you haven't got one, it's not.
it was just a thought, however i usually get a warning.
what level of details (compile and upload) have you set in preferences?
Nutsy
Re: SoftwareSerial
Post by Nutsy » Thu Mar 02, 2017 11:32 am
im not suing the gfx library... just trying to get softwareserial to be recognised as installed... its really strange
Re: SoftwareSerial
Post by zmemw16 » Thu Mar 02, 2017 4:43 pm
i wasn't saying that, i just put that in to show the architecture line in the library.properties file
srp
asmallri
Re: SoftwareSerial
Post by asmallri » Thu Dec 21, 2017 4:50 am
This multi instance example works fine:...
It does not work correctly. The example showed a corner case where it did work. However if you try to test it the other way around where the other port are trying to receive data it does not work.
Re: SoftwareSerial
Post by Rick Kimball » Thu Dec 21, 2017 5:04 am
Can you post the code that doesn't work please?
asmallri
Re: SoftwareSerial
Post by asmallri » Thu Dec 21, 2017 9:31 pm
I have tried the AT and CC drivers, all have issues. Some software Uarts can receive but not transmit, other can transmit but not receive.Here is one simple example that demonstrates the problem. One implementation I tested worked for 19 characters and then stopped working. The code I have posted below code may work for a short period of time (a few minutes) but normally just does not work.
The platform I am using is a BluePill STM32F103 running at 72MHz.
In this example I have used a single hardware Uart (Serial 1) and one software UART. I have added LED on and off statements and a 100ms delay so that you can see when a character has been received by the respective UART.
The symptoms of this example is when the processor is reset, the initial start messages are correctly sent out of both Serial ports. When characters are typed on the terminal connected to the HW UART receive input, the character is echoed both to the terminal attached to the HW Uart and the Software Uart and the LED flashes appropriately indicating a character was received by the HW Uart.
When characters are typed on the terminal connected to the SW UART receive input, the character are NOT echoed to either terminal HOWEVER the LED flashes appropriately indicating a character was received by the SW Uart. My conclusion for this specific example is the timing for the SW read is broken.
#include "TimerSerial.h"
#define ConsoleSerial Serial1
#define StatusLed PC13
#define StatusLedOn digitalWrite(StatusLed, LOW)
#define StatusLedOff digitalWrite(StatusLed, HIGH)
  pinMode(StatusLed, OUTPUT);
  ConsoleSerial.begin(57600);
  // set the data rate for the SoftwareSerial port
  Timer2Serial.begin(9600);    // (PA1,PA0)
void loop() // run over and over
  ConsoleSerial.println("");
  ConsoleSerial.println("ConsoleSerial is active");
  Timer2Serial.println("Timer2Serial is active");
  while (1) {
    if (ConsoleSerial.available()) {
     digitalWrite(StatusLed, LOW);
      int c = ConsoleSerial.read();
      ConsoleSerial.write(c);
      Timer2Serial.write(c);
      delay(100);
      digitalWrite(StatusLed, HIGH);
    if (Timer2Serial.available()){
      int c = Timer2Serial.read();
      delay(100);
Re: SoftwareSerial
Post by Rick Kimball » Tue Feb 06, 2018 5:22 am
I made some slight changes to your code. I don't echo the Timer4Serial . To test I used the local echo option on the putty terminal for Timer4Serial. This allows you to send lots of data without it being overrun.
I also looped until I exhaust the available input instead of grabbing one character at a time from each. I'm assuming your real world usage of this will be a command send and then a response type of situation. Adjust for your case if it isn't
#define SlaveSerial Timer4Serial
  ConsoleSerial.begin(115200);
  SlaveSerial.begin(115200);    // (PB7,PB6)
  while(!ConsoleSerial.isConnected());
  SlaveSerial.println("SlaveSerial is active");
  while (1) {
     //digitalWrite(StatusLed, LOW);
      int c;
      while((c = ConsoleSerial.read()) != -1 ) {
        SlaveSerial.write(c&0xff);
        ConsoleSerial.write(c&0xff);
      //digitalWrite(StatusLed, HIGH);
    if (SlaveSerial.available()){
      int c;
      while( (c=SlaveSerial.read()) != -1 ) {
        //SlaveSerial.write(c);
BTW: I'm testing this on a bluepill using an stlink as the upload device.
