Pulse counter (external signal) with a STM32F769I-DISCO board
donwynne
Post by donwynne »
Hello everyone! I have to connect an inductive sensor to my STM32F769I-DISCO in order to count rising edges of an external signal. So, especially if you have already done that, I would need some advice about the inputs of my microcontroller I may use to carry out the connection with the inductive sensor.
By the way, to count rising edges, I am wondering which functions I could use. Otherwise, do you know a specific method for doing that?
I truly thank you in advance for your help (I'm still a newcomer in that field to be honest).
Sincerely,
Re: Pulse counter (external signal) with a STM32F769I-DISCO board
Just use interrupt.
eg:
volatile uint32_t impulseCount=0;
void ISR(){
  impulseCount++;
  pinMode(<pin>,INPUT);
  attachInterrupt(<pin>,ISR,RISING);
Depending on your circuit and sensor, you might need to use pull down or pull up resistor on input pin.
nektariosb
Post by nektariosb »
@GonzoG which pins can I use for external interrupt?
Thank you!
I think that STM32s can use any pin as an external interrupt.
