Problems with converting Arduino Nano code over to Maple Mini. Help needed.
Buleste
Re: Problems with converting Arduino Nano code over to Maple Mini. Help needed.
Post by Buleste » Tue Jan 31, 2017 5:33 pm
victor_pv wrote:What's the TimerOne library for? I haven't used it before.
A note of advice, when working on my port of the TMRPCM library I found HardwareTimer provides only the most basic features of the timers, but there are some core functions that can do more, and then all registers and bits are defined in the core, so for anything advanced other than generate PWM output and trigger an interrupt, you should go and have a good read on the stm32f1 reference manual and learn how the timer peripherals work, then you can go setting registers as you need.
BTW, there is a thread called something like "My maple mini just let go of the magic smoke" that shows some issues with the hardware, and some could be corrected. I started it when I thought I had burnt the MCU, and found out it was just the voltage regulator and a diode and was able to replace them.
Timer one is similar to HardwareTimer for the Maple Mini.
Best example of what it does can be found here http://playground.arduino.cc/Code/Timer1 Although we use Paul Stoffregen's modified TimerOne library which is faster and works on more boards.
We use it to help generate the sound pulses required to convert TZX/TAP/CAS files into noise that the computers can detect.
Post by victor_pv » Tue Jan 31, 2017 7:58 pm
Buleste wrote: Timer one is similar to HardwareTimer for the Maple Mini.
So those files don't have PCM samples like the wav do?
Post by victor_pv » Wed Feb 01, 2017 3:57 am
This is an earlier version of the sketch, it doesn't use set module, instead it uses SPI1 for the sdcard, and SPI2 is a new object of the spi class declared in the tft cpp file
SPIClass tftSPI(2);
This was an earlier test, I believe this one just played some file or files, but did not react to any button.
Anyway, here it is in case it helps.
coos_display_blink_wav.zip
(15.84 KiB) Downloaded 13 times
BennehBoy
Post by BennehBoy » Wed Feb 01, 2017 7:45 am
victor_pv wrote:
Buleste wrote: We use it to help generate the sound pulses required to convert TZX/TAP/CAS files into noise that the computers can detect.
Those files are just the data that would normally be loaded by the tape system, most emulators use similar, C64 also for example.
See here -> http://faqwiki.zxnet.co.uk/wiki/TAP_format
https://github.com/BennehBoy
Buleste
Post by Buleste » Wed Feb 01, 2017 11:31 am
In their simplest forms no.
The most extensive information for one of those file formats can be found here. http://www.worldofspectrum.org/TZXformat.html
That's actually for the Spectrum TAP file format which is surprisingly different to the C64 TAP file format. There are also several CAS file formats for different machines too. It's a fun old world. Lol
BennehBoy
Post by BennehBoy » Wed Feb 01, 2017 11:49 am
Buleste wrote:That's actually for the Spectrum TAP file format which is surprisingly different to the C64 TAP file format. There are also several CAS file formats for different machines too. It's a fun old world. Lol
Yup I was pointing out the speccy tape format, probably just my wording that could be read as it being for c64.
Buleste
Post by Buleste » Thu Feb 02, 2017 6:21 pm
I've managed to get bot TZXMaple and CASMaple compiling. I had to // out some of the EEPROM lines for the moment whilst I figure them out but I can't test anything just yet to see if it works as it should. Hurry up AliExpress.
Post by victor_pv » Fri Feb 03, 2017 4:16 am
Buleste wrote:I've managed to get bot TZXMaple and CASMaple compiling. I had to // out some of the EEPROM lines for the moment whilst I figure them out but I can't test anything just yet to see if it works as it should. Hurry up AliExpress.
The stm32f1 doesn't have an integrated EEPROM. There is a library as part of the core that can emulate an eeprom from a page of flash memory. Thats fine if it will hold values that very rarely change, otherwise the flash page may wear out, since it can be rewritten like 1000 times vs hundreds of thousands for an eeprom.
Buleste
Post by Buleste » Fri Feb 03, 2017 11:21 am
Yeah I found the EEPROM library and I'm just getting to grips with it. I may need to consider an external EEPROM though.
BennehBoy
Post by BennehBoy » Fri Feb 03, 2017 11:25 am
Can't you write to the SD? (not withstanding the level shifting issues on your existing reader, but I mean as an alternative to having to incorporate a physical eeprom)
