'class TwoWire' has no member named 'End'
keypunch
Re: 'class TwoWire' has no member named 'End'
Post by keypunch » Sun Jun 18, 2017 5:40 am
Roger,
GIT still indicates "Latest commit aef93f7 5 days ago" for Arduino_STM32-master.zip. This is the version I tested with about 30 minutes ago that has a new unrelated to wire.end() error. Is there a newer version of Arduino_STM32-master.zip that I am not able to access yet?
Regards,
John L. Males
Toronto, Ontario
Canada
18 June 2017 01:40 EDT
Post by RogerClark » Sun Jun 18, 2017 7:24 am
Ummm
Thats strange
Someone else independently said that it was fixed for them
See
https://github.com/rogerclarkmelbourne/ ... #L187-L197
https://github.com/rogerclarkmelbourne/ ... Wire.h#140
Check your files have the end() method in them
keypunch
Post by keypunch » Sun Jun 18, 2017 7:55 am
Roger,
Perhaps I was not clear. The wire.end() compiles with the code I tested with initially. This is the same code after you made the fix to the library I tested with.
The new issue is completely unrelated to the wire library.
This means there is nothing strange nor different than someone else that has verified your fix independently. I can confirm that the wire.end(s) is at least compiled resolved. The new unrelated error means I cannot compile to a binary as yet.
No hurry for me to compile to an STM32F103 binary. I still have items to arrive that I would need to load the binary to the STM32F103 I am testing with. I have a few different TTL USB to Serial converters that should take about 4-6 weeks to arrive via a non AliExpress source. Once the code compiles I will need to make changes to pin assignments that suit a STM32F103 uC. Then wait for the TTL USB to Serial converters.
I am trying to decide what STM32F103 I will order as the "development" board to test code with to limit flash wear on the more important STM32F103s I have. I am leaning to a Black Pill rather than a Blue Pill. I know the Black Pill VBAT is tied to VCC which is not a major issue for my purposes at this time (no pun intended).
I will open the new issue later Sunday. I believe once you see the new issue you will understand it has nothing to do with the wire library. I need to try to get some sleep. Something that I have lost a fair bit of this past week unexpectly.
Regards,
John L. Males
Toronto, Ontario
Canada
18 June 2017 03:55 EDT
18 June 2017 17:24 EDT Minor typo corrections jlm
