Hi all,
i have interfaced a MPU6050 with an Olimexino STM32 board using the Softwire library. I was performing tests, and I tried to short SCL and SDA to produce an error and check whether it is correctly handled in my code. To my surprise, doing so blocks the execution somewhere in the library, so the called function does not return FALSE, and the error handling cannot take place.
Is anyone aware of this problem? I develop using the Arduino IDE, so no debug is possible.
Softwire library blocks in case of hardware failure
Re: Softwire library blocks in case of hardware failure
There is no softWire library in the STM32 core. I guess you use Roger's core (leaflab)?
Exactly. I found a place where a dead loop can occur. I added a simple timeout mechanism and it helped. The added lines are identified by the comment: JMD 30 March 2020
If there is a better way, I would appreciate.
void SoftWire::set_scl(bool state) {
int Timeout = 10000 ; // JMD 30 March 2020
I2C_DELAY(this->i2c_delay);
gpio_write_bit(sclDevice,sclBit, state);
// digitalWrite(this->scl_pin,state);
//Allow for clock stretching - dangerous currently
if (state == HIGH) {
while(digitalRead(this->scl_pin) == 0) // JMD 30 March 2020
if ( Timeout-- == 0 ) // JMD 30 March 2020
return ; // JMD 30 March 2020
