Multiple I2C libraries
Re: Multiple I2C libraries
Post by zmemw16 » Wed Dec 20, 2017 4:05 pm
definitely daft ideas mode
just how slow can we clock i2c ? set timeouts in seconds?
replace resistors with led and resistor, really, really slow the clock.
record video and then playback frame by frame ;)
not nearly enough really's in that line
maybe trying a bit-bang i2c would help in slowing it down
kevin someone has a lovely video on youtube of controlling a stepper motor with switches.
tfried
Post by tfried » Wed Dec 20, 2017 9:39 pm
Grasping for straws, but...
What happens, if you move "vl.begin();" (and the associated debug lines) above "display.begin()"?
Post by stevestrong » Sat Dec 23, 2017 5:29 pm
Just thinking...
You start first library (let's say) First.begin(), which will call Wire.begin().
The you call other "First" functions:
First.display();
First.blabla();
Then, you start "Second" library (let's say): Second.begin(), which also calls same default (!) object Wire.begin();
Will this maybe clear (or conflict) the previous library variables/instances and reset the default Wire object?
