[SOLVED] OLED_I2C
RenatoJr17
[SOLVED] OLED_I2C
Post by RenatoJr17 » Mon Jan 22, 2018 9:50 pm
I can not compile a library ever this error, what can I do? I'm a newbie.
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\OLED_I2C.cpp:36:57: note: #pragma message: Compiling for STM32F1 Architecture...
  #pragma message("Compiling for STM32F1 Architecture...")
In file included from C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\OLED_I2C.cpp:37:0:
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h: In member function 'void OLED::_initTWI()':
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h:22:7: error: 'HWIRE' was not declared in this scope
       HWIRE.begin();
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h:38:9: error: 'HWIRE' was not declared in this scope
         HWIRE.begin();
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h: In member function 'void OLED::update()':
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h:85:10: error: 'HWIRE' was not declared in this scope
          HWIRE.beginTransmission(SSD1306_ADDR);
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h:2:20: error: 'HWIRE' was not declared in this scope
 #define WIRE_WRITE HWIRE.write
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h:113:13: note: in expansion of macro 'WIRE_WRITE'
             WIRE_WRITE(aa);
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h:124:9: error: 'HWIRE' was not declared in this scope
         HWIRE.endTransmission();
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h: In member function 'void OLED::_sendTWIcommand(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\hardware/arm/HW_STM32.h:140:9: error: 'HWIRE' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\OLED_I2C.cpp: In member function 'void OLED::begin()':
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\OLED_I2C.cpp:73:46: note: #pragma message: I2C HW mode enabled
         #pragma message("I2C HW mode enabled")
C:\Program Files (x86)\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\OLED_I2C\OLED_I2C.cpp:80:45: note: #pragma message: SCL pinmode OUTPUT
         #pragma message("SCL pinmode OUTPUT")
exit status 1
Erro compilando para a placa Generic STM32F103C series
Re: OLED_I2C
Post by Pito » Mon Jan 22, 2018 10:05 pm
Show your sketch..
Re: OLED_I2C
Post by mrburnette » Mon Jan 22, 2018 10:26 pm
exit status 1
[/code]
What we need to know always is:
  • What version of ArduinoIDE you are using
  • What OS are you running
  • And the full source code or link if from an online source.
However in this case, I suspect a mismatch between some old OLED code
https://github.com/rogerclarkmelbourne/ ... s/OLED_I2C
that did not get updated with a core update.
The core has undergone many changes in SPI and I2C. In a "perfect world" members who craft changes should always sanity test their changes by compiling every example file in the "master" get Hub repository. In this case, I do not think that happened :ugeek:
(Although I do see an update just 20 days ago, so I may be mistaken.)
Give us a little time to check things out. I am on my tablet and away from my workshop.
RenatoJr17
Re: OLED_I2C
Post by RenatoJr17 » Mon Jan 22, 2018 10:55 pm
I'm using the library's ready sketch.
What version of ArduinoIDE you are using -- 1.8.5
What OS are you running -- win 10
And the full source code or link if from an online source. -- full source code
I will update the library with the link you gave me and test
thanks.
Re: OLED_I2C
Post by RogerClark » Tue Jan 23, 2018 12:34 am
Looks like this library did not get changed when the I2C (Wire) library was changed to use Hardware instead of software I2C
I think the problem is here
https://github.com/rogerclarkmelbourne/ ... HW_STM32.h
Try changing references to HWIRE.xxxx to Wire.xxxxx
RenatoJr17
Re: {SOLVED] OLED_I2C
Post by RenatoJr17 » Fri Jan 26, 2018 3:58 am
thank you all, it was just the outdated library.
