Two Arduino IDE'S, two STLINK'S simultan
kurtow187
Post by kurtow187 »
I,m using two (portable) Arduino IDE's with two STLINK V2 in exchange.
One IDE with Bluepill, one with a STMF411.
I use this with at one USB Hub with switchable USB channels.
Each IDE has its own cache folder.
This runs nearly perfect. But...
If I ever forget to activate/deactivate the correct USB port, then the wrong processor is flashed (with the wrong software).
(this happens quite often since I'm not the youngest anymore)
So my questions are:
- Does anyone know the way to adress the STLINK via the Arduino IDE via the serial number?
- It is possible create your own command line for the Arduino CLI?
- Is it possible to find the command line generated by the IDE on the computer?
I am grateful for any help!
Kurtow
kurtow187
Re: Two Arduino IDE'S, two STLINK'S simultan
Post by kurtow187 »
I have found a own workaround for my problem.
It is still very rudimentary, but it is enough for me.
I use the CLI from the STM32Cubeprogrammer
The below lines do the most work:
For the first Arduino IDE:
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin>STM32_Programmer_CLI.exe -c port=SWD SN=50FF72065088515619531887 freq=4000 -w c:\build_1\BLPI_PV_Cont.ino.bin 0x08000000
For the second Arduino IDE:
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin>STM32_Programmer_CLI.exe -c port=SWD SN=066FFF494849887767182234 freq=4000 -w c:\build\TFT_HC12_Pow_Receive.ino.bin 0x08000000
In the each Arduino IDE I use only 'CTRL R Compile' command.
Then I start a batch file with one of the above command lines
It needs the Serial number of each STLINK and path/filename of the arduino output file.
In this way, the correct STLINK is always addressed.
If anyone wants to dig deeper in STM32CubeProgrammer CLI, this blog post is very informative:
https://blog.katastros.com/a?ID=01800-2 ... 2db0f0f5c6
regards
Kurtow187
Return to “IDE's”
