Radio library Bluepill
iscle
Post by iscle » Wed Jul 12, 2017 1:51 pm
i've been trying to get a TEA5767 working with the STM32 arduino port with the Radio library which can be found on GitHub, but i get lots of warnings and errors when trying to compile the Test sketch for the STM32 board. If I try to compile it for an arduino uno or an arduino nano it works just fine!
What should I do?
This is the error
In file included from C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\examples\TestTEA5767\TestTEA5767.ino:36:0:
C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src/radio.h:124:1: warning: 'typedef' was ignored in this declaration [enabled by default]
C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src/radio.h:133:1: warning: 'typedef' was ignored in this declaration [enabled by default]
In file included from C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src\RDA5807M.cpp:21:0:
C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src\RDA5807M.cpp: In member function 'virtual void RDA5807M::checkRDS()':
C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src\RDA5807M.cpp:381:38: error: no matching function for call to 'TwoWire::requestFrom(int, int, int)'
       Wire.requestFrom(I2C_INDX, 8, 1);                  // Retransmit device address with READ, followed by 8 bytes
C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src\RDA5807M.cpp:381:38: note: candidates are:
In file included from C:\Users\Iscle\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Wire/Wire.h:43:0,
                 from C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src\RDA5807M.cpp:19:
C:\Users\Iscle\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Wire/WireBase.h:101:11: note: uint8 WireBase::requestFrom(uint8, int)
     uint8 requestFrom(uint8, int);
C:\Users\Iscle\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Wire/WireBase.h:101:11: note:   candidate expects 2 arguments, 3 provided
C:\Users\Iscle\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Wire/WireBase.h:106:11: note: uint8 WireBase::requestFrom(int, int)
     uint8 requestFrom(int, int);
C:\Users\Iscle\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Wire/WireBase.h:106:11: note:   candidate expects 2 arguments, 3 provided
C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src\RDA5807M.cpp: In member function 'virtual void RDA5807M::debugStatus()':
C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src\RDA5807M.cpp:483:33: error: no matching function for call to 'TwoWire::requestFrom(int, int, int)'
   Wire.requestFrom(I2C_INDX,32,1);                  // Retransmit device address with READ, followed by 8 bytes
C:\Users\Iscle\Documents\Arduino\libraries\Radio-master\src\RDA5807M.cpp:483:33: note: candidates are:
exit status 1
Thanks a lot.
EDIT: The board is the Bluepill one.
Re: Radio library Bluepill
Post by Rick Kimball » Wed Jul 12, 2017 2:23 pm
Post by stevestrong » Wed Jul 12, 2017 3:49 pm
Which STM32 board?
Post by zmemw16 » Wed Jul 12, 2017 4:10 pm
radio+library+TEA5767 --> 6 repo's cf 343 :)
+arduino and its 5
iscle
Post by iscle » Wed Jul 12, 2017 10:14 pm
yup, i forgot to put the link to the library hahaha
It's this one: https://github.com/mathertel/Radio
The board is the BluePill one.
I've chosen this one because it seemed to work with arduino, but it can be any library as long as it works with the TEA5767, something I couldn't find.
Thanks!
bdbell
Post by bdbell » Thu Jul 13, 2017 1:15 am
I have been using the attached library with STM32 and TEA Radio module.
TEA5767Radio.zip
(2.51 KiB) Downloaded 22 times
iscle
Post by iscle » Tue Jul 18, 2017 9:28 pm
Thanks! I will try it and see if it works for me. :)
iscle
Post by iscle » Sat Jul 22, 2017 10:17 pm
Okay, I've tried 3 libraries of which only 2 of them work, but the problem is that I can't seem to get past 103.5MHz frequency!!! If i go past that I can still hear that station, with a bit of noise... Anyone had this problem before?
Can it be a problem of having 10k pull up resistor on the i2c instead of 4k7?
Edit: I've tried with 5K resistors and it's still the same problem...
Post by RogerClark » Sat Jul 22, 2017 10:25 pm
Seems very unlikely this is a problem with Comms to the module.
Sounds like you reached the RF frequency limit if either the TX or the Rx
iscle
Post by iscle » Sat Jul 22, 2017 10:28 pm
Hi Roger,
Thanks for answering...
I've tried with 5k pull ups and it's still the same problem.
Could it be due to a faulty chip? I've searched this problem and nobody seems to be having it! Strange... All stations from 103.5 and below work just fine...
Edit:
The library uses this to convert the frequency entered in (xxx.x) ex.(104.2) style and send it via i2c.
void TEA5767Radio::setFrequency(float frequency)
  	unsigned int frequencyB = 4 * (frequency * 1000000 + 225000) / 32768;
	byte frequencyH = frequencyB >> 8;
	byte frequencyL = frequencyB & 0XFF;
	HWire.beginTransmission(_address);
	HWire.write(frequencyH);
	HWire.write(frequencyL);
	HWire.write(0xB0);
	HWire.write(0x10);
	HWire.write(0x00);
	HWire.endTransmission();
	delay(100);
