[SOLVED] FTP client. how to work ?
Can someone help me port this library?
acronis
Post by acronis » Wed Aug 09, 2017 3:53 am
http://playground.arduino.cc/Code/FTP
    FTP passive client for IDE v1.0.1 and w5100/w5200
    Posted October 2012 by SurferTim
    Modified 6 June 2015 by SurferTim
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
// comment out next line to write to SD from FTP server
#define FTPWRITE
// this must be unique
 byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x59, 0x67 };
// change to your network settings
 IPAddress ip( 192, 168, 2, 2 );
 IPAddress gateway( 192, 168, 2, 1 );
 IPAddress subnet( 255, 255, 255, 0 );
// change to your server
 IPAddress server( 1, 2, 3, 4 );
 EthernetClient client;
 EthernetClient dclient;
char outBuf[128];
char outCount;
// change fileName to your file (8.3 format!)
char fileName[13] = "test.txt";
   digitalWrite(10,HIGH);
   if(SD.begin(4) == 0)
     Serial.println(F("SD init fail"));
   Ethernet.begin(mac, ip, gateway, gateway, subnet);
   delay(2000);
   Serial.println(F("Ready. Press f or r"));
   byte inChar;
   inChar = Serial.read();
   if(inChar == 'f')
     if(doFTP()) Serial.println(F("FTP OK"));
     else Serial.println(F("FTP FAIL"));
   if(inChar == 'r')
     readSD();
 File fh;
 byte doFTP()
#ifdef FTPWRITE
   fh = SD.open(fileName,FILE_READ);
#else
   SD.remove(fileName);
   fh = SD.open(fileName,FILE_WRITE);
   if(!fh)
     Serial.println(F("SD open fail"));
     return 0;
#ifndef FTPWRITE
   if(!fh.seek(0))
     Serial.println(F("Rewind fail"));
     fh.close();
     return 0;
   Serial.println(F("SD opened"));
   if (client.connect(server,21)) {
     Serial.println(F("Command connected"));
   else {
     fh.close();
     Serial.println(F("Command connection failed"));
     return 0;
   if(!eRcv()) return 0;
   client.println(F("USER myuser"));
   client.println(F("PASS mypassword"));
   client.println(F("SYST"));
   client.println(F("Type I"));
   client.println(F("PASV"));
   char *tStr = strtok(outBuf,"(,");
   int array_pasv[6];
   for ( int i = 0; i < 6; i++) {
     tStr = strtok(NULL,"(,");
     array_pasv[i] = atoi(tStr);
     if(tStr == NULL)
       Serial.println(F("Bad PASV Answer"));
   unsigned int hiPort,loPort;
   hiPort = array_pasv[4] << 8;
   loPort = array_pasv[5] & 255;
   Serial.print(F("Data port: "));
   hiPort = hiPort | loPort;
   Serial.println(hiPort);
   if (dclient.connect(server,hiPort)) {
     Serial.println(F("Data connected"));
   else {
     Serial.println(F("Data connection failed"));
     client.stop();
     fh.close();
     return 0;
#ifdef FTPWRITE
   client.print(F("STOR "));
   client.println(fileName);
#else
   client.print(F("RETR "));
   if(!eRcv())
     dclient.stop();
     return 0;
#ifdef FTPWRITE
   Serial.println(F("Writing"));
   byte clientBuf[64];
   int clientCount = 0;
   while(fh.available())
     clientBuf[clientCount] = fh.read();
     clientCount++;
     if(clientCount > 63)
       dclient.write(clientBuf,64);
       clientCount = 0;
   if(clientCount > 0) dclient.write(clientBuf,clientCount);
#else
   while(dclient.connected())
     while(dclient.available())
       char c = dclient.read();
       fh.write(c);
       Serial.write(c);
   dclient.stop();
   Serial.println(F("Data disconnected"));
   client.println(F("QUIT"));
   client.stop();
   Serial.println(F("Command disconnected"));
   fh.close();
   Serial.println(F("SD closed"));
   return 1;
 byte eRcv()
   byte respCode;
   byte thisByte;
   while(!client.available()) delay(1);
   respCode = client.peek();
   outCount = 0;
   while(client.available())
     thisByte = client.read();
     Serial.write(thisByte);
     if(outCount < 127)
       outBuf[outCount] = thisByte;
       outCount++;
       outBuf[outCount] = 0;
   if(respCode >= '4')
     efail();
     return 0;
   return 1;
void efail()
   byte thisByte = 0;
   client.stop();
   fh.close();
void readSD()
   if(!fh)
     return;
     Serial.write(fh.read());
   fh.close();
Hello.
There is a wonderful FTP client that works perfectly.
But it works in any one direction
#define FTPWRITE
How to make this code in one program and send the file to FTP and read a file from an FTP server ?
  // send the file to FTP server
#define FTPWRITE
   fileName = "cardID.txt";
    if (doFTP())
      tft.println(F("FTP OK"));
    else
      tft.println(F("FTP FAIL"));
how to count it, trace it back ?
if you do
#undef FTPWRITE
that doesn't work
I need to work in two sides and c the sd card to the ftp server , and FTP server to sd card
RogerClark
Re: FTP client. how to work ?
Post by RogerClark » Tue Aug 15, 2017 12:22 am
You are confusing FTP Client with FTP Server
You need to post to the Arduino.cc forum about obtaining a FTP server library
