Updated STM F1 core to support BluePill including USB Serial
Re: Updated STM F1 core to support BluePill including USB Serial
Post by RogerClark » Mon Nov 14, 2016 5:20 am
Rick Kimball wrote:something must be including the legacy header.
So how is support for pins going to work. The stm32 value line has leds on PC8 and PC9. What pin number do I use for those?
Pin numbering is a mess.
I already posted and issue.
Post by Rick Kimball » Mon Nov 14, 2016 5:20 am
BTW I have it blinking on one of the arduino defined pins (ARDUINO_PIN_D8) and it seems to work nicely. I had to load the binary from the command line as the nucleo flasher thing didn't work for me.
Post by RogerClark » Mon Nov 14, 2016 5:21 am
OK
Did you see the gitter invite, you can login using your github ID
https://gitter.im/stm32duino/Lobby
Post by RogerClark » Mon Nov 14, 2016 5:22 am
PS. I'll commit your fix, and also get rid of the - (dash) in the variant name
Actually, I'll change all the variant names
Post by Rick Kimball » Mon Nov 14, 2016 5:23 am
RogerClark wrote:OK
I did, but i'm reluctant to login to any site with ids from another site if I don't have to. Sorry.
Post by RogerClark » Mon Nov 14, 2016 5:30 am
OK. No worries.
Just changing all those dashes (arrggghhh)
Post by RogerClark » Mon Nov 14, 2016 5:33 am
Whats the default upload for the ValueLine ? STLink??
Post by Rick Kimball » Mon Nov 14, 2016 5:35 am
RogerClark wrote:Whats the default upload for the ValueLine ? STLink??
I would hope so.
Post by RogerClark » Mon Nov 14, 2016 5:36 am
OK.
I'll change it in boards.txt
Actually, it looks like I left some legacy defines from the libmaple boards.txt as part of the upload params, but I'll tidy them later after I sort out this immediate mess
Post by RogerClark » Mon Nov 14, 2016 5:40 am
BTW.
VLDiscovery lib currently does not build.
@danieleff must have built it originally, but it won't build now. I suspect its the inclusion of the USB code thats causing the problem, so more #ifdef's are needed
