build errors with recent gcc-arm-none-eabi
Post by ag123 » Wed Apr 05, 2017 6:27 pm
hi sorry to bother as i'm rather 'newbie' in this, need a little guidance :lol:
after much procrastinating i finally got around to installing arduino ide 1.8.2 https://www.arduino.cc/en/Main/Software
and installing aduino_stm32 (https://github.com/rogerclarkmelbourne/Arduino_STM32)
following pretty much these instructions: https://github.com/rogerclarkmelbourne/ ... stallation
i noted that gcc-arm is not part of the arduino ide, hence i got gcc-arm-none-eabi from https://developer.arm.com/open-source/g ... /downloads (i'd think it may be good to mention it in the Arduino_STM32 installation wiki as well as arm none gcc isn't distributed as part of it too)
i'm using version 6-2017-q1-update Released: February 23, 2017 (the current release as of this post)
when i build a sketch, these errors occurred
In file included from /opt4/opt/arduino-1.8.2/hardware/Arduino_STM32/STM32F1/cores/maple/WString.cpp:23:0:
/opt4/opt/arduino-1.8.2/hardware/Arduino_STM32/STM32F1/cores/maple/itoa.h:34:14: error: conflicting declaration of C function 'char* utoa(long unsigned int, char*, int)'
 extern char* utoa( unsigned long value, char *string, int radix ) ;
In file included from /opt4/opt/gcc-arm-none-eabi-6-2017-q1-update/arm-none-eabi/include/stdlib.h:11:0,
                 from /opt4/opt/gcc-arm-none-eabi-6-2017-q1-update/arm-none-eabi/include/c++/6.3.1/cstdlib:75,
                 from /opt4/opt/gcc-arm-none-eabi-6-2017-q1-update/arm-none-eabi/include/c++/6.3.1/stdlib.h:36,
                 from /opt4/opt/arduino-1.8.2/hardware/Arduino_STM32/STM32F1/cores/maple/WString.h:26,
                 from /opt4/opt/arduino-1.8.2/hardware/Arduino_STM32/STM32F1/cores/maple/WString.cpp:22:
/opt4/opt/gcc-arm-none-eabi-6-2017-q1-update/arm-none-eabi/include/stdlib.h:223:8: note: previous declaration 'char* utoa(unsigned int, char*, int)'
 char * _EXFUN(utoa,(unsigned, char *, int));
while i'm inclined to attempt patching up Arduino_STM32 codes to attempt to resolve the errors, is arm's gcc-arm-none-eabi from arm website the correct arm gcc to go with Arduino_STM32?
thanks much in advance
Re: build errors with recent gcc-arm-none-eabi
Post by stevestrong » Wed Apr 05, 2017 6:41 pm
You missed this step:
https://github.com/rogerclarkmelbourne/ ... ds-Manager
I think it is now the SAM boards (Cortex-M3) which should be installed.
Post by ag123 » Wed Apr 05, 2017 6:47 pm
thanks ! all works :D
Post by fpiSTM » Wed May 10, 2017 3:29 pm
To solve this issue if you update the arm toolchain:
https://github.com/stm32duino/Arduino_C ... 06f86b9281
Post by RogerClark » Thu May 11, 2017 10:13 am
fpiSTM wrote:To solve this issue if you update the arm toolchain:
I've added this to the LibMaple issues list, and I will deploy the same fix when I have time
aster
Post by aster » Thu May 18, 2017 12:13 am
stevestrong wrote:You missed this step:
are you sure? i installed the SAMD boards (cortex M0) and it works ok
Post by ag123 » Thu May 18, 2017 7:50 am
installing the SAMD boards would install arm-none-gcc 4.8.3-2014q1 as part of it. it normally goes into your $home/.arduino15 folders. if you would like to use the recent gcc compiler that's directly from arm on https://developer.arm.com/open-source/g ... /downloads, you would need to make those minor updates for the itoa.c and itoa.h in the libmaple core source codes. the issue only arise as the more recent arm-none-gcc e.g. v6 (6.3.1) compiler tool chain delivers a functional utoa() as part of its libraries and includes, prior around 4.9.9 (see fpiSTM's link) it isn't there ;)
aster
Post by aster » Thu May 18, 2017 11:28 am
I will wait to fill more the flash of the f1 chip for now i have enough space free for my projects :D
