STM32G030F6P6TR compilation error.
Posted: Mon Feb 05, 2024 7:10 am
by damlevikram
I am new to STM microcontroller and am trying to program STM32G030F6P6TR using Arduino IDE.
I am using the latest version of IDE as well as latest version of STM32 libraries.
Here is the code I am trying to flash
#define SCR_Pin PA7
#define RELAY_PIN PC15
#define LED_PIN PA6
#define ZCD_PIN PA0
#define DIM_MAX 10
#define DIM_MIN 90
#define AC_CTRL_OFF digitalWrite(SCR_Pin, LOW)
#define AC_CTRL_ON digitalWrite(SCR_Pin, HIGH)
#define RELAY_OFF digitalWrite(RELAY_PIN, LOW)
#define RELAY_ON digitalWrite(RELAY_PIN, HIGH)
#define LED_OFF digitalWrite(LED_PIN, HIGH)
#define LED_ON digitalWrite(LED_PIN, LOW)
unsigned char dim = 0;
HardwareSerial mySerial(PB7, PB6);
int led_flag = 0;
    pinMode(LED_PIN, OUTPUT);
    pinMode(RELAY_PIN, OUTPUT);
    pinMode(SCR_Pin, OUTPUT);
    pinMode(ZCD_PIN, INPUT);
    LED_OFF;
    RELAY_OFF;
    AC_CTRL_OFF;
    mySerial.begin(115200);
    mySerial.println("Start");
    attachInterrupt(ZCD_PIN, zero_cross_int, RISING); // CHANGE FALLING RISING
    if (led_flag % 2 == 0)
        LED_ON;
    else
        LED_OFF;
    led_flag++;
    char c;
    String str = "";
    while (mySerial.available() > 0)
        c = mySerial.read();
        if (c == '\n')
            mySerial.println("Get line:");
            mySerial.println(str);
            at_explain(str);
        else
            str = str + c;
// AT D50
void at_explain(String command)
    if (command.startsWith("AT"))
        int var_1 = 0;
        sscanf(command.c_str(), "AT D%d", &var_1);
        mySerial.println(var_1);
        set_power(var_1);
void set_power(int level)
    dim = map(level, 0, 100, DIM_MIN, DIM_MAX);
    if (level == 0)
        RELAY_OFF;
    else
        RELAY_ON;
void zero_cross_int() // function to be fired at the zero crossing to dim the light
    if (dim <= DIM_MAX)
        return;
    // if (dim >= DIM_MIN)
    //     return;
    AC_CTRL_OFF;
    int dimtime = (100 * dim);
    delayMicroseconds(dimtime); // Off cycle
    AC_CTRL_ON;                 // triac firing
    // delayMicroseconds(500);     // triac On propagation delay
    // triac Off
When I try to compile this code by selecting Generic STM32G0 series from boards manager I get following error.
exit status 1
Compilation error: 'PC15' was not declared in this scope; did you mean 'PC_5'?
The same code when I compile using STM32G4 series I can finish with successful compilation.
When I change the Pin names in code from
PA7 to PA_7
PC15 to PC_15 and on...
the code gets compiled with STM32G0 series. I am attaching screenshots of what is happening.
Your help in this regard is highly appreciated
Re: STM32G030F6P6TR compilation error.
Posted: Mon Feb 05, 2024 10:24 am
I've built your code for STM32G030F6P and have no error.
I guess you didn't select the correct board part number in the menu and you build for AGAFIA_SG0 which does not have PC15
Posted: Mon Feb 05, 2024 10:52 am
by damlevikram
Thank you very much for pointing out my mistake.
What you told was correct. After selection of correct board there is no error now.
Posted: Wed Mar 20, 2024 4:49 am
by jimcarrey
just select the correct board part number in the menu
