Page 1 of 4
WeAct Studio STM32F411CEU6 BlackPill v3.1 crystal is 8 MHz
Posted: Fri Apr 19, 2024 11:39 pm
by Fziegler_076
Hello friends!
I bought a new version of the Black Pill v3.1 board (WeAct Studio) with HSE 8 MHz.
The standard version of the board is available with HSE 25 MHz, and this board (easier to enter dfu mode by usb)
was made with HSE 8 MHz and it does not work.
Please tell me in detail what and where to fix so that the board works in Arduino.
I am a novice specialist and I really need to launch this board.
I will be very grateful for your help.
Re: WeAct Studio STM32F411CEU6 BlackPill v3.1 crystal is 8 MHz
Posted: Sat Apr 20, 2024 7:02 am
Simply redefine HSE_VALUE using hal_conf_extra.h.
See the wiki.
Posted: Sat Apr 20, 2024 7:42 am
by Fziegler_076
fpiSTM wrote: Sat Apr 20, 2024 7:02 am Simply redefine HSE_VALUE using hal_conf_extra.h.
Hi fpiSTM !
There is no such file. I need to create it myself in the catalog C:\Users\Admin\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.7.1\variants\STM32F4xx\F411C(C-E)(U-Y)?
Or does it need to be created in another directory? I looked at the Wiki, but did not understand what needs to be entered there.
Only one line #define HSE_VALUE 800000000U or something else needs to be added to this file?
Could you help me write the contents of this file?
Posted: Sat Apr 20, 2024 7:56 am
https://github.com/stm32duino/Arduino_C ... adaptation
https://github.com/stm32duino/Arduino_C ... efinitions
So simply create the file with at sketch level :
Posted: Sat Apr 20, 2024 9:10 am
by Fziegler_076
I created the hal_conf_extra.h file with a single line #define HSE_VALUE 800000000U and put it in the folder with the sketch, next to the blink.ino files.
The program is loaded into the microcontroller, but the LED does not blink.
I use the standard Blink program from the examples
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
Why doesn't it work?
What could be the problem?
I checked on 3 boards.
Posted: Sat Apr 20, 2024 10:48 am
Is the LED_BUILTIN correct for this new board?
Posted: Sat Apr 20, 2024 11:21 am
Pay attention it seems you set 80MHz and not 8MHz
Posted: Sat Apr 20, 2024 12:13 pm
by Fziegler_076
1. I fixed it to #define HSE_VALUE 8000000U
2. I wrote the LED pin myself (PC13)
  pinMode(PC13, OUTPUT);
  digitalWrite(PC13, HIGH);  // turn the LED on (HIGH is the voltage level)
  digitalWrite(PC13, LOW);   // turn the LED off by making the voltage LOW
https://aliexpress.com/item/1005001456186625.html 8 MHz XTAL version
It doesn't work anyway (
What else can I check?
I have attached my project
Posted: Sat Apr 20, 2024 2:11 pm
You should redefine the system core clock config to properly configure the pll vs the HSE value.
Posted: Sat Apr 20, 2024 7:02 pm
Note that even with a wrong crystal frequency, you should be able to blink your led
	pinMode(LED_BUILTIN,OUTPUT);
	digitalWrite(LED_BUILTIN, ! digitalRead(LED_BUILTIN));
and your LED should blink, if it doesn't blink then your issue is likely not related to the crystal frequency.
e.g. wrong/different LED pin ? did you manage to flash / install the firmware/sketch properly?
the 'defacto' standard is to use stm32cube programmer ('official' from ST)
though for the 'experts' there are open sourced 3rd party tools available.
there are also standard procedures if you want to use USB DFU to install the sketch (firmware), you need to set boot0 and press reset. did you do that?
for WeAct f401/f411, the 'standard' button dance
- connect usb
- press both boot0 and reset
- hold boot0 release reset
- release boot0 2 secs later
- then program from stm32cube programmer
- if you need the bin file, it is from the arduino menu -> export compiled binary, the bin file should be found in your project/sketch folder.
Note that all the various schematics SchDoc 20 - 31
https://github.com/WeActStudio/WeActStu ... master/HDK
all show a 25 Mhz crystal, are you sure the crystal on your board is 8 Mhz?
if you are sure 8 Mhz is correct, try out the python script here
viewtopic.php?t=78
running that script would give you various M, N, P, Q pll multipliers and the fcpu - cpu frequency e.g.
FHSE: 8 m: 1 n: 18 p: 2 (RCC_PLLP_DIV2) q: 3 fusb: 48.0 fcpu: 72.0
FHSE: 8 m: 1 n: 24 p: 2 (RCC_PLLP_DIV2) q: 4 fusb: 48.0 fcpu: 96.0
FHSE: 8 m: 1 n: 36 p: 4 (RCC_PLLP_DIV4) q: 6 fusb: 48.0 fcpu: 72.0
FHSE: 8 m: 1 n: 42 p: 4 (RCC_PLLP_DIV4) q: 7 fusb: 48.0 fcpu: 84.0
FHSE: 8 m: 1 n: 48 p: 4 (RCC_PLLP_DIV4) q: 8 fusb: 48.0 fcpu: 96.0 <-
FHSE: 8 m: 1 n: 54 p: 4 (RCC_PLLP_DIV4) q: 9 fusb: 48.0 fcpu: 108.0
e.g. for stm32f411ce the specs give a fcpu of 100 Mhz - the closest from the script is 96 Mhz
https://www.st.com/en/microcontrollers- ... 411ce.html
hence, use those m, n, p, q multipliers values
go into your variant e.g. variant_BLACKPILL_F411CE.cpp in the core files installed with your (Arduino) IDE
look for void SystemClock_Config(void)
and look for the codes where the PLL multipliers are set e.g.
https://github.com/stm32duino/Arduino_C ... CE.cpp#L95
  RCC_OscInitStruct.PLL.PLLM = 25;
  RCC_OscInitStruct.PLL.PLLN = 192;
  RCC_OscInitStruct.PLL.PLLQ = 4;
this is for 25 Mhz, you can comment those codes, then copy them and revise the m, n, p, q multipliers based on that from the python script.
in fact, for this you won't even need to use the python script, simply change PLLM to 8, and that should work for a 8 Mhz crystal.
note that you should also consult the manual as well as the specs on the clock and reset control (RCC chapters) and check that the remaining configurations that the ahb / apb clock dividers are after all correct.
usually, based on the values from the python script, usb would be working correctly i.e. at 48 mhz.
select USB CDC Serial as your serial port and if you have codes like
	Serial.begin();
	while(!Serial);
	// echo usb serial input back to host
	if (Serial.available())
		while(Serial.available())
			Serial.write(Serial.read());
	delay(1);
the virtual comm port should be working, e.g. that you can use the serial monitor e.g. in the Arduino IDE to test it.
if your HSE crystal is after all not running at 8 Mhz (with the new m, n, p, q) multipliers or in the original with 25 Mhz, then usb won't work no matter how.
and I supposed you have already reviewed and done the steps as documented in the Wiki
if you have not even tried those, then all these comments are 'way advanced' compared to those already documented in the getting started guide.
if there is still issues get a board like
https://www.st.com/en/evaluation-tools/ ... 411re.html
or the 'original' weact f411 with 25 Mhz crystal
https://www.aliexpress.com/item/1005001456186625.html
that should work by simply selecting the correct variant
