analogWrite() -> pwm()
What could be included in further releases, or for the forum.
aster
Post by aster » Thu Apr 13, 2017 9:30 pm
I know it won't be very well seen for code compatibility, history, habits, ecc
But i think that here everyone know what is a pwm pulse, so why don t use its real name? I always found it confusing to call it analogWrite!
Last but not least pwm() is shorter to write :lol:
racemaniac
Re: analogWrite() -> pwm()
Post by racemaniac » Fri Apr 14, 2017 7:22 am
we could add it as an alias for analogWrite, but the goal of this project is obviously to keep arduino compatibility, so the analogWrite will remain (even though the name is terrible >_<)
Post by Pito » Fri Apr 14, 2017 7:44 am
analogWrite() has got fixed frequency while it changes duty cycle only.
pwm() usually gets 2 parameters - duty cycle and frequency.
edogaldo
Post by edogaldo » Fri Apr 14, 2017 7:45 am
aster wrote:I know it won't be very well seen for code compatibility, history, habits, ecc
The core already provides pwmWrite() (ref. pwm.h/pwm.cpp), it's just 5 letters longer.. ;)
aster
Post by aster » Sat Apr 15, 2017 4:24 pm
edogaldo wrote: The core already provides pwmWrite() (ref. pwm.h/pwm.cpp), it's just 5 letters longer.. ;)
it is great
void analogWrite(uint8 pin, int duty_cycle8)
	pinMode(pin,PWM);
	pwmWrite(pin,duty_cycle8 * 257);// 257 maps 255 to 65535 (i.e 255*257 = 65535)
void pwmWrite(uint8 pin, uint16 duty_cycle) {
    if (pin >= BOARD_NR_GPIO_PINS) {
        return;
    timer_dev *dev = PIN_MAP[pin].timer_device;
    uint8 cc_channel = PIN_MAP[pin].timer_channel;
    ASSERT(dev && cc_channel);
    timer_set_compare(dev, cc_channel, duty_cycle);
so what @racemaniac suggested had already been did, great
Pito wrote:analogWrite() has got fixed frequency while it changes duty cycle only.
this would be very good: the possibility to choose the frequency and duty cycle but it would need some effort to make it in arduino style API
Post by Pito » Sat Apr 15, 2017 5:55 pm
Everything is available, you can set period/frequency and duty cycle as you wish (with some limitations), just read the libmaple documentation, also discussed few times here, for example:
viewtopic.php?f=3&t=1041&hilit=pito+pwm&start=10
