Software QSPI for stm32f103
What could be included in further releases, or for the forum.
diger67
Re: Software QSPI for stm32f103
Post by diger67 » Wed May 03, 2017 2:26 am
This idea was born accidentally. I connected memory to stm32f446 by QSPI, it did not work correctly. As I found out on the board, it was incorrect to mark two pins. I did not have any other stm32 with QSPI hardware, I had to write a software one. Measuring the read speed is not difficult. The material you suggested I read, it can turn out something useful.
P.s.
Look at the datasheet for this memory and you will understand what to implement on the proposed algorithm QSPI will be almost impossible.
diger67
Post by diger67 » Wed May 03, 2017 11:58 am
I checked the dump reading time to 256 bytes. When initializing SysTick in 1 μs, the read time for the program QSPI is 1 ms.
uint8_t idData[3];
uint8_t dataBuff[0x100];
static __IO uint32_t sysTickCounter;
__IO uint32_t uwTick = 0;
float	timeend;
uint32_t time;
uint32_t GetSysTick(void)
	return uwTick;
void SysTick_Handler(void)
	uwTick++;
int main(void)
	SysTick_Config(SystemCoreClock/1000000);	//1uS
	Gpio_Init();
	QSPIInit();
	QSPI_Read_ID(READ_ID_CHIP, idData, 3);
	time = GetSysTick();
	QSPI_data_read(0, 0x00, 6, dataBuff);
   timeend = (GetSysTick() - time)/1000 ;
    while(1)
Who is online
