Battling combinatorial explosion
What could be included in further releases, or for the forum.
jcw
Re: Battling combinatorial explosion
Post by jcw » Fri Oct 30, 2015 8:25 am
Enable a F0 variant branch and Arduino only sees F0 in the menus.
Do you have to restart the Arduino IDE in between?
jcw
Post by jcw » Fri Oct 30, 2015 8:54 am
To recap, I use Git to create a branch for each variant that CubeMX sets up and generates the HAL code.
If that's the audience at which Arduino-STM32 is targeted, then great. Sounds like a flexible and powerful setup.
sheepdoll
Post by sheepdoll » Fri Oct 30, 2015 5:45 pm
Yes, Even without using git The Arduino IDE needs to be restarted a lot to build the dynamic menus.
jcw
Post by jcw » Fri Oct 30, 2015 6:26 pm
Yes, too bad.
I've been thinking a bit more about your git-branch approach, I use the "GitHub for Mac" app quite a bit, which makes it very easy to pull code from that site, but also to switch branches, check in changes, and even submit pull requests. There's also a "GitHub for Windows" app. On Linux, I assume everyone will be familiar with the command line, so no issues there.
https://desktop.github.com
Maybe there's a not-too-complex-or-brittle way to describe the setup process for newcomers. The advantage being that this mechanism exists today, once you know how to switch branches. Something like: download/install the IDE, download/install GitHub, checkout a repo in the right place, restart the IDE.
I don't know how easy it is to maintain an entire set of branches. What if you want to apply a change which needs to carry through in multiple, or even all, the branches? Use two separate repositories next to each other, perhaps? One single-branch with common stuff, and one multi-branch with references to the common stuff?
jcw
Post by jcw » Fri Oct 30, 2015 7:02 pm
Another thought - combining the ideas of Git and ChibiOS: how about managing it all through symbolic links?
RogerClark
Post by RogerClark » Fri Oct 30, 2015 8:24 pm
Im not sure whether symbolic links will work on Windows??
Post by mrburnette » Sat Oct 31, 2015 12:12 am
RogerClark wrote:Im not sure whether symbolic links will work on Windows??
They work:
viewtopic.php?t=356
But complicate things for many users not familiar with with their use.
