Bring in the ChibiOS HAL?
What could be included in further releases, or for the forum.
jcw
Re: Bring in the ChibiOS HAL?
Post by jcw » Fri Oct 30, 2015 6:45 pm
Did someone say Eclipse? Fresh article on HAD:
http://hackaday.com/2015/10/30/code-cra ... velopment/
Post by RogerClark » Fri Oct 30, 2015 10:44 pm
I noticed that as well, but have not read it yet.
I know a few people on the forum have managed to configure Eclipse for use with Arduino and the STM32 but I"ve not had much luck when I tried (and I don't have a huge amount of spare time to spend on it :-(
Edit.
It looks like the article focuses on Linux. I think @rickkimball has it set up and working, but I suspect the on Windows that things are still not that straightforward
Post by zmemw16 » Sat Oct 31, 2015 12:53 am
eclipsearduino
i've just tried it again on this debian 8 system, it complains about 1.6.5r? and shows 1.6.4 for software;
i can see a selection list of boards.txt
my main arduino 1.6.5 is installed in ~/ard165 and the 'boards.txt's listed are from the hardware directory in that location.
it doesn't see the ~/sketchbook/hardware/Arduino_STM32 directory, this i believe is the recommended way for us(?)
i did configure the plugin with the correct paths for my sketchbook, libraries and hardware. i use a soft link for ~/sketchbook to 'sketchbook_STM32 and in sketchbook/hardware' is another soft link to the 'current' Arduino_STM32' directory.
i'll go off and have a play with directories under ~/ard165xx ...
edit1
the directories listed are from ~/.arduino15 and ard165xxx/hardware, not seeing sketchbook/hardware
edit2
moved stm32 to ard165xxx/hardware, now seeing stm32 boards / variant/ upload options
tried a compile and got ......
copied gcc-arm....etc into hardware/tools/gcc....
now moans about missing "libmaple/libmaple_types.h"
include path screwed up i suspect
i'm reverting.
