Waveform Generator (Two DAC examples)
Viktor_7
Re: Waveform Generator (Two DAC examples)
Post by Viktor_7 » Tue Aug 08, 2017 8:10 am
Hello!
Please help, why does the ADC on STM32F103VCT6 work properly, and on STM32F100 (STM32VLDISCOVERY) does not work ??
In the board manager, I select the required microcontroller.
Post by dannyf » Sat Aug 19, 2017 1:21 pm
Sawtooth waveform on both DAC channels
code pieces like that are helpful in testing a concept but not that useful in real life, as the loop timing is generally not consistent from run to run.
a much better approach is DDS:
1) create waveform in tables;
2) index the tables via a phase accumulator;
3) in a timer isr, increase the phase accumulator and then output the waveform;
by changing the increments to phase accumulator, or the waveform tables, you can change the output frequency, or output waveform, easily.
DDS chips are essentially that, but implemented via hardware.
RogerClark
Post by RogerClark » Sat Aug 19, 2017 9:18 pm
You could use DMA to take data from the table and send to the DAC, as this would remove the overhead of the ISR.
I think the setup would be similar to what @stsvstrong has written to use DMA to read from an 8 bit parallel GPIO device ( the OV7670 camera).
You would just need to change the direction of the DMA and the port address
Post by ag123 » Tue Sep 19, 2017 4:36 pm
this is itching me to try out the DAC on the stm32f407vet6 black boards :lol:
escarneiro
Post by escarneiro » Fri Oct 20, 2017 1:11 am
Guys,
I've been trying to make a blue pill works with a TDA1543, using the code from vassilis (viewtopic.php?f=18&t=519)
I'm wiring it in conjunction with a NE5532 , as the image below suggests:
Well, I got nothing but noise on the TDA1543 outputs. Looking the output on PA5 (clock) on oscilloscope, I got this:
Which I think is not even close to a decent clock signal.
Do you guys think my blue pill is defective ?
Another question: Is it possible to use another pin as clock, and/or to use another SPI to accomplish this task ?
PS: I cant find some PT8211 to buy. I only found it in SMD-mount format.
ChrisMicro
Post by ChrisMicro » Fri Oct 20, 2017 4:40 am
Do you really need a DAC or might be PWM or sigma delta pin toggling sufficient?
https://github.com/ChrisMicro/BluePillSound
Post by stevestrong » Fri Oct 20, 2017 9:41 am
I cannot find any specific code under the given link.
What is the scope of the presented circuit and how should it work?
What kind of signals are input to BCK, WS and DATA? Do you have any scope plots for those?
escarneiro
Post by escarneiro » Sat Oct 21, 2017 12:08 am
Well, this is the code. https://pastebin.com/tSBUc42b
And that plot I've posted is from the BCK signal. Anyway, besides of it's strange shape, I took a look at it again and saw something even stranger (running now at half frequency / setting SPI divider at 32).
The BCK clock, alone (it is not contiguous!)
BCK + WS (seems to be straigth)
BCK + DATA (seems ok too)
escarneiro
Post by escarneiro » Sat Oct 21, 2017 12:13 am
Yes, I want a DAC, but your project seems interesting too. But perhaps I couldn't understand the scheme you made. :lol:
It would be nice to have it designed in a EDA software
Pito
Post by Pito » Sat Oct 21, 2017 8:46 am
Potential issues:
1. your opamps may require +5V and -5V supplies (or higher as it is not an rail-rail opamp),
2. TDA is 5V and its input signals are 0-3.3V only,
3. the protocol is I2S, BP does not have that, afaik.
