STM32F Arduino register setup
mikedb
Post by mikedb »
Arduino with the Official ST micro core.
I would like to know where the actual registers is setup.
This is a small snippet of code in "wiring_analog.c"
#if defined(HAL_ADC_MODULE_ENABLED) && !defined(HAL_ADC_MODULE_ONLY)
  PinName p = analogInputToPinName(ulPin);
  if (p != NC) {
    value = adc_read_value(p, _internalReadResolution);
    value = mapResolution(value, _internalReadResolution, _readResolution);
#else
  UNUSED(ulPin);
  return value;
But where and how is the actual registers setup from the HAL_ setup?
Like in the sample below.
RCC->AHB1ENR |= RCC_AHB1ENR_GPIOCEN |         // Enable clock to GPIO port C
RCC_AHB1ENR_DMA1EN;                                       // Enable DMA1
RCC->APB1ENR |= RCC_APB1ENR_TIM2EN;            // Enable clock to TIM2 timer
GPIOC->MODER |= GPIO_MODER_MODER0_1;        // Set D8 (PC0) as alterntive function
GPIOC->AFR[0] |= GPIO_AFRL_AFSEL0_0;
Thanks in advance.
Answers: 92
Re: STM32F Arduino register setup
In the adc_read_value().
mikedb
Post by mikedb »
Where is adc_read_value();
This is the Library path on my pc.
C:\Users\me\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.0.0\cores\arduino
Answers: 92
First it is not a library it is a core ;)
The BSP was moved in a library to avoid issue with Arduino cache feature.
https://github.com/stm32duino/Arduino_C ... g.cpp#L748
mikedb
Post by mikedb »
Thanks ... But.
This code:
Must somehow do this:
ADC1->CR2 |= 1 << 0; // ADON =1 enable ADC1
How is the HAL_ instruction converted to set the ADON bit in the ADC1 Register?
Answers: 92
The goal of using HAL or LL API is to not be aware of this. So if you want check that, simply dig into all HAL API.
mikedb
Post by mikedb »
Thanks I will do some searching.
mikedb
Post by mikedb »
Dont know if this will show up twice but nothing happend when I clicked - submit -
#define __HAL_RCC_SYSCFG_CLK_DISABLE() (RCC->APB2ENR &= ~(RCC_APB2ENR_SYSCFGEN))
#define __HAL_RCC_ADC1_CLK_DISABLE()   (RCC->APB2ENR &= ~(RCC_APB2ENR_ADC1EN))
#define __HAL_RCC_TIM1_CLK_DISABLE()   (RCC->APB2ENR &= ~(RCC_APB2ENR_TIM1EN))
#define __HAL_RCC_SPI1_CLK_DISABLE()   (RCC->APB2ENR &= ~(RCC_APB2ENR_SPI1EN))
#define __HAL_RCC_TIM16_CLK_DISABLE()  (RCC->APB2ENR &= ~(RCC_APB2ENR_TIM16EN))
#define __HAL_RCC_TIM17_CLK_DISABLE()  (RCC->APB2ENR &= ~(RCC_APB2ENR_TIM17EN))
#define __HAL_RCC_USART1_CLK_DISABLE() (RCC->APB2ENR &= ~(RCC_APB2ENR_USART1EN))
#define __HAL_RCC_DBGMCU_CLK_DISABLE() (RCC->APB2ENR &= ~(RCC_APB2ENR_DBGMCUEN))
#define __HAL_RCC_SYSCFG_IS_CLK_ENABLED()     ((RCC->APB2ENR & (RCC_APB2ENR_SYSCFGEN)) != RESET)
#define __HAL_RCC_ADC1_IS_CLK_ENABLED()       ((RCC->APB2ENR & (RCC_APB2ENR_ADC1EN))   != RESET)
