GPIO registers and port manipulation
iwalpola
Post by iwalpola » Sun Jul 03, 2016 9:35 pm
Sources:
http://embedded-lab.com/blog/stm32-gpio-ports-insights/
http://hertaville.com/stm32f0-gpio-tutorial-part-1.html
The libmaple libraries, on which STM32duino is based, provides access to registers by the syntax:
GPIOA->regs->REG
where REG can be one of the following:
CRH and CRL
CRH is used to set type/and or speed of pins 8-15 of the port
CRL is used to set type/and or speed of pins 0-7 of the port
Accessed as a 32 bit word, with 4 bits representing the state of each pin. Out of these 4 bits, the low 2 bits are MODE, and high 2 bits are CNF.
The 4 bits for each pin can be set to:
0b0011 (binary) or 0x3 (HEX) - Corresponds to setting pin as output, same as pinMode()
0b1000 or 0x8 - Corresponds to setting pin as input, same as pinMode()
Say I want to set PORTA pins 0, 3 and 4 to OUTPUT and 1, 6, 7 to INPUT, and leave pins 2 and 5 in their original state. The code is:
PORTA->regs->CRL = (PORTA->regs->CRL & 0x00F00F00) | 0x88000080 |0x00033003;
//0x00F00F00 is bitmask to retain value of pins 2 and 5 in original state
//0x88000080 is bitmask to set inputs
//0x00033003 is bitmask to set outputs
IDR - Input Data Register
Used to read input of entire 16 pins of port at once. Accessed as a 32 bit word whose lower 16 bits represent each pin.
The pins being read must be set to INPUT mode by using CRL/CRH or pinMode() before using this.
Say I want to read pins A2. The code is:
bool result = GPIOA->regs->IDR & 0x0004; //returns true if A2 is HIGH
//0x0004 is 0b0000000000000100
ODR - Output Data Register
Used to write output to entire 16 pins of port at once. Accessed and written as a 32 bit word whose lower 16 bits represent each pin.
The pins being read must be set to OUTPUT mode by using CRL/CRH or pinMode() before using this.
Say I want to set pins A2, A12 and A13, and reset (clear) all other pins in the 16 pin bus. The code is:
GPIOA->regs->ODR = 0b0011000000000100; //note,  binary
Now if I want to set and clear A2, A12 and A13 without altering other pins, the code is:
//Set A2, A12, A13 (HIGH)
GPIOA->regs->ODR |= 0b0011000000000100;
//Clear A2, A12, A13 (LOW)
GPIOA->regs->ODR &= ~(0b0011000000000100);
but notice how, if we want to touch only some pins, we have to READ, MASK and WRITE. That's why there is BRR and BSRR
BRR - Bit Reset Register
32 bit word. Lower 16 bits have 1's where bits are to be set to "LOW". Upper 16 bits have 1's where bits are to be set "HIGH".
0's mean ignore
Now, to set and clear A2, A12, A13 while preserving the state of all other pins in the port, the code is:
GPIOA->regs->BRR = 0b0011000000000100 << 16; //move to upper 16 bits
GPIOA->regs->BRR = 0b0011000000000100;
BSRR - Bit Set Reset Register
BSRR is like the complement of BRR. It's also a 32 bit word. Lower 16 bits have 1's where bits are to be set to "HIGH". Upper 16 bits have 1's where bits are to be set "LOW".
0's mean ignore
In this case, to set and clear A2, A12, A13 while preserving the state of all other pins in the port, the code is:
GPIOA->regs->BSRR = 0b0011000000000100;
GPIOA->regs->BSRR = 0b0011000000000100 << 16; //move to upper 16 bits
Combination of BRR and BSRR
Since BRR and BSRR are opposite of each other, you can use both if you don't want to do the bit shift left operation .
GPIOA->regs->BSRR = 0b0011000000000100; //lower 16 bits
GPIOA->regs->BRR = 0b0011000000000100; //lower 16 bits
Re: GPIO registers and port manipulation
Post by RogerClark » Sun Jul 03, 2016 10:42 pm
Did you see the post about individual bit access via different addresses.
( sorry I cant find the link to the thread at the moment as I am posting from my phone)
Ollie
Post by Ollie » Sun Jul 03, 2016 11:01 pm
Here is the post for accessing
- individual bits of the peripheral registers
- bit fields in peripheral registers
http://www.stm32duino.com/viewtopic.php ... ing#p15081
In the first case the parameters are the register name and bit number. In the second case, the parameters are
- register name
- first bit number
- number of bits
Note: the bit number can go over 32 to make it easier to address bit fields that are stored in multiple 32 bit register words.
This method is the fastest way to access (read and write) peripheral register content. In addition, it is multi thread safe, when the mask based read-modify-write sequence is not.
Cheers, Ollie
Post by RogerClark » Sun Jul 03, 2016 11:25 pm
@ollie
Thanks.
I should get into the habit of trying to remember something unique in those sorts of posts, so I stand a better chance of finding them again.
In this case it would be "bit banding"
iwalpola
Post by iwalpola » Sun Jul 03, 2016 11:49 pm
Sounds interesting, at this rate I won't get any sleep at all :D
smithy
Post by smithy » Sun Sep 04, 2016 2:54 pm
Hmm maybe i misunderstood something but trying following did not give the results i expected:
GPIOA->regs->CRL = (GPIOA->regs->CRL & 0x33333333) ; //set PA0-PA7 output
//Set A0-A7 (HIGH)
GPIOA->regs->ODR |= 0b0000000011111111;
Only PA1 is high, what is wrong ?? (using bluepill, C8 board)
Serial.println(GPIOA->regs->CRL);
Serial.println(GPIOA->regs->ODR);
Results in
0
41215
The original values seem to be
0x44444444 for CLR (Input floating)
0xA000 for ODR
If i use GPIOA->regs->CRL = (GPIOA->regs->CRL | 0x33333333) ; it results to 0x77777777, still only PA1 is High
If i declare outputs like this
uint8_t DPINS[] = {PA0, PA1, PA2, PA3, PA4, PA5, PA6, PA7};
  for (uint8_t i = 0; i <= sizeof(DPINS) - 1; i++)
    pinMode(DPINS[i], OUTPUT);
It is working, guess the problem is the CLR command.
Now that i can finally set GPIO´s with direct mapping i wanted to implement it in the u8g2lib in order to speed things up when using 8080 mode.
This is the original code
	for( i = U8X8_MSG_GPIO_D0; i <= U8X8_MSG_GPIO_D7; i++ )
	  u8x8_gpio_call(u8x8, i, b&1);
	  b >>= 1;
being replaced with
	uint16_t bitmask;
	GPIOA->regs->ODR &= ~(0b0000000011111111); //reset dpins PA0-PA7
	bitmask = b;
	GPIOA->regs->ODR |= bitmask; //set nescessary dpins PA0-PA7 High
Now the compiler throws
C:\Users\Master\Documents\Arduino\libraries\U8g2\src\clib\u8x8_byte.c: In function 'u8x8_byte_8bit_8080mode':
C:\Users\Master\Documents\Arduino\libraries\U8g2\src\clib\u8x8_byte.c:212:2: error: 'GPIOA' undeclared (first use in this function)
C:\Users\Master\Documents\Arduino\libraries\U8g2\src\clib\u8x8_byte.c:212:2: note: each undeclared identifier is reported only once for each function it appears in
When searching for GPIOA with notepad++ in the Arduino_STM32-master\STM32F1 folder i get 236 hits in 27 files, i´m pretty unsure which header to include, can anyone help me a bit here ?
Arduino_STM32-master\STM32F1\system\libmaple\stm32f1\include\series\gpio.h seems to be wrong, throwing
C:\Users\Master\Documents\Arduino\libraries\U8g2\src\clib\u8x8_byte.c:213:7: error: dereferencing pointer to incomplete type
#include <wirish_types.h> throws
C:\Users\Master\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\cores\maple/wirish_types.h:66:1: error: unknown type name 'bool'
typedef bool boolean;
EDIT:Found the right file
#include "C:\Users\Master\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\system\libmaple\include\libmaple\gpio.h"
now i´m measuring half the transmission time (from 30 down to 14 ms 128*64 display) which is quite nice :)
atacanteknik
Post by atacanteknik » Mon May 08, 2017 7:05 am
i want use a led gpioc port for PC13
how i can use witd direct registers and port manipulation
stm32f103 series
edogaldo
Post by edogaldo » Mon May 08, 2017 9:57 am
RCC_BASE->APB2ENR |= 0x10; // enable GPIOC clock
GPIOC->regs->CRH = (GPIOC->regs->CRH & 0xFF0FFFFF) | 0x00100000; // PC13 output push/pull (max speed 10MHz)
GPIOC->regs->CRH = (GPIOC->regs->CRH & 0xFF0FFFFF) | 0x00200000; // PC13 output push/pull (max speed 2MHz)
GPIOC->regs->CRH = (GPIOC->regs->CRH & 0xFF0FFFFF) | 0x00300000; // PC13 output push/pull (max speed 50MHz)
GPIOC->regs->BSRR =  0x00002000; //PC13 = 1 (leave others unchanged)
GPIOC->regs->BSRR =  0x20000000; //PC13 = 0 (leave others unchanged)
GPIOC->regs->BSRR =  0x20002000; //PC13 = 1 (leave others unchanged - lower bits (set) have precedence over higher (clear))
GPIOC->regs->BRR  =  0x00002000; //PC13 = 0 (leave others unchanged)
GPIOC->regs->ODR  =  0x00002000; //PC13 = 1 (all others set to 0)
GPIOC->regs->ODR |=  0x00002000; //PC13 = 1 (leave others unchanged)
GPIOC->regs->ODR  =  0x00000000; //PC13 = 0 (all others set to 0 too)
GPIOC->regs->ODR &= ~0x00002000; //PC13 = 0 (leave others unchanged)
atacanteknik
Post by atacanteknik » Mon May 08, 2017 11:22 am
can you made same PC15
edogaldo
Post by edogaldo » Mon May 08, 2017 11:53 am
atacanteknik wrote:can you made same PC15
I'd leave this as an exercise to you.
Tips:
- ref RM0008: http://www.st.com/content/ccc/resource/ ... 171190.pdf
- look particularly at regs:
- RCC_APB2ENR (par. 7.3.7)
- GPIOx_{CRH, CRL, BSRR, BRR, ODR} (parr. 9.2.*)
If you want to play hard you have to be prepared.. ;)
Anyway consider that PC14 and PC15 are also the LSE pins so unless you really know what you are doing, better avoid using them..
