Portenta_H7_PWM Library
Posted: Wed Sep 22, 2021 11:00 pm
by khoih-prog
This library enables you to use Hardware Timers on an STM32H747XI-based Portenta_H7 board to create and output PWM to pins.
The most important feature is they're purely hardware-based PWM channels. Therefore, the frequency can be higher than hybrid or software-based PWM, and their executions are not blocked by bad-behaving functions / tasks. This important feature is absolutely necessary for mission-critical tasks.
The PWMs_Array_Complex example will demonstrate the nearly perfect accuracy, compared to software-based PWM, by printing the actual period / duty-cycle in `microsecs` of each of PWM-channels.
Releases v1.0.0
1. Initial coding to support **Portenta_H7 boards** such as Portenta_H7 Rev2 ABX00042, etc., using ArduinoCore-mbed mbed_portenta
Supported Boards
1. STM32H747XI-based Portenta_H7 using using ArduinoCore-mbed mbed_portenta
Examples:
1. PWM_Multi
2. PWM_Multi_Args
3. PWMs_Array_Complex
Debug Terminal Output Sample
The following is the sample terminal output when running example PWMs_Array_Complex on Portenta_H7 to demonstrate the accuracy of Hardware-based PWM, especially when system is very busy.
Starting PWMs_Array_Complex on PORTENTA_H7_M7
Portenta_H7_PWM v1.0.0
Index = 0, Instance = 0x40010000, channel = 3, TimerIndex = 0
Index = 1, Instance = 0x40000800, channel = 1, TimerIndex = 3
Index = 2, Instance = 0x40010400, channel = 2, TimerIndex = 7
Index = 3, Instance = 0x40001800, channel = 2, TimerIndex = 8
SimpleTimer (ms): 2000, us : 12659505, Dus : 9933701
PWM Channel : 0, programmed Period (us): 500000, actual : 499994, programmed DutyCycle : 20, actual : 20.00
PWM Channel : 1, programmed Period (us): 200000, actual : 199999, programmed DutyCycle : 30, actual : 30.00
PWM Channel : 2, programmed Period (us): 100000, actual : 100000, programmed DutyCycle : 50, actual : 50.00
PWM Channel : 3, programmed Period (us): 10000, actual : 10000, programmed DutyCycle : 70, actual : 70.00
SimpleTimer (ms): 2000, us : 22594086, Dus : 9934581
PWM Channel : 1, programmed Period (us): 200000, actual : 199998, programmed DutyCycle : 30, actual : 30.00
PWM Channel : 2, programmed Period (us): 100000, actual : 99999, programmed DutyCycle : 50, actual : 50.00
SimpleTimer (ms): 2000, us : 32528951, Dus : 9934865
PWM Channel : 3, programmed Period (us): 10000, actual : 10001, programmed DutyCycle : 70, actual : 69.99
SimpleTimer (ms): 2000, us : 42463635, Dus : 9934684
PWM Channel : 3, programmed Period (us): 10000, actual : 10000, programmed DutyCycle : 70, actual : 69.99
SimpleTimer (ms): 2000, us : 52398502, Dus : 9934867
Re: Portenta_H7_PWM Library
Posted: Sat Dec 11, 2021 6:48 am
by khoih-prog
Releases v2.0.0
1. Completely new code to fix no PWM output issue. Check No PWM-Output signals #1
2. To permit start, stop, change and restore the settings of any PWM channel on-the-fly
The following is the sample terminal output when running example PWM_Multi on Portenta_H7 to demonstrate how to start multiple PWM channels, then stop, change, restore the PWM settings on-the-fly.
Starting PWM_Multi on PORTENTA_H7_M7
Portenta_H7_PWM v2.0.0
[PWM] Freq = 1000.00, 	DutyCycle % = 50.00, 	DutyCycle = 0.50, 	Pin = 0
[PWM] Freq = 2500.00, 	DutyCycle % = 50.00, 	DutyCycle = 0.50, 	Pin = 1
[PWM] Freq = 4000.00, 	DutyCycle % = 50.00, 	DutyCycle = 0.50, 	Pin = 3
[PWM] Freq = 5000.00, 	DutyCycle % = 50.00, 	DutyCycle = 0.50, 	Pin = 5
[PWM] Freq = 50000.00, 	DutyCycle % = 50.00, 	DutyCycle = 0.50, 	Pin = 6
PW (us) 0	PW (us) 1	PW (us) 2	PW (us) 3	PW (us) 4
500.00		200.00		125.00		100.00		10.00
Stop all PWM
0.00		0.00		0.00		0.00		0.00
Change all PWM
125.00		50.00		31.25		25.00		2.50
Restore all PWM
Stop all PWM
Change all PWM
Restore all PWM
Posted: Sun Dec 12, 2021 3:24 am
by khoih-prog
Releases v2.0.1
1. Fix PWM_Multi example by not using HRTIM pinD3 and pinD6 at the same time
2. Temporary fix polarity for HRTIM PWM for core v2.6.1-. Check Portenta: PWM on HRTIM has inverted corner case values #352 To be modified when the issue is fixed.
