Maple mini LED fading blink(pin 33)
navintiwari08
Post by navintiwari08 » Sat Aug 13, 2016 2:03 pm
Hey,
Maple mini has LED at pin 33 which is a non PWM pin. Here is a little code that simulates PWM on pin 33 and produces a fading blink on that LED.
#define LED_PIN 33    //pin 33 is the led pin on maple mini.
  // initialize digital pin 33 as output.
  pinMode(LED_PIN, OUTPUT);
  int period = 600;             //the pulse time period (us)
  int pwm_pulses = 80;          //number of pwm pulses to be sent
  for (int j = 1; j < 100; j++) {   //duty cycle changing from 1% to 99%
    set_pwm(LED_PIN, period, j, pwm_pulses); //setting pwm on led pin
  digitalWrite(LED_PIN, HIGH);
  for (int j = 99; j >= 1; j--) {
  digitalWrite(LED_PIN, LOW);
void set_pwm(int pin_num, int period, int duty_cycle, int pwm_pulses) {
  int on_time = (duty_cycle * period)/100; //on time(us)
  int off_time = period - on_time;      //off time(us)
  for (int i = 1; i <= pwm_pulses; i++) {  //sending 'pwm_pulses' pulses.
    digitalWrite(pin_num, HIGH);
    delayMicroseconds(on_time);
    digitalWrite(pin_num, LOW);
    delayMicroseconds(off_time);
Enjoy!
Navin
Re: Maple mini LED fading blink(pin 33)
Post by RogerClark » Sat Aug 13, 2016 11:20 pm
Hi Navin
If you want to experiment with some more advanced code, to do the same thing, but which keeps running in the background
You could use one of the hardware timers to call a function which toggles the value of the pin.
Also, If you look on MBED there is a software PWM library for the nRF51 ( as this device only has PWM on 3 pins)
I considered porting that library to Arduino, but in the end I didnt need it.
Or there may be other software PWM libraries that would be easier to port
navintiwari08
Post by navintiwari08 » Mon Aug 15, 2016 7:16 am
Hi Roger,
Does Arduino provide functions to directly control the hardware timers? It would be great if that can be done.
I looked up on mbed.org but couldn't quite locate the library you were referring to.
Also, is there a way to change the system clock frequency of maple mini? I suppose its running on 72 MHz. I know this is the maximum for this MCU but can I slow it down?
Post by RogerClark » Mon Aug 15, 2016 7:38 am
STM32 is different from AVR Arduino, but STM32 does have multiple hardware timers which you can use to trigger interrupts and call Interrupt Service Routines (functions)
Look in the Examples menu under A_STM32 Examples -> Maple -> TimerInterrupts , there is an example of how to use the timer interrupts
You would need to modify the boards_setup.cpp file in the Mini Maple variant folder,
If you look in the GD32 variant, in boards_setup.cpp there is code like
#if F_CPU==120000000
	#define BOARD_RCC_PLLMUL RCC_PLLMUL_10
#elif F_CPU==96000000
	#define BOARD_RCC_PLLMUL RCC_PLLMUL_8
#elif F_CPU==72000000
	#define BOARD_RCC_PLLMUL RCC_PLLMUL_6
#elif F_CPU==48000000
	#define BOARD_RCC_PLLMUL RCC_PLLMUL_4
#elif F_CPU==12000000
// Use 2 x pre-divider
Actually this is my update code that I am testing as I want to run the GD32 at 12Mhz (its lowest speed) but similar code could be used for the Maple mini e.g.
#ifndef BOARD_RCC_PLLMUL
#if F_CPU==72000000
	#define BOARD_RCC_PLLMUL RCC_PLLMUL_9
Note. USB will only work at 72Mhz and 48Mhz on the Maple mini as the USB clock control only has 2 possible divider settings (and will not multiply the clock value)
GD32 has 4 USB Clock divider settings (but won't operated below 48Mhz either)
Also, there is a small bug in the master code at the moment, which I only found yesterday where the USB divider for Maple mini is set to 1.5 x for 48Mhz but should be 1.0 x
So Maple mini boards_setup.cpp should be
 * The MIT License
 * Copyright (c) 2012 LeafLabs, LLC.
 * Permission is hereby granted, free of charge, to any person
 * obtaining a copy of this software and associated documentation
 * files (the "Software"), to deal in the Software without
 * restriction, including without limitation the rights to use, copy,
 * modify, merge, publish, distribute, sublicense, and/or sell copies
 * of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be
 * included in all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS
 * BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN
 * ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
 * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
 * @file wirish/stm32f1/boards_setup.cpp
 * @author Marti Bolivar <mbolivar@leaflabs.com>
 * @brief STM32F1 chip setup.
 * This file controls how init() behaves on the STM32F1. Be very
 * careful when changing anything here. Many of these values depend
 * upon each other.
#include "boards_private.h"
#include <libmaple/gpio.h>
#include <libmaple/timer.h>
#include <boards.h>
#include <usb_serial.h>
// Allow boards to provide a PLL multiplier. This is useful for
// e.g. STM32F100 value line MCUs, which use slower multipliers.
// (We're leaving the default to RCC_PLLMUL_9 for now, since that
// works for F103 performance line MCUs, which is all that LeafLabs
// currently officially supports).
#if F_CPU==72000000
namespace wirish {
    namespace priv {
        static stm32f1_rcc_pll_data pll_data = {BOARD_RCC_PLLMUL};
        __weak rcc_pll_cfg w_board_pll_cfg = {RCC_PLLSRC_HSE, &pll_data};
        __weak adc_prescaler w_adc_pre = ADC_PRE_PCLK2_DIV_6;
        __weak adc_smp_rate w_adc_smp = ADC_SMPR_55_5;
        __weak void board_reset_pll(void) {
            // TODO
        __weak void board_setup_clock_prescalers(void) {
            rcc_set_prescaler(RCC_PRESCALER_AHB, RCC_AHB_SYSCLK_DIV_1);
            rcc_set_prescaler(RCC_PRESCALER_APB1, RCC_APB1_HCLK_DIV_2);
            rcc_set_prescaler(RCC_PRESCALER_APB2, RCC_APB2_HCLK_DIV_1);
			rcc_clk_disable(RCC_USB);
			#if F_CPU == 72000000
			rcc_set_prescaler(RCC_PRESCALER_USB, RCC_USB_SYSCLK_DIV_1_5);
			#elif F_CPU == 48000000
			rcc_set_prescaler(RCC_PRESCALER_USB, RCC_USB_SYSCLK_DIV_1);
        __weak void board_setup_gpio(void) {
            gpio_init_all();
        __weak void board_setup_usb(void) {
#ifdef SERIAL_USB
//          SerialUSB.begin();
			Serial.begin();// Roger Clark. Changed SerialUSB to Serial for Arduino sketch compatibility
        __weak void series_init(void) {
            // Initialize AFIO here, too, so peripheral remaps and external
            // interrupts work out of the box.
            afio_init();
Also for my tests I had changed boards.txt maple mini to add a speed selection menu like this
mapleMini.name=Maple Mini
mapleMini.build.board=MAPLE_MINI
mapleMini.vid.0=0x1EAF
mapleMini.pid.0=0x0004
mapleMini.build.core=maple
mapleMini.build.cpu_flags=-DMCU_STM32F103CB -DSERIAL_USB
mapleMini.build.variant=maple_mini
mapleMini.upload.usbID=1EAF:0003
mapleMini.upload.tool=maple_upload
mapleMini.upload.protocol=maple_dfu
mapleMini.upload.use_1200bps_touch=false
mapleMini.upload.file_type=bin
mapleMini.upload.auto_reset=true
mapleMini.menu.bootloader_version.original = Original (17k RAM,108k Flash)
mapleMini.menu.bootloader_version.original.build.vect=VECT_TAB_ADDR=0x8005000
mapleMini.menu.bootloader_version.original.build.ldscript=ld/flash.ld
mapleMini.menu.bootloader_version.original.upload.ram.maximum_size=17408
mapleMini.menu.bootloader_version.original.upload.flash.maximum_size=110592
mapleMini.menu.bootloader_version.original.upload.maximum_size=110592
mapleMini.menu.bootloader_version.original.upload.altID=1
mapleMini.menu.bootloader_version.bootloader20 = Bootloader 2.0 (20k RAM,120k Flash)
mapleMini.menu.bootloader_version.bootloader20.build.vect=VECT_TAB_ADDR=0x8002000
mapleMini.menu.bootloader_version.bootloader20.build.ldscript=ld/bootloader_20.ld
mapleMini.menu.bootloader_version.bootloader20.upload.ram.maximum_size=20480
mapleMini.menu.bootloader_version.bootloader20.upload.flash.maximum_size=122880
mapleMini.menu.bootloader_version.bootloader20.upload.maximum_size=122880
mapleMini.menu.bootloader_version.bootloader20.upload.altID=2
mapleMini.menu.cpu_speed.speed_72mhz=72Mhz
mapleMini.menu.cpu_speed.speed_72mhz.build.f_cpu=72000000L
mapleMini.menu.cpu_speed.speed_48mhz=48Mhz (lower power with USB)
mapleMini.menu.cpu_speed.speed_48mhz.build.f_cpu=48000000L
If you update those 2 files you can select 48Mhz and the USB will still work
You can make the Maple mini run at 8Mhz, but USB will not work for Serial and you will need to attach a USB to Serial adaptor and send debug messages via Serial1
Also upload will not work unless you press reset just before the IDE will upload the sketch
I may add this new menu (72Mhz / 48Mhz ) to the Maple mini, but I'm not sure its much use if you are running from USB as saving power by running the clock slower would not be necessary as the board is powered from the host USB
navintiwari08
Post by navintiwari08 » Wed Aug 17, 2016 3:48 am
Thanks Roger!
Got the timer working. I guess I'll run it at 72 MHz only for now. I don't really see a point in slowing it down to 48 MHz.
I'll try to experiment and interface few peripherals at hand. And probably set up a little serial com to control things from my PC's keyboard.
keep it burning!
Navin
Post by RogerClark » Wed Aug 17, 2016 4:39 am
Navin
I agree.
navintiwari08 wrote: I don't really see a point in slowing it down to 48 MHz.
I don't see any point in running at 48Mhz either, as if the STM32 is bring powered from the USB host, there is no need to save 10mA by reducing the clock speed.
The only benefit in reducing the clock speed is if you run at the minimum of 8Mhz (some boards have 12Mhz crystal but most , including the Maple Mini have a 8Mhz crystal).
There is another current thread about using the STM32 as a LUX (light colour) meter, and it switches the board to use HSE (High Speed External) direct for clock, rather than HSE -> PLL - > master clock
This seems to be the easiest way to switch to a low clock speed as it bypasses the main / system clock PLL
I have done some tests on a 12Mhz board and power consumption is reduced from 40mA to 10mA if clock is changed from 72Mhz to 8Mhz (and no other changes made)
10mA is still quite high for battery power operation, but this seems to be the minimum achievable without turning off GPIO etc
