get RAM usage - free stack space
Post by ag123 » Mon May 08, 2017 5:41 am
found some rather 'obscure' codes that determine the free stack space from greiman stfat's repository
https://github.com/greiman/SdFat-beta/b ... tack.h#L45
#if defined(__arm__)
extern "C" char* sbrk(int incr);
static int FreeStack() {
  char top = 't';
  return &top - reinterpret_cast<char*>(sbrk(0));
imho this is a nice hack, sbrk is normally at the 'bottom' where malloc allocates memory and moves up, hence the code allocate a variable on the stack (called it top) and measure the distance between 'top' to sbrk();
Re: get RAM usage - free stack space
Post by victor_pv » Mon May 08, 2017 5:27 pm
Nice find. :)
