SoftPWM via DMA and no CPU cycles
Re: SoftPWM via DMA and no CPU cycles
Post by victor_pv » Mon Jul 10, 2017 5:58 pm
BTW, there is a function to do this:
TIMER2_BASE->DIER = TIMER_DIER_CC3DE;
Since it's an inline shouldn't take many instructions and makes the code more portable between timers
 * @brief Enable a timer channel's DMA request.
 * @param dev Timer device, must have type TIMER_ADVANCED or TIMER_GENERAL
 * @param channel Channel whose DMA request to enable.
static inline void timer_dma_enable_req(timer_dev *dev, uint8 channel) {
    *bb_perip(&(dev->regs).gen->DIER, channel + 8) = 1;
Furthermore, you don't need to use a channel CC to trigger the DMA. The update event (when the timer reaches the overflow there is an update event) could be used for that. There was no function in the core for that, but we just added it recently. If you use that, you dont need to set up the CC, and can keep using the channels for normal PWM if you want (at *resolution* times faster speed than the soft one, so it can provide a timebase if one is needed at the frequency of DMA refresh.
 * @brief Enable a timer's update DMA request
static inline void timer_dma_enable_upd_req(timer_dev *dev) {
    *bb_perip(&(dev->regs).gen->DIER, TIMER_DIER_UDE_BIT) = 1;
This may have drawbacks though, I believe when you change the ARR and call timer.update it will also generate an update event, and so 1 DMA transfer.
