TEK 4010/4014 Vector Graphics terminal DEMO
ChrisMicro
Re: TEK 4010/4014 Vector Graphics terminal DEMO
Post by ChrisMicro » Tue Jul 25, 2017 6:21 am
Regarding doing fills.
Maybe we can bring Tek to fill out a rectangle if we write a "space" character with the desired color and dimension at the desired coordinate.
Of course, this will only work for horizontally and vertically aligned fills.
You can do "pseudo fills" if the screen resolutions fits.
You can see the result if you just install the GuiPittix-Library and run the LED-example with TEK-output.
I make this library to have universal graphical elements on any display. Probably I will start to make special vector graphics elements to support this type of displays.
zoomx
Post by zoomx » Tue Jul 25, 2017 6:34 am
RogerClark wrote:
Mon Jul 24, 2017 10:44 pm
I recall some early video games that also used vector displays.
Perhaps we can have Asteriods ;-)
I recall also Battle Tank and a two player game I don't remember the name. It was a battle between two battleship in a gravitational field.
Post by RogerClark » Tue Jul 25, 2017 7:19 am
https://en.wikipedia.org/wiki/Battlezon ... ideo_game)
was the tank one
I vaguely recall playing something based on Star Trek, with a "Enterprise" and "Kingon" ship (while on a school trip, I think we went to an arcade when we should have been doing something educational! and they had some old game console machines )
Possibly
http://davesclassicarcade.com/startrek/startrek.html
https://en.wikipedia.org/wiki/Star_Trek_(arcade_game)
But the one I remember seemed to predate this, and from what I recall was more like asteroids, in that it was 2D plan view
Post by RogerClark » Tue Jul 25, 2017 7:26 am
I found what appears to be a good list of vector games
http://wikivisually.com/wiki/Category:V ... cade_games
Post by Pito » Tue Jul 25, 2017 8:26 am
Regarding fills: you may fill with solid lines - the TT's or Xterm's side is fast enough, the bottleneck is the Serial connectivity to the tek terminal. In order to fill ie. 300x300 box with lines you need to send about 2700 bytes via serial, with current usb speeds of say 200kB/sec it is something like 13msecs. So it is not so "slow". It would be slow when running Tek terminal via 9k6.
Post by Pito » Tue Jul 25, 2017 8:53 am
For example: the filling a 300x300 box with solid lines
  uint32_t elapsed = micros();
  for (i=100; i<400; i++){
          tek.Tekline(i,100,i,400);
 elapsed = micros() - elapsed;
takes 2.9ms - 7.7ms with the latest libmaple usb on Black f407ZE..
Tek 300x300 line fill.JPG (26.19 KiB) Viewed 242 times
Btw, why such spread?? (2.897ms - 7.933ms).
Post by Pito » Tue Jul 25, 2017 9:22 am
While reading the TT's source I can see there some interesting functionality regarding printing the texts.
You can set for example the text orientation, 0, 90, 180, 270 deg. That is great when drawing graphs and charts..
Post by stevestrong » Tue Jul 25, 2017 9:39 am
I can only think on the host processing speed, the libmaple USB has a 2kB Tx buffer, uses blocking Tx, and if the Tekline() command sends more than 5 bytes, then the buffer gets full and will allow sending of further bytes only if the host is reading some of previously sent ones.
So actually the ~3 ms is the time just to write the data to the Tx buffer.
Post by RogerClark » Tue Jul 25, 2017 9:57 am
I don't think its worthwhile doing fill's with lines
Its better to find a python TEK 4010 client and add a new command for fills
Post by Pito » Tue Jul 25, 2017 10:21 am
Ok, the 8ms is the realistic time for filling the 300x300box..
That is not bad provided most of potential users may use the Tek emulator for a visualization of their measurements done with their ..duinos in a form of simple 2D graphs/charts, with the option of having easy copy/paste/saving/printing of their graphs. And without a need to mess with windows programming.
I did not test with Xterm, but sources claim it works as well..
PS: while I messed with the spectrum analyzer POC above, the lesson learned is following: the data acquisition - sampling the ADC data - takes much longer than the processing and plotting them in Tek window. For example with 100kHz sampling rate, you need 10msecs to get 1024 samples in, you need to average the spectra in order to get some nice results, I did with 64 spectra, thus the total time for data sampling was 640ms. The actual fft processing of 64 spectra takes maybe 100 msecs in total (fpu on). So the refresh rate of the spectra on the Tek screen was below 1sec. The plotting the data took maybe 15msecs.
