soft PWM via DMA
arpruss
soft PWM via DMA
Post by arpruss » Thu Oct 26, 2017 3:05 pm
I wanted to do PWM on a pin that had no PWM support, specifically the PB12 pin of the LED on the black pill. Solution: circular DMA transfer to BSRR. The PWM frequency is 7.2MHz (the scope picture shows 3.6, but that's for both the low and the high together), which is kind of crazy. Memory use is 4*DMA_PWM_MAX_DUTY.
To turn off, just call setDMAPWM with duty cycle at 0 or at the maximum.
Is there any way to lower the DMA speed, by the way?
#include <dma_private.h>
#define PIN_TO_PULSE PB12
#define DMA_PWM_MAX_DUTY 32
uint32_t data[DMA_PWM_MAX_DUTY];
void setDMAPWM(uint32_t pin, uint32_t duty_cycle) {
  gpio_dev *dev = digitalPinToPort(pin);
  uint32_t maskOn = digitalPinToBitMask(pin);
  uint32_t maskOff = digitalPinToBitMask(pin) << 16;
  if (duty_cycle == 0 || duty_cycle >= DMA_PWM_MAX_DUTY) {
    dma_disable(DMA1, DMA_CH1);
    gpio_write_bit(dev, PIN_MAP[pin].gpio_bit, duty_cycle != 0);
    return;
  for (uint32_t i=0; i<duty_cycle; i++)
    data[i] = maskOn;
  for (uint32_t i=duty_cycle; i<DMA_PWM_MAX_DUTY; i++)
    data[i] = maskOff;
  dma_init(DMA1);
  dma_setup_transfer(DMA1, DMA_CH1, data, DMA_SIZE_32BITS, &(dev->regs->BSRR),
    DMA_SIZE_32BITS, DMA_PINC_MODE |  DMA_MEM_2_MEM | DMA_CIRC_MODE);
  dma_set_num_transfers(DMA1, DMA_CH1, DMA_PWM_MAX_DUTY);
  dma_enable(DMA1, DMA_CH1);
  pinMode(PIN_TO_PULSE, OUTPUT);
  setDMAPWM(PIN_TO_PULSE, 1);
  for(int i=0;i<DMA_PWM_MAX_DUTY;i++) {
    setDMAPWM(PIN_TO_PULSE, i);
    delay(50);
    setDMAPWM(PIN_TO_PULSE, DMA_PWM_MAX_DUTY-1-i);
    delay(50);
racemaniac
Re: PWM via DMA
Post by racemaniac » Thu Oct 26, 2017 3:21 pm
i don't think there's a way to throttle mem2mem DMA.
in a thread where we did benchmarks on the effect of DMA on the performance of the MCU, someone also mentioned that the datasheet mentions you shouldn't put mem2mem in circular mode (but as you can guess, that's what i did for the benchmark)
Once you do that, you really see how much it affects other dma's running, as the poor dma controller is used at full capacity :).
so use at your own risk :)
Re: PWM via DMA
Post by stevestrong » Thu Oct 26, 2017 7:35 pm
Normally you should trigger the DMA by a timer trigger or compare output, so that you can control the frequency.
In this case you should use memory to peripheral mode (DMA_MINC_MODE | DMA_MEM_2_PER | DMA_CIRC_MODE).
Or you use a larger buffer (256 bytes), and thus also increase the PWM resolution.
arpruss
Re: PWM via DMA
Post by arpruss » Thu Oct 26, 2017 9:01 pm
But does it affect performance when one isn't using other DMAs?
... Nevermind, I found the thread.
Answer: not much.
arpruss
Re: PWM via DMA
Post by arpruss » Thu Oct 26, 2017 10:33 pm
My own benchmarking shows a 10% decrease in speed for memory dominated tasks.
Re: PWM via DMA
Post by victor_pv » Fri Oct 27, 2017 4:21 am
As Steve said, instead of doing mem2mem, configure the DMA as mem2per, and use a dma channel that can be triggered by a timer event (either the time update, or one of the channel compares), enable DMA requests for that timer (or timer channel), and the timer will trigger the transfers at the rate you set the timer to.
arpruss
Re: PWM via DMA
Post by arpruss » Fri Oct 27, 2017 3:34 pm
Thanks! In fact, I see a thread on this.
Re: soft PWM via DMA
Post by stevestrong » Sun Oct 29, 2017 9:27 am
I changed the title to reflect that the PWM generated here is a software solution.
similar project: viewtopic.php?f=18&t=2305
