Dual LFO with choice of waveforms using PT8211 and Blue Pill
KenLaszlo
Post by KenLaszlo » Fri Nov 24, 2017 2:12 pm
Hi folks
Roger encouraged me to make a post here, so here's me 'taking the plunge'. My first code-snippet / project.
From reading Vasillis code example using the PT8211 (thank you!), if spurred me on to create a dual LFO.
I was interested in getting two independant waveforms out of the chip with a choice of wave shapes, and a frequency between 0.1Hz and 100Hz.
The code here seems to work fine. There is, however, an issue with the waveforms generated. Particularly at lower frequencies.
    Dual LFO for STM32F103C8T6
    Description:
    This code generates separate low frequency waveforms on the two channels of the PT8211 DAC.
    My remit was for frequencies approximately between 0.1Hz and 100Hz (LFO) and a choice of waveforms
    including sine, saw, reverse saw, triangle and square
    Created by Ken Laszlo 24/11/2017
    email:  wight446-at-yahoo.com
    Thanks to Roger Clark, Vassilis Serasidis and Madis
    Connections between PT8211 DAC and the STM32F103C8T6
    WS    <-->  PA3
    BCK   <-->  PA5 <-->  BOARD_SPI1_SCK_PIN
    DIN   <-->  PA7 <-->  BOARD_SPI1_MOSI_PIN
    100K Potentiometers on PA2 and PA4 providing a scaled voltage between 0 and 3.3v for frequency selection
    100K Potentiometers on PA6 and PA8 providing a scaled voltage between 0 and 3.3v for wave type selection
#include <SPI.h>
#define WS   PA3
#define BCK  PA5
#define DATA PA7
#define SINE 0
#define SAWTOOTH 1
#define REVSAWTOOTH 2
#define TRIANGLE 3
#define SQUARE 4
int waveRead;
byte waveType1 = SINE;
byte waveType2 = SAWTOOTH;
int maxSamples1 = 512;
int maxSamples2 = 512;
int sampPos1, sampPos2 = 0;
int ratio1, ratio2;
int phaseAccumulator1, phaseAccumulator2 = 0;
uint16_t thisSample1, thisSample2;                // 16 Bit as these will be fed to the DAC
// Sine generator
// http://www.daycounter.com/Calculators/Sine-Generator-Calculator.phtml
// Triangle generator
// http://www.daycounter.com/Calculators/Triangle-Wave-Generator-Calculator.phtml
// A 512 point Sine Array (-32767 to +32767)
const uint16_t sineArray[512] PROGMEM = {  1, 403, 805, 1207, 1608, 2010, 2411, 2812, 3212, 3612, 4012, 4410, 4808, 5206, 5602, 5998,
                                           6393, 6787, 7180, 7572, 7962, 8352, 8740, 9127, 9512, 9896, 10279, 10660, 11040, 11417, 11793, 12168,
                                           12540, 12911, 13279, 13646, 14010, 14373, 14733, 15091, 15447, 15800, 16152, 16500, 16846, 17190, 17531, 17869,
                                           18205, 18538, 18868, 19196, 19520, 19842, 20160, 20476, 20788, 21097, 21403, 21706, 22006, 22302, 22595, 22885,
                                           23171, 23453, 23732, 24008, 24280, 24548, 24812, 25073, 25330, 25583, 25833, 26078, 26320, 26557, 26791, 27020,
                                           27246, 27467, 27684, 27897, 28106, 28311, 28511, 28707, 28899, 29086, 29269, 29448, 29622, 29792, 29957, 30118,
                                           30274, 30425, 30572, 30715, 30853, 30986, 31114, 31238, 31357, 31471, 31581, 31686, 31786, 31881, 31972, 32058,
                                           32138, 32214, 32286, 32352, 32413, 32470, 32522, 32568, 32610, 32647, 32679, 32706, 32729, 32746, 32758, 32766,
                                           32767, 32766, 32758, 32746, 32729, 32706, 32679, 32647, 32610, 32568, 32522, 32470, 32413, 32352, 32286, 32214,
                                           32138, 32058, 31972, 31881, 31786, 31686, 31581, 31471, 31357, 31238, 31114, 30986, 30853, 30715, 30572, 30425,
                                           30274, 30118, 29957, 29792, 29622, 29448, 29269, 29086, 28899, 28707, 28511, 28311, 28106, 27897, 27684, 27467,
                                           27246, 27020, 26791, 26557, 26320, 26078, 25833, 25583, 25330, 25073, 24812, 24548, 24280, 24008, 23732, 23453,
                                           23171, 22885, 22595, 22302, 22006, 21706, 21403, 21097, 20788, 20476, 20160, 19842, 19520, 19196, 18868, 18538,
                                           18205, 17869, 17531, 17190, 16846, 16500, 16152, 15800, 15447, 15091, 14733, 14373, 14010, 13646, 13279, 12911,
                                           12540, 12168, 11793, 11417, 11040, 10660, 10279, 9896, 9512, 9127, 8740, 8352, 7962, 7572, 7180, 6787,
                                           6393, 5998, 5602, 5206, 4808, 4410, 4012, 3612, 3212, 2812, 2411, 2010, 1608, 1207, 805, 403,
                                           1, -402, -804, -1206, -1607, -2009, -2410, -2811, -3211, -3611, -4011, -4409, -4807, -5205, -5601, -5997,
                                           -6392, -6786, -7179, -7571, -7961, -8351, -8739, -9126, -9511, -9895, -10278, -10659, -11039, -11416, -11792, -12167,
                                           -12539, -12910, -13278, -13645, -14009, -14372, -14732, -15090, -15446, -15799, -16151, -16499, -16845, -17189, -17530, -17868,
                                           -18204, -18537, -18867, -19195, -19519, -19841, -20159, -20475, -20787, -21096, -21402, -21705, -22005, -22301, -22594, -22884,
                                           -23170, -23452, -23731, -24007, -24279, -24547, -24811, -25072, -25329, -25582, -25832, -26077, -26319, -26556, -26790, -27019,
                                           -27245, -27466, -27683, -27896, -28105, -28310, -28510, -28706, -28898, -29085, -29268, -29447, -29621, -29791, -29956, -30117,
                                           -30273, -30424, -30571, -30714, -30852, -30985, -31113, -31237, -31356, -31470, -31580, -31685, -31785, -31880, -31971, -32057,
                                           -32137, -32213, -32285, -32351, -32412, -32469, -32521, -32567, -32609, -32646, -32678, -32705, -32728, -32745, -32757, -32765,
                                           -32767, -32765, -32757, -32745, -32728, -32705, -32678, -32646, -32609, -32567, -32521, -32469, -32412, -32351, -32285, -32213,
                                           -32137, -32057, -31971, -31880, -31785, -31685, -31580, -31470, -31356, -31237, -31113, -30985, -30852, -30714, -30571, -30424,
                                           -30273, -30117, -29956, -29791, -29621, -29447, -29268, -29085, -28898, -28706, -28510, -28310, -28105, -27896, -27683, -27466,
                                           -27245, -27019, -26790, -26556, -26319, -26077, -25832, -25582, -25329, -25072, -24811, -24547, -24279, -24007, -23731, -23452,
                                           -23170, -22884, -22594, -22301, -22005, -21705, -21402, -21096, -20787, -20475, -20159, -19841, -19519, -19195, -18867, -18537,
                                           -18204, -17868, -17530, -17189, -16845, -16499, -16151, -15799, -15446, -15090, -14732, -14372, -14009, -13645, -13278, -12910,
                                           -12539, -12167, -11792, -11416, -11039, -10659, -10278, -9895, -9511, -9126, -8739, -8351, -7961, -7571, -7179, -6786,
                                           -6392, -5997, -5601, -5205, -4807, -4409, -4011, -3611, -3211, -2811, -2410, -2009, -1607, -1206, -804, -402,
// A 512 point Triangle Array (-32767 to +32767)
const uint16_t triangleArray[512] PROGMEM = { -32511, -32255, -31999, -31743, -31487, -31231, -30975, -30719, -30463, -30207, -29951, -29695, -29439, -29183, -28927, -28671,
                                              -28415, -28159, -27903, -27647, -27391, -27135, -26879, -26623, -26367, -26111, -25855, -25599, -25343, -25087, -24831, -24575,
                                              -24319, -24063, -23807, -23551, -23295, -23039, -22783, -22527, -22271, -22015, -21759, -21503, -21247, -20991, -20735, -20479,
                                              -20223, -19967, -19711, -19455, -19199, -18943, -18687, -18431, -18175, -17919, -17663, -17407, -17151, -16895, -16639, -16383,
                                              -16127, -15871, -15615, -15359, -15103, -14847, -14591, -14335, -14079, -13823, -13567, -13311, -13055, -12799, -12543, -12287,
                                              -12031, -11775, -11519, -11263, -11007, -10751, -10495, -10239, -9983, -9727, -9471, -9215, -8959, -8703, -8447, -8191,
                                              -7935, -7679, -7423, -7167, -6911, -6655, -6399, -6143, -5887, -5631, -5375, -5119, -4863, -4607, -4351, -4095,
                                              -3839, -3583, -3327, -3071, -2815, -2559, -2303, -2047, -1791, -1535, -1279, -1023, -767, -511, -255, 1,
                                              256, 512, 768, 1024, 1280, 1536, 1792, 2048, 2304, 2560, 2816, 3072, 3328, 3584, 3840, 4096,
                                              4352, 4608, 4864, 5120, 5376, 5632, 5888, 6144, 6400, 6656, 6912, 7168, 7424, 7680, 7936, 8192,
                                              8448, 8704, 8960, 9216, 9472, 9728, 9984, 10240, 10496, 10752, 11008, 11264, 11520, 11776, 12032, 12288,
                                              12544, 12800, 13056, 13312, 13568, 13824, 14080, 14336, 14592, 14848, 15104, 15360, 15616, 15872, 16128, 16384,
                                              16640, 16896, 17152, 17408, 17664, 17920, 18176, 18432, 18688, 18944, 19200, 19456, 19712, 19968, 20224, 20480,
                                              20736, 20992, 21248, 21504, 21760, 22016, 22272, 22528, 22784, 23040, 23296, 23552, 23808, 24064, 24320, 24576,
                                              24832, 25088, 25344, 25600, 25856, 26112, 26368, 26624, 26880, 27136, 27392, 27648, 27904, 28160, 28416, 28672,
                                              28928, 29184, 29440, 29696, 29952, 30208, 30464, 30720, 30976, 31232, 31488, 31744, 32000, 32256, 32512, 32767,
                                              32512, 32256, 32000, 31744, 31488, 31232, 30976, 30720, 30464, 30208, 29952, 29696, 29440, 29184, 28928, 28672,
                                              28416, 28160, 27904, 27648, 27392, 27136, 26880, 26624, 26368, 26112, 25856, 25600, 25344, 25088, 24832, 24576,
                                              24320, 24064, 23808, 23552, 23296, 23040, 22784, 22528, 22272, 22016, 21760, 21504, 21248, 20992, 20736, 20480,
                                              20224, 19968, 19712, 19456, 19200, 18944, 18688, 18432, 18176, 17920, 17664, 17408, 17152, 16896, 16640, 16384,
                                              16128, 15872, 15616, 15360, 15104, 14848, 14592, 14336, 14080, 13824, 13568, 13312, 13056, 12800, 12544, 12288,
                                              12032, 11776, 11520, 11264, 11008, 10752, 10496, 10240, 9984, 9728, 9472, 9216, 8960, 8704, 8448, 8192,
                                              7936, 7680, 7424, 7168, 6912, 6656, 6400, 6144, 5888, 5632, 5376, 5120, 4864, 4608, 4352, 4096,
                                              3840, 3584, 3328, 3072, 2816, 2560, 2304, 2048, 1792, 1536, 1280, 1024, 768, 512, 256, 1,
                                              -255, -511, -767, -1023, -1279, -1535, -1791, -2047, -2303, -2559, -2815, -3071, -3327, -3583, -3839, -4095,
                                              -4351, -4607, -4863, -5119, -5375, -5631, -5887, -6143, -6399, -6655, -6911, -7167, -7423, -7679, -7935, -8191,
                                              -8447, -8703, -8959, -9215, -9471, -9727, -9983, -10239, -10495, -10751, -11007, -11263, -11519, -11775, -12031, -12287,
                                              -12543, -12799, -13055, -13311, -13567, -13823, -14079, -14335, -14591, -14847, -15103, -15359, -15615, -15871, -16127, -16383,
                                              -16639, -16895, -17151, -17407, -17663, -17919, -18175, -18431, -18687, -18943, -19199, -19455, -19711, -19967, -20223, -20479,
                                              -20735, -20991, -21247, -21503, -21759, -22015, -22271, -22527, -22783, -23039, -23295, -23551, -23807, -24063, -24319, -24575,
                                              -24831, -25087, -25343, -25599, -25855, -26111, -26367, -26623, -26879, -27135, -27391, -27647, -27903, -28159, -28415, -28671,
                                              -28927, -29183, -29439, -29695, -29951, -30207, -30463, -30719, -30975, -31231, -31487, -31743, -31999, -32255, -32511, -32767,
HardwareTimer timer(3);
  pinMode(PA2, INPUT_ANALOG);        // LFO Rate Potentiometers
  pinMode(PA4, INPUT_ANALOG);
  pinMode(PA6, INPUT_ANALOG);        // Wavetype Potentiometers - We can calculate 'voltage represents wavetype' for our needs
  pinMode(PA8, INPUT_ANALOG);
  // A3, A5 and A7 are in use by the PT8211 DAC
  SPI.begin();                                  //  Initialize the SPI_1 port.
  SPI.setBitOrder(MSBFIRST);                    //  Set the SPI_1 bit order
  SPI.setDataMode(SPI_MODE0);                   //  Set the  SPI_2 data mode 0
  SPI.setClockDivider(SPI_CLOCK_DIV4);          //  Speed (72 / 4 = 18 MHz SPI_1 speed) PT8211 up to 20MHZ clock
  pinMode(WS, OUTPUT);                          //  Set the Word Select pin (WS) as output.
  SPI.setDataSize (SPI_CR1_DFF);                //  Set SPI data size to 16Bit
  // timer3 setup
  timer.pause();                                      // Pause the timer while we're configuring it
  timer.setPeriod(20);                                // Set up period in microseconds  -- 40 Microseconds gives 100Hz with 256 samples per second, 20 Microseconds give 100Hz with 512 samps/s
  timer.setChannel1Mode(TIMER_OUTPUT_COMPARE);        // Set up an interrupt on channel 1
  timer.setCompare(TIMER_CH1, 1);                     // Interrupt 1 count after each update
  timer.attachCompare1Interrupt(update_sample);       // The interrupt routine we shall run
  timer.refresh();                                    // Refresh the timer's count, prescale, and overflow
  timer.resume();                                     // Start the timer counting
void loop () {
  maxSamples1 = 512 + (analogRead(PA2) * 16 );
  maxSamples2 = 512 + (analogRead(PA4) * 16 );
  waveRead = analogRead(PA6);               // 12 bits - 0 to 4095
  switch (waveRead) {                       // Set the wavetype1 from the value received
    case 0000 ... 800:
      waveType1 = SINE;
      break;
    case 801 ... 1600:
      waveType1 = SAWTOOTH;
      break;
    case 1601 ... 2400:
      waveType1 = REVSAWTOOTH;
      break;
    case 2401 ... 3200:
      waveType1 = TRIANGLE;
      break;
    case 3201 ... 4095:
      waveType1 = SQUARE;
      break;
     waveRead = analogRead(PA8);               // 12 bits - 0 to 4095
      switch (waveRead) {                       // Set the wavetype2 from the value received
        case 0000 ... 800:
          waveType2 = SINE;
          break;
        case 801 ... 1600:
          break;
        case 1601 ... 2400:
          waveType2 = REVSAWTOOTH;
          break;
        case 2401 ... 3200:
          waveType2 = TRIANGLE;
          break;
        case 3201 ... 4095:
          waveType2 = SQUARE;
          break;
void update_sample(void)
  phaseAccumulator1++;       // Move to next samples position
  phaseAccumulator2++;
  if (phaseAccumulator1 >= maxSamples1) phaseAccumulator1 = 0;          // Check for overflow i.e. value of 1024 at max freq
  if (phaseAccumulator2 >= maxSamples2) phaseAccumulator2 = 0;
  ratio1 = maxSamples1 * 10000;
  ratio2 = maxSamples2 * 10000;
  ratio1 = ratio1 / 512;         // (Bit shift 10 right is no faster / the same)
  ratio2 = ratio2 / 512;
  sampPos1 = phaseAccumulator1 * 10000;
  sampPos2 = phaseAccumulator2 * 10000;
  sampPos1 = sampPos1 / ratio1;
  sampPos2 = sampPos2 / ratio2;
  switch (waveType1) {
    case SINE:
      thisSample1 = pgm_read_word_near(&sineArray[(int)sampPos1]);
      break;
    case SAWTOOTH:
      thisSample1 = ((sampPos1 - 255) * 128);
      break;
    case REVSAWTOOTH:
      thisSample1 = ((255 -  sampPos1) * 128);
      break;
    case TRIANGLE:
      thisSample1 = pgm_read_word_near(&triangleArray[(int)sampPos1]);
      break;
    case SQUARE:
      if (sampPos1 < 256) {
        thisSample1 = 32767;
      }  else {
        thisSample1 = -32767;
      break;
  switch (waveType2) {
    case SINE:
      thisSample2 = pgm_read_word_near(&sineArray[(int)sampPos2]);
      break;
    case SAWTOOTH:
      thisSample2 = ((sampPos2 - 255) * 128);
      break;
    case REVSAWTOOTH:
      thisSample2 = ((255 -  sampPos2) * 128);
      break;
    case TRIANGLE:
      thisSample2 = pgm_read_word_near(&triangleArray[(int)sampPos2]);
      break;
    case SQUARE:
      if (sampPos2 < 256) {
        thisSample2 = 32767;
      }  else {
        thisSample2 = -32767;
      break;
  // Write the values to the DAC
  gpio_write_bit(GPIOA, 3, LOW);      //  Replaces digitalWrite(WS, LOW);  Select RIGHT Audio channel
  SPI.write(thisSample1);
  gpio_write_bit(GPIOA, 3, HIGH);     //  Replaces digitalWrite(WS, HIGH); Select LEFT Audio channel
  SPI.write(thisSample2);
I realise the code is quite 'verbose' - I am self-taught :)
Positive criticism and improvements are welcomed (especially optimisation for speed).
I'm happy with the way it runs, but there is a problem with the generated waveforms - Particularly the lower in frequency you get.
You can clearly see the 'slope' to the square wave. This gets worse the lower in frequency you go. In fact, all the waveforms (apart from Sine) degrade in quality the lower you go in frequency until they become completely unrecognisable.
(Other waveforms on the next post)
The output of the PT8211 is going through a 47uF capacitor to a potential divider of two resistors to bring the level down to 1V peak-to-peak before I send it into the LINE IN on the PC. The screen captures are from a PC software oscilloscope, using the Sound Card LINE IN input.
Would things be improved with an op-amp buffer?
Ultimately, I will want rid of the 47uF cap as I will want the varying DC voltage, rather than an AC waveform for my purposes.
What's the best way of doing this do you think, please?
Thank you
Ken
KenLaszlo
Re: Dual LFO with choice of waveforms using PT8211 and Blue Pill
Post by KenLaszlo » Fri Nov 24, 2017 2:13 pm
zoomx
Post by zoomx » Fri Nov 24, 2017 3:26 pm
Interesting!
I found only one board with PT8211, the one by Paul Stoffregen. It is cheap, less than 3$ but unfortunately shipping cost to Europe is from 13 to 16$ depending on weight.
KenLaszlo
Post by KenLaszlo » Fri Nov 24, 2017 4:31 pm
I managed to get ten PT8211 SMD Chips from eBay (sent from China) for 1.88 USD.
I got four SMD to DIP8 Adapter PCB Boards from a UK seller for 1.89 UKP.
Dirt cheap.
Ken
Post by ahull » Fri Nov 24, 2017 5:03 pm
Those square waves look like they are being passed through some sort of L/C or R/C filter, are you sure the issue is not with your scope or probes. Try the scope on DC coupled rather than AC coupled, since the frequency is so low. If that makes no difference, try a couple of short wires in place of the scope probe.
EDIT: OK I need to learn to read the *whole* post in future...
I suspect his is your issue, that capacitor/resistor combination is going to act as an R/C filter, and is going to have a negative effect, which gets more pronounced the lower the frequency... try replacing the 47uF capacitor with a suitable resistor.. Without knowing the values of your voltage divider I suggest you try a 10K or 47K pot, start at full resistance and tweak it till you get a suitable amplitude for your purposes, then replace with a resistor of that value (unless you feel like doing the maths to calculate the value required).
dave j
Post by dave j » Fri Nov 24, 2017 5:12 pm
Sound card inputs are almost always AC coupled so won't handle very low frequencies or steady voltages properly - so don't worry to much about your PC oscilloscope output. Without a proper scope, capturing a set of samples with a microcontroller with an ADC, transferring them to a PC and displaying them in a graphing app (even a spreadsheet would do) is the easiest way of getting waveform plots.
Post by ahull » Fri Nov 24, 2017 5:14 pm
.. or you could build the pig-o-scope and use that to measure the waveforms :D it has no filtering or buffering whatsoever.
Post by Pito » Fri Nov 24, 2017 6:29 pm
An RC is called "integrative circuit (low-pass)", RC wired as CR is called "derivative circuit (high-pass)".
When you integrate or differentiate a sine/cosine signal you will get the same signal shape (math).
With input signal as below the RC will "round the edges", while the CR will pass the fast changes (edges) better and will suppress slow changing parts of the signal.
The signal passing a CR is pulled down - symmetrically around zero level - as well.
That is because the CR suppresses the DC part of the signal - the DC does "not change fast enough :) to be passed via the CR", in below example DC= 2.5V. We also say CR "decouples" the DC part of the signal.
Therefore your signal will read -1.25 to 1.25Vpp at the output of the R1/R2 divider finally (see below).
KenLaszlo
Post by KenLaszlo » Sun Nov 26, 2017 7:06 pm
Thank you all for your assistance and further input.
These little PT8211s are genius!
Hey Pito - Nice circuit diagrams and output and explanations! Cool!
Thanks, Chap - I get it. A bit of school-boy error in the readings really.
I'm confident the circuit and code are working correctly. I need to read the output on a DC coupled device.
Wow! Thanks for the pointer - I just ordered one of the 2.4" displays for around 4 UKP and another Blue Pill.
Another future project!
Ken
Post by RogerClark » Sun Nov 26, 2017 9:02 pm
ken
Excellent post..
Re your code.
You don’t need to use PROGMEM or the function to read it, The memory space is flat an flash and RAM addresses can be accessed directly via pointers
Just define your arrays as const , is enough to put them in flash ..
Analog read is slow for compatibility with AVR which has dedicated analog input pins and hence no need to set the pin mode
STM32is different as pins have multiple uses, so If I remember right, analogRead calls pinmode
There is direct call on the LibMaple internal API to read the analog input, but you will need to look in the core as I can’t remember off the top of my head what it’s called. You will also need t call pinMode in setup
I think there are potentially speed improvements in a few places where calculations split onto 2 lines can be combined, but I am typing this post on my IPad and it’s hard to cut and paste which lines I mean
