Waveform Generator (Two DAC examples)
Re: Waveform Generator (Two DAC examples)
Post by stevestrong » Sat Oct 21, 2017 9:18 am
The code you are using is for PT8211.
For TDA1543, you have to :
- exchange the high and low bytes order (it requires LSB then MSB, while your code is sending MSB then LSB)
- the TDA is fed with 5V, the STM32F1 is working with 3.3V - level adaptation may be necessary
EDIT
- the signal values may need adaptation, because the lowest code word -32768 = 8000h yields the largest, the highest code word 32767 = 7FFFh the smallest voltage.
(Beachte: Das niedrigste Kodewort -32768 = 8000h ergibt die größte, das höchste Kodewort 32767 = 7FFFh die kleinste Spannung)
german link: https://www-user.tu-chemnitz.de/~heha/M ... DA1543.htm
escarneiro
Post by escarneiro » Sun Oct 22, 2017 2:40 am
EDIT
Danke! Ich werde es mal gucken.
