Morning all
@fredbox @ag123 @ABOSTM THANK YOU all for your help
The code is now running as I had originally intended and is included below in case it helps someone else in the future.
Note: I did have to move the 'setPWM' out of the main loop as it was 'resetting' the output on every tick even if there was no change, and thus messing up the output. Only executing this IF there was movement in the encoder solved the problem.
As my plan, for the later version, was to have 5 encoders (all on seperate timers), I am rather going to simplify my life (and probably the code overhead) by moving to linear potentiometers.
#include <LiquidCrystal.h> // include the LCD library
const int rs = PB_10, en = PB_2, d4 = PB_1, d5 = PB_0, d6 = PA_7, d7 = PA_6; //STM32 Pins to which LCD is connected
LiquidCrystal lcd(rs, en, d4, d5, d6, d7); //Initialize the LCD
#define STM32DUINO_CORE
#define PWMPIN PA0 // Main Output
#define RUN_FREQ_ENC_CLK PB8 //Encoder1
#define RUN_FREQ_ENC_DATA PB9
#define RUN_PW_SW PA5
#define RUN_PW_ENC_CLK PB4 //Encoder2
#define RUN_PW_ENC_DATA PB5
#define RUN_PW_SW PA6
#define LEDPIN PC13
volatile uint32_t RUN_FREQ = 100;
volatile uint32_t RUN_PW = 10;
// volatile uint32_t BURST_FREQ = 10;
// volatile uint32_t BURST_PW = 50;
// volatile uint32_t ONESHOT_PW = 50;
// Automatically retrieve TIM instance and channel associated to pin
// This is used to be compatible with all STM32 series automatically.
TIM_TypeDef *Instance = (TIM_TypeDef *)pinmap_peripheral(digitalPinToPinName(PWMPIN), PinMap_PWM);
uint32_t channel = STM_PIN_CHANNEL(pinmap_function(digitalPinToPinName(PWMPIN), PinMap_PWM));
void run_freq_enc_read(void)
volatile static uint8_t F_ABs = 0;
F_ABs = (F_ABs << 2) & 0x0f; //left 2 bits now contain the previous AB key read-out;
F_ABs |= (digitalRead(RUN_FREQ_ENC_CLK) << 1) | digitalRead(RUN_FREQ_ENC_DATA);
switch (F_ABs)
case 0x0d:
RUN_FREQ++;
break;
case 0x0e:
RUN_FREQ--;
break;
void run_pw_enc_read(void)
volatile static uint8_t P_ABs = 0;
P_ABs = (P_ABs << 2) & 0x0f; //left 2 bits now contain the previous AB key read-out;
P_ABs |= (digitalRead(RUN_PW_ENC_CLK) << 1) | digitalRead(RUN_PW_ENC_DATA);
switch (P_ABs)
case 0x0d:
RUN_PW++;
break;
case 0x0e:
RUN_PW--;
break;
void led_blink()
static uint8_t led_state = 0;
led_state = 1 - led_state;
digitalWrite(LEDPIN, led_state);
// LCD setup
lcd.begin(16, 2);//Defining 16*2 LCD
lcd.setCursor(0, 0); //LCD Row 0 and Column 0
lcd.print("Freaky ISSTC"); //Print this Line
lcd.setCursor(0, 1); //LCD Row 0 and Column 1
lcd.print("Interrupter V1.0"); //Print this Line
delay(4000); //wait for four secounds
lcd.clear(); //Clear the screen
// Encoder setup
pinMode(RUN_FREQ_ENC_CLK, INPUT);
pinMode(RUN_FREQ_ENC_DATA, INPUT);
pinMode(RUN_PW_ENC_CLK, INPUT);
pinMode(RUN_PW_ENC_DATA, INPUT);
pinMode(LEDPIN, OUTPUT);
// Configure and start PWM
MyTim->setPWM(channel, PWMPIN, RUN_FREQ, RUN_PW); // RUN_FREQ Hertz, RUN_PW dutycycle
static uint32_t freq_count;
static uint32_t freq_prevCount;
freq_count = RUN_FREQ;
if (freq_count != freq_prevCount)
freq_prevCount = freq_count;
led_blink();
static uint32_t pw_count;
static uint32_t pw_prevCount;
pw_count = RUN_PW;
if (pw_count != pw_prevCount)
pw_prevCount = pw_count;
led_blink();
lcd.print("BPS: ");
lcd.print(RUN_FREQ); // display the beats per second
lcd.setCursor(0,1); // move cursor to next line
lcd.print("PW: ");
lcd.print(RUN_PW); // display the pulse width
delay(200);
lcd.clear();
#ifdef STM32DUINO_CORE
void HAL_SYSTICK_Callback()
run_freq_enc_read();
run_pw_enc_read();
- pic_7_1.png (23.16 KiB) Viewed 3252 times
