I2S example code
Re: I2S example code
Post by victor_pv » Mon Sep 07, 2015 2:00 pm
madias wrote:
I would set all the DMA stuff, including the DMA enable, somewhere else, so
bb_peri_set_bit(&dev->regs->CR2, SPI_CR2_TXDMAEN_BIT, 1); // DMA enable
should not be there.
Yes, sorry, this example is from my test code, I forgot to eliminate the DMA line.
Effect pedal and DUE: I know that stuff: real 12-bit crunchy sound! :) Another thing: For uncomplicated effects like simple delay you wont have enough RAM. I read, that the CMSIS DSP library runs not only on M4, but on M3...maybe a good starting point for porting it (I know that on energia/TI - Tiva somebody ported it)
edit: found it! https://github.com/sumotoy/CMSIS-librar ... a-LM4F-mcu
About the RAM, it depends though, we could always add an SPI RAM, or an FSMC RAM and have plenty ;)
Vassilis
Post by Vassilis » Mon Sep 07, 2015 3:36 pm
madias wrote:
Vassilis wrote:
madias wrote:...vasillis would be the person.
Matthias, may I have a working (latest) copy of your I2S library to make some tests on my VET6 board ?
Vassilis: I've managed it that no changes are needed within spi.c or spi.h!
Please use my code as *.zip and please tell me if you are getting compiling errors! (Maybe I missed some #defines, but I tried it with a "clean" repo)
The test code is for a PT8211 DAC sinus right and saw up left ---> edit: I use SPI3! In the configuration there is no Master Clock enabled.
and edit 2 --> sorry for not cleaning up the code :)
I connected the PT8211
STM32F103VET6 <--> PT8211
PB3 <--> BCK
PA15 <--> WS
PB5 <--> DIN
but I see only a sawtooth wave at 374 Hz on the right channel. Not a sine wave.
Which are the STM32 pins you used ?
madias
Post by madias » Mon Sep 07, 2015 3:52 pm
connections are the same, but on a RET6 board (shouldn't be a different).
What's on the left channel?
edit: sine is on the left channel! I messed up my wiring stuff...
Vassilis
Post by Vassilis » Mon Sep 07, 2015 3:55 pm
I comment-out the line 128 and 134 and it worked:
if (dma_get_isr_bits( DMA2, DMA_CH2) == 3)
madias
Post by madias » Mon Sep 07, 2015 3:58 pm
yes, but
i2s_buffer[0]= left channel and
i2s_buffer[1]= right channel
with eleminating the if (dma_get_isr_bits( DMA2, DMA_CH2) == 3) you eleminate the right/left stuff! :)
Vassilis
Post by Vassilis » Mon Sep 07, 2015 4:01 pm
By disabling those lines I saw the Sine wave on the Left channel and the Sawtooth wave on the Right channel simultaneously.
madias
Post by madias » Mon Sep 07, 2015 4:08 pm
Yes, but you fill up the buffer[0] and [1] every time, so twice at it would be needed.
I set up a buffer with [2] and the "if" in the function
triggers every "half transfer finished". So it fills up on first interrupt the buffer[0]n and on the next buffer[1]
But maybe I missed/messed something. But can you use my uncorrected example? Strange, that this is working on my place but not on yours...
Vassilis
Post by Vassilis » Mon Sep 07, 2015 4:12 pm
I will check again the code. Maybe there is some problem with my current stm32duino repo.
madias
Post by madias » Mon Sep 07, 2015 4:28 pm
ok 374 hz is much too fast: 374x256=95744, but it should be 47872
madias
Post by madias » Mon Sep 07, 2015 5:43 pm
ok, I've done a test LED within the dma IRQ:
void DMAEvent() {
    i2s_buffer[0]  = sine[wavecounter1] << 3; // half transfer
    wavecounter1++;
    flip=1;
  else
    i2s_buffer[1] = wavecounter2 << 8 ;
    wavecounter2++;
    flip=0;
  dma_clear_isr_bits(DMA2, DMA_CH2);
digitalWrite(LED,flip);
So you can easily see if left/right buffer is working! LED frequency should be 47.9khz
