$10 O-Scope revisited
What are you developing?
arpruss
Re: $10 O-Scope revisited
Post by arpruss » Mon Oct 02, 2017 9:10 pm
By the way, going way back to the original stm32f1 scope, it's worth noting that if one turns off interrupts during sampling, one can get the full maximum sampling rate (1.7msps) without DMA, just by reading the interleaved data in a tight loop in continuous mode:
void fetch() {
  int channel = PIN_MAP[analogInPin].adc_channel;
  adc_set_sample_rate(ADC1, ADC_SMPR_1_5);
  adc_set_sample_rate(ADC2, ADC_SMPR_1_5);
  adc_set_reg_seqlen(ADC1, 1);
  adc_set_reg_seqlen(ADC2, 1);
  ADC1->regs->SQR3 = channel;
  ADC2->regs->SQR3 = channel;
  ADC1->regs->CR1 |= 0x70000; // ADC_CR1_FASTINT;
  ADC1->regs->CR2 |= ADC_CR2_CONT | ADC_CR2_SWSTART;
  ADC2->regs->CR2 |= ADC_CR2_CONT | ADC_CR2_SWSTART;
  ADC2->regs->CR1 |= 0x70000; // ADC_CR1_FASTINT;
  nvic_globalirq_disable();
  for (int j = 0; j < maxSamples ; j+=2 )
    while (!(ADC1->regs->SR & ADC_SR_EOC))
    dataPoints[j] = ADC1->regs->DR & ADC_DR_DATA;
    while (!(ADC2->regs->SR & ADC_SR_EOC))
    dataPoints[j+1] = ADC2->regs->DR & ADC_DR_DATA;
  nvic_globalirq_enable();
alexandros
Post by alexandros » Tue Oct 03, 2017 6:24 am
I'm Looking at the code of O-Scope and i m trying to understand how can i add a second channel for getting samples.
like
void setADCs ()
	  int pinMapADCinA = PIN_MAP[analogInPinA].adc_channel;
	  int pinMapADCinB = PIN_MAP[analogInPinB].adc_channel;
	  adc_set_sample_rate(ADC1, ADC_SMPR_1_5); //7_5 13_5
	  //  adc_reg_map *regs = dev->regs;
	  ADC1->regs->SQR3 = pinMapADCinA;
	  ADC1->regs->CR2 |= ADC_CR2_CONT; // | ADC_CR2_DMA; // Set continuous mode and DMA
	  ADC1->regs->CR1 |= ADC_CR1_FASTINT; // Interleaved mode
	  ADC1->regs->CR2 |= ADC_CR2_SWSTART;
	  ADC2->regs->SQR3 = pinMapADCinB;
	  ADC2->regs->CR2 |= ADC_CR2_CONT; // ADC 2 continuos
This code works fine .
But i have a problem in taking samples for the ADC2
What do i have to do in order to take the ADC2 values ?
void takeSamplesADC2 ()
  // This loop uses dual interleaved mode to get the best performance out of the ADCs
  dma_init(DMA1);
  dma_attach_interrupt(DMA1, DMA_CH1, DMA1_CH1_Event);
  adc_dma_enable(ADC2);
  dma_setup_transfer(DMA1, DMA_CH1, &ADC2->regs->DR, DMA_SIZE_32BITS,
                     dataPoints32, DMA_SIZE_32BITS, (DMA_MINC_MODE | DMA_TRNS_CMPLT));// Receive buffer DMA
  dma_set_num_transfers(DMA1, DMA_CH1, maxSamples / 2);
  dma1_ch1_Active = 1;
  //  regs->CR2 |= ADC_CR2_SWSTART; //moved to setADC
  dma_enable(DMA1, DMA_CH1); // Enable the channel and start the transfer.
  //adc_calibrate(ADC1);
  //adc_calibrate(ADC2);
  samplingTime = micros();
  while (dma1_ch1_Active);
  samplingTime = (micros() - samplingTime);
  dma_disable(DMA1, DMA_CH1); //End of trasfer, disable DMA and Continuous mode.
  // regs->CR2 &= ~ADC_CR2_CONT;
arpruss
Post by arpruss » Wed Oct 04, 2017 8:32 pm
You can't do two channel of you're using interleaved mode. If you want two channel, you'll be limited in speed to half the maximum.
rexnanet
Post by rexnanet » Sat Oct 07, 2017 6:24 pm
I think that it might be kind of "2 separate channel interleaving". You might get ADC2 samples on the second 16 bits of every 32bit block.
But channel 2 will not be sampled at the same time as channel 1. It will be offset by 7 ADC clocks.
If setting ADC2 to pinB works, than the what I said before should be valid.
EDIT: read http://www.st.com/content/ccc/resource/ ... 258017.pdf
rexnanet
Post by rexnanet » Sun Dec 17, 2017 10:15 pm
ThunderOwl wrote:
Thu Mar 09, 2017 9:59 am
Proud me 8-) , i am featuret at tomeko.net (bottom of "v2d" page) :
http://tomeko.net/miniscope_v2d/index.php?lang=en
Made my "first" attempt at replicating your feats!
Is it a simple case of desoldering the F103 and soldering the F303? Nothing else?
How did you test you swap?
I'm asking because I've swapped them successfully, then opened a "blinky" example on keil uVision 5 and after some trial and error, got the programmer to detect the board by switching one of the jumpers to "1" (the one next to the reset button) and after a few seconds of no led blinking, "magic smoke" begins to appear! :o I saw the led blinking once but after switching the board off, it no longer worked and magic smoke keeps appearing if I power it up (using the ST-link programmer).
