$10 O-Scope revisited
What are you developing?
ThunderOwl
Re: $10 O-Scope revisited
Post by ThunderOwl » Sun Mar 26, 2017 2:56 pm
Update for that simple BT/USB "BluePill" based scope (entry S-14 in my list of DIY scopes). Almost finished version by me:
http://bildites.lv/a/xfjbphbf#33yk2zed
Project forum here:
http://forum.easyelectronics.ru/viewtop ... 4&start=75
In every man's childhood, first 40 years are the hardest
mausi_mick
Post by mausi_mick » Mon Mar 27, 2017 3:17 am
I have now activated channel2 with the second MCP6S91 ...
On the screen ( bottom right) is now a second touch-field to activate the amplifier.
The signals are from external generators.
The video is on Youtube:
https://youtu.be/8uKkUnRKve0
mausi_mick
Post by mausi_mick » Mon Mar 27, 2017 5:34 am
ThunderOwl,
is it somethimng like this:
https://www.crowdsupply.com/aeroscope-l ... -112434141
ThunderOwl
Post by ThunderOwl » Mon Mar 27, 2017 6:21 am
mausi_mick, check my pictures gallery, it is simply STM32 BluePill with MCP6S21 in a box ;-)
mausi_mick
Post by mausi_mick » Mon Mar 27, 2017 8:35 am
ThunderOwl,
what will You make with the HC05/HC06 ?
ThunderOwl
Post by ThunderOwl » Mon Mar 27, 2017 9:59 am
mausi_mick wrote: what will You make with the HC05/HC06 ?
Well, project S-14 (my list reference) initially was Bluetooth only, with HC-06 module. USB connection and Windows host software was actually added at later time, and now is more capable than Android app (which is very rudimentary). I added some pictures, this "BT-USB-O-Scope" checking signal from another project, "Murzik-2" by Fusion (still have to add this to my list).
I added 3 pictures here:
http://bildites.lv/a/xfjbphbf#2krddrqc
http://bildites.lv/users/ThunderJuris/albums
Project "BT-USB-STM-O-Scope":
http://forum.easyelectronics.ru/viewtop ... 17&t=27404 )page 2 nad later)
Project "Murzik-2" (STM32F446 + AD9283):
http://radiokot.ru/forum/viewtopic.php? ... &start=480 (page 25 and later)
BT-O-Scope & Murzik-2
ThunderOwl
Post by ThunderOwl » Mon Mar 27, 2017 11:06 am
It is 100kHz. I think so... :)
I added 3 pictures here (EDIT: 5 pictures added, 2 with LED light mounted):
http://radiokot.ru/forum/viewtopic.php? ... &start=480 (page 25 and later)[/quote]
mausi_mick
Post by mausi_mick » Mon Mar 27, 2017 5:55 pm
ThunderBowl, very nice pictures !
Do You transfer the scope-data via bluetooth to android to display it there ?
It's quick enough ?
something other, you asked for AD9850/51 connected with SPI. I have tested it , but not with success. It was possible to generate a frequency and I can see it on the screen, but if I try to change the frequency their is chaos . Sometimes appears a very high frequency and if I try to set to 100 Hz, he gives a very low frequency back. I tested some diffent software (from Arduino), but I think it's difficult to transfer the frequency order.
Perhaps other have more success, but I stopped it.
Now I try to integrate the two amplifiers in the scope:
mausi_mick
Post by mausi_mick » Thu Mar 30, 2017 5:42 pm
ThunderOwl,
I had problems with SPI for ADS9851, but now I need only three Pins , I put Pin AD_RST to ground.
Now I have installed the two preamps:
The switches with red plastic is for AC/DC, among them the switches for the reducer ( similar DSO150 input-stage).
The sockets left under the display is output from ADS9851.
mausi_mick
Post by mausi_mick » Sun Apr 02, 2017 3:20 pm
I have now built in a sinus to squarewave-former with 50% duty cycle.
The former is realized with a smitt-trigger and a divider trough two ( HC7474). Therefore the input-frequency is multiplied by two to
eliminate the divider.
to save on a new touch-input area on edge I have integrate the select function between SINUS / SQUARE(wave) in the Frequency-menu
(see Video).
https://youtu.be/z_VZjN_pj-o
