DLO-138 OScope
What are you developing?
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Thu Nov 02, 2017 3:14 am
Hi rexnanet,
I have modified the program, now the offset by changing gain is ok. The noise - I think - is from the preamp without compensation. I need some picoFarad ...
[url]https://youtu.be/vbiXGKW42pU/url]
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Sat Nov 04, 2017 5:13 pm
I have the preamps modified, here a picture:
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Tue Nov 07, 2017 7:02 pm
now the second preamp is nearly ready, I changed the TL072 in the first stage with the MCP6022 (R.R) because supply-voltage is only 5V.
The noise is from not perfect shielding . ?
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Sat Nov 11, 2017 2:16 am
Now I have made a new pcb for the maple-mini in the same size with the 2.8" display includes 5V supply and the MCP4822 DAC.
It is nearly ok, butI have eliminate the DAC beacause I have to change it from 3.3V to 5V like the other devices (PGA's) on SPI-2.
And I have to make something with the trigger ...
A new video: https://youtu.be/3KJTmGfGuTA
rexnanet
Re: DLO-138 OScope
Post by rexnanet » Sat Nov 11, 2017 8:35 am
Nice work!
3.3V to 5V: why are you mentioning SPI? 3.3V SPI should work with 5V slave if you ignore MISO line.
MCP6022 doesn't have a great BW but should be enough.
Is your trigger done in SW? If so it should be easy.
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Sat Nov 11, 2017 11:08 am
hi rexnanet,
the problem is solved,
It was a "design" error on the pcb-layout, I connected CS to CLK, MOSI to CS and CLK to MOSI of the MCP4822.
Now all is ok and the offset for both channels works. And the encoders work smooth and soft.
Thanks !
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Wed Nov 15, 2017 2:50 pm
Now I have finished the most of the HW and fixed it on the front-panel.
The supply m( USB or 7,5V-12V DC) is on the left side. BTN4 and Reset-Button are on the right above the two encoders.
DLO138_ILI9341_SPI_front_panel_With encoders.JPG (52.58 KiB) Viewed 374 times
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Mon Nov 20, 2017 4:17 pm
Now I have tested an quadencoder on an Namiki motor, the phase difference is 90° :lol:
https://www.youtube.com/watch?v=GXj4ve7 ... e=youtu.be
rexnanet
Re: DLO-138 OScope
Post by rexnanet » Wed Dec 13, 2017 3:21 pm
Nive work :)
I've got some DSO150 to try them out. It works great but only one channel is not very nice :)
I'm thinking about making a similar approach but using the F303 and getting to 10MSPS/channel.
I'm going to try changing the F103 for the F303 on a bluepill to test it (like ThunderOwl did :) ).
Maybe it could be possible to use this code with that chip...
dev
Re: DLO-138 OScope
Post by dev » Thu Feb 08, 2018 3:05 pm
Hi mausi_mick,
Could you please share the updated schematic for dso?
I want to give a try on this.
