DLO-138 OScope
What are you developing?
rexnanet
Re: DLO-138 OScope
Post by rexnanet » Mon Mar 06, 2017 5:52 pm
Ok.
How many pins do you have free? MCP6S only needs CLK,MOSI,CS(1 for each MCP...) 4 total for 2 MCP's.
But you can use "shiftOut" and save SPI troubles :)
Otherwise, I think you can do this:
_SPI->beginTransaction(SPISettings(9000000, MSBFIRST, SPI_MODE0)); //before MCP access 9Mhz to be safe
_SPI->beginTransaction(SPISettings(36000000, MSBFIRST, SPI_MODE0)); //after MCP access 36Mhz for the display. (if _SPI = SPI1)
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Mon Mar 06, 2017 6:04 pm
a new video at Youtube:
https://youtu.be/VkH50oe3FvA
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Tue Mar 07, 2017 2:36 am
rexnanet,
thanks for your example for changing frequency.
I hope that I need only one pin for each MCP, only for CS(n),
I take the same SCK (PA5), MOSI(PA7) Pins like the SPI-TFT (spi1).
There is a nice project:
http://www.rotwang.co.uk/projects/energy_monitor.html
with two spi-devices (ADC-MCP3002 and PGA MCP6S91) with Arduino-Code.
But I think at first I try this:
https://jasmedia2011.wordpress.com/2011 ... illoscope/
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Tue Mar 07, 2017 8:11 am
test of the PGA MCP6S91 on SPI-TFT successful , although the Input( ADC)-Voltage is not exactly multiplied.
Perhaps was the voltage-divider on the input (51k / 1k) not low resistance enough or the Voltage Vcc not stable or ...?
But with Vin (of the Maple Mini on USB) its nearly exact.
https://youtu.be/ttBVXR3ykcE
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Wed Mar 08, 2017 3:35 am
I had problems with the MCP6S91 lib, because it was not really HW-SPI.
Therefore I modified it to MCP6S92.h / cpp
I made on the left corner of the display for testing a small touch-area for activating the PGA MCP6S91.
A video from the first test is here ( only for switching between 16 and 32, because I have problems with the offset):
https://youtu.be/fHq3KtxJ0Yk
the modified lib is here:
MCP6S92.h
(608 Bytes) Downloaded 28 times
MCP6S92.cpp
(1.52 KiB) Downloaded 28 times
rexnanet
Re: DLO-138 OScope
Post by rexnanet » Thu Mar 09, 2017 9:37 am
mausi_mick wrote:I had problems with the MCP6S91 lib, because it was not really HW-SPI.
MCP6S92.h
MCP6S92.cpp
Have you look at the code I shared?
I had it modified to support HW-SPI :) all you needed to do is #define MPC_USE_HW_SPI (or something similar :) )
I've also added the support to change the channel (on X2 series)...
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Fri Mar 10, 2017 5:41 am
Hi rexnanet,
I have now no problems with the MCP6S91, the gain switching with SPI is ok. I have only to make something with the trigger and offset (like DSO138).
But I said in the Blog touch is more intuitive for changing labels, but to activate TOUCH with a real button is a little bit antique.
Therefore I tried it with SPI , but no success.
Back to URTOUCH I activated the touch with an ISR on TOUCH_IRQ-Pin and don't need the loop:
while (touch.available() ...
Now I can use the touch-function without pressing the button (the button on the encoder is now free ) :lol: :D
That's quick and real intuitive ! :D
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Fri Mar 10, 2017 6:08 am
ThunderOwl,
I think with the DSO150 you can make only a 1 channel o-scope, because you need 4 pins for gain selection.
I think it's better with the MCP6S91/92 (1 Pin) or a combination from DSO150 ( only inputstage with HC4053 (1Pin))
and MCP6S91/92.
The input of the DSO150 is a little bit better and easier to realize as the of the DSO138 and you can build in an overvoltage-protection with 2 diodes or two antiparallel white/blue leds (not tested, but very small leakage currents, but perhaps problems with capacity).
mausi_mick
Re: DLO-138 OScope
Post by mausi_mick » Fri Mar 10, 2017 9:03 am
the video with isr activated touch on Youtube:
https://youtu.be/Kkf7qgRC96E
it's not ever easy to hit the small touch-fields with thick finger's ! :lol:
rexnanet
Re: DLO-138 OScope
Post by rexnanet » Fri Mar 10, 2017 10:05 am
Good work mausi_mick!!!
Yep, the small areas are a bit difficult do get using fingers...that is why I started to use the encoder. But it's not perfect too...
Maybe a 15" touchscreen could help us :lol:
Touch IRQ is a great feature as it doesn't affect the refresh rate :)
The HC input stage approach can lead to a better bandwidth by using better op-amps. But that could be used for the F303 option :)
