Porting Marlin to STM32.
What are you developing?
Re: Porting Marlin to STM32.
Post by victor_pv » Fri Jul 07, 2017 11:29 pm
I just uploaded my libmaple port to github, and linked it in the first post.
danieleff
Post by danieleff » Sat Jul 08, 2017 4:38 am
Why is it not a fork, but a new repo?
Post by victor_pv » Sat Jul 08, 2017 1:43 pm
Hmmm, there isn't any specific reason. Once the Marlin main devs merge their HAL layer to the Main, this will be submitted as just a new folder in their HAL subfolder. At that point it will not exist as either branch of fork, just part of the master Marlin.
In the meanwhile I just uploaded it in case any wants to check it out, so not much planning on which way I was uploading it.
Post by victor_pv » Fri Oct 27, 2017 4:37 am
Today I successfully printed a couple of test cubes, and then a Yoda-Bhuda with Marlin and the STM32F1 HAL I started writting. xC0000005 has joined development and rewrote the ADC part to work with DMA.
He printed successfully a couple of days ago with a Malyan M200 board, and I printed with custom board I made for these test.
I updated the first post to reflect the progress.
It's now in the official Marlin 2.0 bugfix branch, but I have to upload and submit the very latest changes I have been doing in my local copy, and xC0000005 may have submit some too, but now Marlin is functional in STM32F1 :D
I used an stm32f103vet. I forgot whats in the M200 board, but whatever MCU verson it has, it can fit Marlin too.
Post by ag123 » Fri Oct 27, 2017 3:03 pm
+10 :)
mj666
Post by mj666 » Thu Nov 02, 2017 6:16 pm
Hello, I own an Fabrikator Mini V2. This contains a very similar board like the Malyan M200. Here is the link:
https://hobbyking.com/de_de/main-board- ... -m100.html
I see the printer could get some firmware improvements and the Marlin firmware could be a good fit. During my investigations I found this thread and that someone is already working on this port. My plan was to order a spare board and start experimenting with this. I may be able to help on this project.
I'm working with an global team to develop STM32 based flight controllers since quite a while and have been deeply involved in the firmware development for this flight controllers:
https://www.alienflightng.com/
I'm actively developing for BetaFlight and iNav, but was also was working on Harakiri, BaseFlight and CleanFlight in the past. I'm using Eclipse with the GNU ARM tool chain for this development. I used Arduino in the 8bit version in the past for the MultiWii with ATMega chips where I also did some work years ago.
Post by victor_pv » Thu Nov 02, 2017 10:36 pm
Any help is welcome.
I haven't done much in the code size because I was testing with another closed source board, a Chitu3d, and just finished with that a few days ago, and was able to print with Marlin.
xC00005 has been working on the Malyan, and he has successfully printed too. If that board is similar to the Malyan, all you need to do at the current time is map what pins are used for each function (step, dir and enable, for each stepper, thermistor inputs etc) and you should be able to print with it.
I believe xC00005 has last been working on the sanity check code, that checks your configuration in marlin (like 2 functions don't use the same pin, etc).
We still need to work on the LCD part.
Currently we are working off my branch of the code, that's almost up to the official 2.0 branch.
There is a lot of changes going on in the official branch for the LPC, and may take a while to get a PR merged, so I thought it would be easier to work on the STM32 in my HAL as I can merge more often, and then send PR to the official every once in a while.
also the official seems to break a bit more often due to so many changes going on, while the one in my fork is stable working now for us.
It's here:
https://github.com/victorpv/Marlin/tree/bugfix-2.0.x
mj666
Post by mj666 » Fri Nov 03, 2017 5:35 pm
I have ordered the spare board. Looks to be its using an STM32F103C8T6. The basic design looks to be very similar to the Malyan200 board. It likely comes from the same source. Actually trying to get the Arduino build environment up and running to be able to build the code.
parasole
Post by parasole » Fri Dec 15, 2017 3:22 am
I posted this in another tread, sorry if to much duplication...
Nice open sourse "duino" compatible projects are available which enable closed loop control so many motion problems would be fixed. Then one idea is to have control part for 3-4 steppers in one bluepill which would communicate with another one running Marlin, while on stepper side having motor driver and position sensor in case closed loop is used...
mechaduino:
http://tropical-labs.com/index.php/mechaduino
https://github.com/jcchurch13/Mechaduino-Hardware
https://github.com/jcchurch13/Mechaduino-Firmware
Similar to above nano_stepper:
http://misfittech.net
https://github.com/Misfittech/nano_stepper
simpler and cheaper ustepperr, interesting side of this project that you may use cheap Polulu A4988 driver as is:
http://www.ustepper.com/index/what-is-ustepper/
https://github.com/uStepper/uStepper
