Sine wave generator
What are you developing?
ted
Re: Sine wave generator
Post by ted » Tue Jan 30, 2018 5:03 pm
here is it
#define F_TIMER   72000000
#define FREQ    10000  //in Hz
#define SAMPLES ((int)sqrt(F_TIMER / FREQ))
#define T_CNT   ((F_TIMER/FREQ)/SAMPLES)
#define sin_zero     (T_CNT/2)
#define amp0         (sin_zero/2)
#define max_amp      (sin_zero-1)
#define DEBOUNCE_DELAY 100
#define DEBOUNCE_IDLE 0
#define DEBOUNCE_ACTIVE 1
#include <libmaple/dma.h>
dma_tube_config dma_cfg, dma_cfg2;
int flag1 = 0;
int flag2 = 0;
int out1 = PB7;
int out2 = PA8;
int out3 = PA9;
int * val1 = new int[SAMPLES];
int * val2 = new int[SAMPLES];
int phasep = PB6;
int phasen = PB5;
int ampp = PB8;
int ampn = PB9;
int16 shift = 0;
int amp = amp0;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
int ret = 17;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
timer_dev *dev2 = PIN_MAP[out2].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
uint8 cc_channel2 = PIN_MAP[out2].timer_channel;
void fun()
  static uint8_t ff = 0;
  flag1++;
void fun2()
  flag2++;
  digitalWrite(out3, ff = (1 - ff));
void timer_conf()
  timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
  timer_dma_set_burst_len(dev1, 1);
  timer_dma_enable_req(dev1, cc_channel1);
  timer_set_reload(dev1, T_CNT);
  timer_set_prescaler(dev1, 0);
  timer_dma_set_base_addr(dev2, TIMER_DMA_BASE_CCR1);
  timer_dma_set_burst_len(dev2, 1);
  timer_dma_enable_req(dev2, cc_channel2);
  timer_set_reload(dev2, T_CNT);
  timer_set_prescaler(dev2, 0);
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
  dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
  dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
  dma_cfg.tube_src = val1;
  dma_cfg.tube_src_size = DMA_SIZE_32BITS;
  dma_cfg.tube_nr_xfers = SAMPLES;
  dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
  dma_cfg.target_data = 0;
  ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
  /* T1C1 DMA C2 */
  dma_cfg.tube_dst = &(dev2->regs.gen->DMAR);
  dma_cfg.tube_src = val2;
  dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_HALF_CMPLT_IE | DMA_CFG_CMPLT_IE;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM1_CH1;
  ret = dma_tube_cfg(DMA1, DMA_CH2, &dma_cfg);
void dma_start()
//  dma_attach_interrupt(DMA1, DMA_CH4, fun);
  dma_enable(DMA1, DMA_CH4);
  timer_resume(dev1);
  dma_attach_interrupt(DMA1, DMA_CH2, fun2);
  dma_enable(DMA1, DMA_CH2);
  timer_resume(dev2);
void init_wave()
  int i;
  for (i = 0; i < SAMPLES; i++)
    val1[i] = sin_zero + amp * sin(stp * i);
    val2[i] = val1[i];
  int i;
  pinMode(out1, PWM);
  pinMode(out2, PWM);
  pinMode(out3, OUTPUT);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
Post by ahull » Tue Jan 30, 2018 8:37 pm
That looks pretty useful, what are the limitations (max frequency, sample size, etc.) and how does it work?
ted
Post by ted » Tue Jan 30, 2018 8:54 pm
I was using it for 15 kHz, you change the frequency very easy - line # 2, for frequency above 2 or 3 kHz single LC filter works excellent
