What are you developing?
Squonk42
Post by Squonk42 » Tue Dec 05, 2017 9:34 pm
It looks like the MOSFET is the wrong way around since the beginning:
From the datasheet, the DMP2160UW pinout is:
Look at the Due schematic:
https://www.arduino.cc/en/uploads/Main/ ... ematic.pdf
Due Ideal Diode.png (33.31 KiB) Viewed 262 times
And this TI AN:
http://www.ti.com/lit/an/slva139/slva139.pdf
TI Ideal Diode.png (20.25 KiB) Viewed 262 times
racemaniac
Post by racemaniac » Wed Dec 06, 2017 6:27 am
oops XD
well, then now is the right time to turn it around XD
Squonk42
Post by Squonk42 » Wed Dec 06, 2017 7:07 am
No problem ;)
Here is a short TODO list:
  • Add teardrops => Check https://github.com/svofski/kicad-teardrops
  • Panelization => Check pcb-panelizer ( http://blog.thisisnotrocketscience.nl/p ... panelizer/)
  • Fix fill area minimum width => Fixed Top & Bottom GND zones minimum width to 6 mils
  • Added some missing GND tracks between thermal pads due to previous change
  • Problem with PCB edges in 3D view => Fixed by @racemaniac
  • USB connector holes are too small => Fixed pads for J5 (micro USB) to be oval instead of round
  • Remove Ref/Value for U3 (STM32) on PCB top => OK
  • Option: Add an IMU somewhere on the bottom PCB size on an SPI or I2C bus to get a fully working flight controller board! i am thinking of an Invensense MPU6000 hooked to an SPI bus in order to get 8ksps performance
  • Option: Add an RGB LED => 0603?
  • Power AP2112 from +5V, not from +3.3V
  • Add ferrite bead between GND and AGND
  • Replace 32kHz crystal by smaller FC-12M, may be required for previous item
  • Option: Add MCP73831 LiPo battery charger (would require an ideal diode like D3/FET2/R6 in the Olimexino ATMega32U4 schematics)
  • Add pad/pin for VBUS for external PA9 VBUS_SENSE feature (USB Host) => Added a series resistor between VBUS and PA9 to avoid short-circuits
  • Adjust solder mask clearance to 0
  • Make VBAT trace thinner
  • Provide footprint for parallel capacitor near SDCard and voltage regulators
  • Fix MOSFET direction => replace by an SS12 Schottky diode
  • Added PWR_FLAG to schematic to remove ERC warnings
  • Replaced NC by real Kicad ones to remove ERC warnings
  • Cleaned up Expansion connector labels in schematic
  • Cleaned up traces for PA13-14 and PC13-15
  • Changed micro USB connector to BSC-Elec U02-BFD3111B0-009
  • Option: add an SPI Flash chip as an alternative to SDCard connector (overlapping footprints)
  • Add optional shunt resistors to route a single bit SPI bus to the SDCard connector for devices without SDIO interface => NOT POSSIBLE, too tight!
All volunteers welcome!
racemaniac
Post by racemaniac » Wed Dec 06, 2017 7:46 am
ugh, can someone explain to me why the mosfet is the wrong way around? XD
i thought of it as a high side switch that is always on, and from what i can see the load (+5V in our case) would then be on its drain, as we originally drew. but that is not correct?
it drives me crazy when googling i can't find clear answers for something as basic as this XD
Squonk42
Post by Squonk42 » Wed Dec 06, 2017 7:58 am
Please look at the Arduino Due schematic and TI AN above.
racemaniac
Post by racemaniac » Wed Dec 06, 2017 8:22 am
I can see the schematic, but i want to understand why it is so XD
Otherwise i'll keep making the same mistake >_<
Post by RogerClark » Wed Dec 06, 2017 8:38 am
Sorry guys.
What is the purpose of the FET Q1
Which direction is it supposed to prevent. e.g. USB -> 5V pin , or 5V pin to USB
It definitely won't stop 5V pin -> USB because of the internal diode as show in the symbol.
Squonk42
Post by Squonk42 » Wed Dec 06, 2017 9:02 am
Exactly, the idea is to allow USB to power the +5V, but not the opposite direction (we want to control VUSB using the SY6280 USB load switch), so the MOSFET body diode should be USB => +5V, like in the Arduino Due schematic and TI's AN.
racemaniac
Post by racemaniac » Wed Dec 06, 2017 9:07 am
but since we're also pulling the gate low, won't it also conduct the other way around anyway?
Is it then maybe this that we want to create:
https://electronics.stackexchange.com/q ... ransistors
but that's then with 3 transistors >_<
Post by RogerClark » Wed Dec 06, 2017 10:25 am
Guys,
I presume we are not simply using a diode on the 5V input, because you don't want the 0.5V drop across the diode ?
AFIK the Maple mini just uses a diode for this.
What else uses the 5V input ? that really requires 5V, and not 3.3V from the regulator.
Even if the diode dropped 0.5V that would still be 4.5V on the input to the regulator, and I thought that would be enough voltage for some regulators to output 3.3V ??
