Gamecube controller to USB adapter
What are you developing?
arpruss
Post by arpruss » Sat Sep 30, 2017 4:00 am
I made a Gamecube controller to USB adapter using a black pill. It has a lot of operation modes, so it can produce keystrokes, or joystick movements, or even (for Minecraft) keystrokes+mouse movements. I ended up using modified version of the outdated addMidiHID branch of the stm32 core.
Build instructions are here:
https://www.instructables.com/id/Gamecu ... ng-Starte/
This also includes getting-started instructions on how to get started with making USB HID devices with stm32f1, in case any other newbie needs them.
Code is here:
https://github.com/arpruss/gamecube-usb-adapter
Modified version of addMidiHID branch:
https://github.com/arpruss/Arduino_STM3 ... addMidiHID
3D-printable case (may be useful for other black pill projects):
https://www.thingiverse.com/thing:2558264
Re: Gamecube controller to USB adapter
Post by stevestrong » Sat Sep 30, 2017 8:32 am
Coool!
RogerClark
Post by RogerClark » Sat Sep 30, 2017 9:06 pm
Interesting..
One thing I noticed is that the instructable says use the wrong bootloader.
it says use the pb12 version for the blue pill, but its supposed to be then pc13 versions...
The only difference is of course which pin it toggles e.g. flashes, but if you had pb12 connected to some hardware it could be a problem
arpruss
Post by arpruss » Sun Oct 01, 2017 5:23 am
The Instructable is for the black pill. At least mine uses PB12 as the LED.
RogerClark
Post by RogerClark » Sun Oct 01, 2017 11:02 am
OK.
My bad.... ;-)
Just quickly looking at the photo it initially looked like a Blue Pill
