Metal detector dc42 improvment
What are you developing?
ted
Re: Metal detector dc42 improvment
Post by ted » Thu Feb 01, 2018 2:09 am
I used last link, I have " HOBBY COMPONENTS " in frames. How to implement it to this DC42 program ?
#define TIMER1_TOP  (249)        // can adjust this to fine-tune the frequency to get the coil tuned (see above)
#define USE_3V3_AREF  (1)        // set to 1 of running on an Arduino with USB power, 0 for an embedded atmega28p with no 3.3V supply available
// Digital pin definitions
// Digital pin 0 not used, however if we are using the serial port for debugging then it's serial input
const int debugTxPin = 1;        // transmit pin reserved for debugging
const int encoderButtonPin = 2;  // encoder button, also IN0 for waking up from sleep mode
const int earpiecePin = 3;       // earpiece, aka OCR2B for tone generation
const int T0InputPin = 4;
const int coilDrivePin = 5;
const int LcdRsPin = 6;
const int LcdEnPin = 7;
const int LcdPowerPin = 8;       // LCD power and backlight enable
const int T0OutputPin = 9;
const int lcdD0Pin = 10;
const int lcdD1Pin = 11;         // pins 11-13 also used for ICSP
const int LcdD2Pin = 12;
const int LcdD3Pin = 13;
// Analog pin definitions
const int receiverInputPin = 0;
const int encoderAPin = A1;
const int encoderBpin = A2;
// Analog pins 3-5 not used
// Variables used only by the ISR
int16_t bins[4];                 // bins used to accumulate ADC readings, one for each of the 4 phases
uint16_t numSamples = 0;
const uint16_t numSamplesToAverage = 1024;
// Variables used by the ISR and outside it
volatile int16_t averages[4];    // when we've accumulated enough readings in the bins, the ISR copies them to here and starts again
volatile uint32_t ticks = 0;     // system tick counter for timekeeping
volatile bool sampleReady = false;  // indicates that the averages array has been updated
// Variables used only outside the ISR
int16_t calib[4];                // values (set during calibration) that we subtract from the averages
volatile uint8_t lastctr;
volatile uint16_t misses = 0;    // this counts how many times the ISR has been executed too late. Should remain at zero if everything is working properly.
const double halfRoot2 = sqrt(0.5);
const double quarterPi = 3.1415927/4.0;
const double radiansToDegrees = 180.0/3.1415927;
// The ADC sample and hold occurs 2 ADC clocks (= 32 system clocks) after the timer 1 overflow flag is set.
// This introduces a slight phase error, which we adjust for in the calculations.
const float phaseAdjust = (45.0 * 32.0)/(float)(TIMER1_TOP + 1);
float threshold = 10.0;          // lower = greater sensitivity. 10 is just about usable with a well-balanced coil.
                                 // The user will be able to adjust this via a pot or rotary encoder.
  pinMode(encoderButtonPin, INPUT_PULLUP);
  digitalWrite(T0OutputPin, LOW);
  pinMode(T0OutputPin, OUTPUT);       // pulse pin from timer 1 used to feed timer 0
  digitalWrite(coilDrivePin, LOW);
  pinMode(coilDrivePin, OUTPUT);      // timer 0 output, square wave to drive transmit coil
  cli();
  // Stop timer 0 which was set up by the Arduino core
  TCCR0B = 0;        // stop the timer
  TIMSK0 = 0;        // disable interrupt
  TIFR0 = 0x07;      // clear any pending interrupt
  // Set up ADC to trigger and read channel 0 on timer 1 overflow
#if USE_3V3_AREF
  ADMUX = (1 << ADLAR);                   // use AREF pin (connected to 3.3V) as voltage reference, read pin A0, left-adjust result
#else
  ADMUX = (1 << REFS0) | (1 << ADLAR);    // use Avcc as voltage reference, read pin A0, left-adjust result
  ADCSRB = (1 << ADTS2) | (1 << ADTS1);   // auto-trigger ADC on timer/counter 1 overflow
  ADCSRA = (1 << ADEN) | (1 << ADSC) | (1 << ADATE) | (1 << ADPS2);  // enable adc, enable auto-trigger, prescaler = 16 (1MHz ADC clock)
  DIDR0 = 1;
  // Set up timer 1.
  // Prescaler = 1, phase correct PWM mode, TOP = ICR1A
  TCCR1A = (1 << COM1A1) | (1 << WGM11);
  TCCR1B = (1 << WGM12) | (1 << WGM13) | (1 << CS10);    // CTC mode, prescaler = 1
  TCCR1C = 0;
  OCR1AH = (TIMER1_TOP/2 >> 8);
  OCR1AL = (TIMER1_TOP/2 & 0xFF);
  ICR1H = (TIMER1_TOP >> 8);
  ICR1L = (TIMER1_TOP & 0xFF);
  TCNT1H = 0;
  TCNT1L = 0;
  TIFR1 = 0x07;      // clear any pending interrupt
  TIMSK1 = (1 << TOIE1);
  // Set up timer 0
  // Clock source = T0, fast PWM mode, TOP (OCR0A) = 7, PWM output on OC0B
  TCCR0A = (1 << COM0B1) | (1 << WGM01) | (1 << WGM00);
  TCCR0B = (1 << CS00) | (1 << CS01) | (1 << CS02) | (1 << WGM02);
  OCR0A = 7;
  OCR0B = 3;
  TCNT0 = 0;
  sei();
  while (!sampleReady) {}    // discard the first sample
  misses = 0;
  Serial.begin(19200);
// Timer 0 overflow interrupt. This serves 2 purposes:
// 1. It clears the timer 0 overflow flag. If we don't do this, the ADC will not see any more Timer 0 overflows and we will not get any more conversions.
// 2. It increments the tick counter, allowing is to do timekeeping. We get 62500 ticks/second.
// We now read the ADC in the timer interrupt routine instead of having a separate comversion complete interrupt.
ISR(TIMER1_OVF_vect)
  ++ticks;
  uint8_t ctr = TCNT0;
  int16_t val = (int16_t)(uint16_t)ADCH;    // only need to read most significant 8 bits
  if (ctr != ((lastctr + 1) & 7))
    ++misses;
  lastctr = ctr;
  int16_t *p = &bins[ctr & 3];
  if (ctr < 4)
    *p += (val);
    if (*p > 15000) *p = 15000;
  else
    *p -= val;
    if (*p < -15000) *p = -15000;
  if (ctr == 7)
    ++numSamples;
    if (numSamples == numSamplesToAverage)
      numSamples = 0;
      if (!sampleReady)      // if previous sample has been consumed
        memcpy((void*)averages, bins, sizeof(averages));
        sampleReady = true;
      memset(bins, 0, sizeof(bins));
  uint32_t oldTicks = ticks;
  if (digitalRead(encoderButtonPin) == LOW)
    // Calibrate button pressed. We save the current phase detector outputs and subtract them from future results.
    // This lets us use the detector if the coil is slightly off-balance.
    // It would be better to everage several samples instead of taking just one.
    for (int i = 0; i < 4; ++i)
      calib[i] = averages[i];
    Serial.print("Calibrated: ");
      Serial.write(' ');
      Serial.print(calib[i]);
    Serial.println();
  else
      averages[i] -= calib[i];
    const double f = 200.0;
    // Massage the results to eliminate sensitivity to the 3rd harmonic, and divide by 200
    double bin0 = (averages[0] + halfRoot2 * (averages[1] - averages[3]))/f;
    double bin1 = (averages[1] + halfRoot2 * (averages[0] + averages[2]))/f;
    double bin2 = (averages[2] + halfRoot2 * (averages[1] + averages[3]))/f;
    double bin3 = (averages[3] + halfRoot2 * (averages[2] - averages[0]))/f;
    sampleReady = false;          // we've finished reading the averages, so the ISR is free to overwrite them again
    double amp1 = sqrt((bin0 * bin0) + (bin2 * bin2));
    double amp2 = sqrt((bin1 * bin1) + (bin3 * bin3));
    double ampAverage = (amp1 + amp2)/2.0;
    // The ADC sample/hold takes place 2 clocks after the timer overflow
    double phase1 = atan2(bin0, bin2) * radiansToDegrees + 45.0;
    double phase2 = atan2(bin1, bin3) * radiansToDegrees;
    if (phase1 > phase2)
      double temp = phase1;
      phase1 = phase2;
      phase2 = temp;
    double phaseAverage = ((phase1 + phase2)/2.0) - phaseAdjust;
    if (phase2 - phase1 > 180.0)
      if (phaseAverage < 0.0)
        phaseAverage += 180.0;
      else
        phaseAverage -= 180.0;
    // For diagnostic purposes, print the individual bin counts and the 2 indepedently-calculated gains and phases
    Serial.print(misses);
    Serial.write(' ');
    if (bin0 >= 0.0) Serial.write(' ');
    Serial.print(bin0, 2);
    Serial.write(' ');
    if (bin1 >= 0.0) Serial.write(' ');
    Serial.print(bin1, 2);
    Serial.write(' ');
    if (bin2 >= 0.0) Serial.write(' ');
    Serial.print(bin2, 2);
    Serial.write(' ');
    if (bin3 >= 0.0) Serial.write(' ');
    Serial.print(bin3, 2);
    Serial.print("    ");
    Serial.print(amp1, 2);
    Serial.write(' ');
    Serial.print(amp2, 2);
    Serial.write(' ');
    if (phase1 >= 0.0) Serial.write(' ');
    Serial.print(phase1, 2);
    Serial.write(' ');
    if (phase2 >= 0.0) Serial.write(' ');
    Serial.print(phase2, 2);
    Serial.print("    ");
    // Print the final amplitude and phase, which we use to decide what (if anything) we have found)
    if (ampAverage >= 0.0) Serial.write(' ');
    Serial.print(ampAverage, 1);
    Serial.write(' ');
    if (phaseAverage >= 0.0) Serial.write(' ');
    Serial.print((int)phaseAverage);
    // Decide what we have found and tell the user
    if (ampAverage >= threshold)
      // When held in line with the centre of the coil:
      // - non-ferrous metals give a negative phase shift, e.g. -90deg for thick copper or aluminium, a copper olive, -30deg for thin alumimium.
      // Ferrous metals give zero phase shift or a small positive phase shift.
      // So we'll say that anything with a phase shift below -20deg is non-ferrous.
      if (phaseAverage < -20.0)
        Serial.print(" Non-ferrous");
      else
        Serial.print(" Ferrous");
      float temp = ampAverage;
      while (temp > threshold)
        Serial.write('!');
        temp -= (threshold/2);
    Serial.println();
  while (ticks - oldTicks < 16000)
ted
Post by ted » Thu Feb 01, 2018 3:27 am
I made two implementations, the screen is black for DC42 program, and for "Hello World" program is working to.
So I need to change black screen to display message of DC42 program which are on the end of it = activate Serial.print
#1
// include the library code:
//#include <LiquidCrystal.h>
/* Include the U8glib library */
#include "U8glib.h"
/* Define the SPI Chip Select pin */
#define CS_PIN 10
/* Create an instance of the library for the 12864 LCD in SPI mode */
U8GLIB_ST7920_128X64_1X u8g(CS_PIN);
#2
const int LcdEPin = 13;
const int LcdRWPin = 11;
const int LcdRsPin = 10;
BennehBoy
Post by BennehBoy » Thu Feb 01, 2018 8:09 am
I suspect you may be better served by asking your questions on the Arduino.cc forum which has far more active usres with time to help beginners to AVR/MCU coding - as it stands the questions you are asking are all really unrelated to STM32 whilst you work out how to get the fundamentals of your project working on Uno.
https://github.com/BennehBoy
ted
Post by ted » Thu Feb 01, 2018 8:47 pm
The LCD is displaying what is under forward slash line#1, I need to change that to info below forward slash line #2 on the end of the program.
// Induction balance metal detector
// We run the CPU at 16MHz and the ADC clock at 1MHz. ADC resolution is reduced to 8 bits at this speed.
// Timer 1 is used to divide the system clock by about 256 to produce a 62.5kHz square wave.
// This is used to drive timer 0 and also to trigger ADC conversions.
// Timer 0 is used to divide the output of timer 1 by 8, giving a 7.8125kHz signal for driving the transmit coil.
// This gives us 16 ADC clock cycles for each ADC conversion (it actually takes 13.5 cycles), and we take 8 samples per cycle of the coil drive voltage.
// The ADC implements four phase-sensitive detectors at 45 degree intervals. Using 4 instead of just 2 allows us to cancel the third harmonic of the
// coil frequency.
// Timer 2 will be used to generate a tone for the earpiece or headset.
// Other division ratios for timer 1 are possible, from about 235 upwards.
// Wiring:
// Connect digital pin 4 (alias T0) to digital pin 9
// Connect digital pin 5 through resistor to primary coil and tuning capacitor
// Connect output from receive amplifier to analog pin 0. Output of receive amplifier should be biased to about half of the analog reference.
// When using USB power, change analog reference to the 3.3V pin, because there is too much noise on the +5V rail to get good sensitivity.
#include "U8glib.h"
#define CS_PIN 10
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
//const int rs = 6, en = 7, d4 = 10, d5 = 11, d6 = 12, d7 = 13;
//LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//const int LcdRsPin = 6;
//const int LcdEnPin = 7;
 // set up the LCD's number of columns and rows:
//  lcd.begin(16, 2);
  // Print a message to the LCD.
  //lcd.print("hello, world!");
  /* Start of a picture loop */
  u8g.firstPage();
  /* Keep looping until finished drawing screen */
  do
    /* Set the font */
    u8g.setFont(u8g_font_courB14);
// #1
    /* Display some text */
    u8g.drawStr( 35, 26, "HOBBY");
    u8g.drawStr( 8, 46, "COMPONENTS");
    /* Draw a simple border */
    u8g.drawFrame(5,5,117,54);
    u8g.drawFrame(3,3,121,58);
  }while(u8g.nextPage());
  cli();
#if USE_3V3_AREF
#else
  DIDR0 = 1;
  // Set up timer 1.
  TCCR1C = 0;
  TCNT1H = 0;
  TCNT1L = 0;
  // Set up timer 0
  OCR0A = 7;
  OCR0B = 3;
  TCNT0 = 0;
  sei();
  misses = 0;
  ++ticks;
    ++misses;
  lastctr = ctr;
  if (ctr < 4)
    *p += (val);
  else
    *p -= val;
  if (ctr == 7)
    ++numSamples;
      numSamples = 0;
        sampleReady = true;
      Serial.write(' ');
    Serial.println();
  else
      phase1 = phase2;
      phase2 = temp;
      else
    //#2
    Serial.write(' ');
    Serial.write(' ');
    Serial.write(' ');
    Serial.write(' ');
    Serial.print("    ");
    Serial.write(' ');
    Serial.write(' ');
    Serial.write(' ');
    Serial.print("    ");
    Serial.write(' ');
      else
        Serial.write('!');
    Serial.println();
Post by mrburnette » Thu Feb 01, 2018 10:41 pm
I suspect you may be better served ...
I think ted is just keeping us updated on his progress .. like a project log.
ted
Post by ted » Fri Feb 02, 2018 3:44 pm
ted is learning programing.
He is showing what kind of problems he is facing and is looking for answers to them.
tfried
Post by tfried » Sat Feb 03, 2018 8:06 pm
No problem ted. We've all been there, C++ isn't anybody's native tongue, after all.
But when looking for answers, do accept when the answer is "you need to take a step back, and start basic". Really, you're trying to solve specific problems, and of course, finding a solution to those problems is exactly why you're looking at programming in the first place. But even though you may feel real close to solving those problems with your current method of copy-and-paste, what you seem to totally underestimate is your lack of understanding of just how any of what your copying actually works (on the level of programming). Sorry to say, but that lack is fundamental and you will get nowhere trying to ignore it. Better understanding will not come to, automatically, just by spending more time on your approach. Instead, what you need to do is to go back and work through some basic tutorials. Focusing on "Hello world!" may look like a huge step backwards, but you are not ever going to get to your real goals, if you don't take the time to understand every single line of such basic examples. Yes, a whole lot of that will already be familiar to you. Don't let that fool you. You still need to understand the basics, completely.
Since you say you have a firm grip on the electronics side, and you don't need help with basic tasks such as installing or uploading, try these tutorials, focussed on programming basics: https://startingelectronics.org/softwar ... am-course/. All of them, please. And again, you need to understand every single line of code in these tutorials. That is going to take some time (not forever, though) and effort (not a superhero effort, though), but there is not shortcut to learning the basics.
Cheers!
ted
Post by ted » Sat Feb 03, 2018 8:29 pm
It is my dream to understand every line, THANKS for great link, I thing I am close to solve the problem, just replace serial by lcd and more digging.
ted
Post by ted » Thu Feb 08, 2018 2:43 pm
I followed tfried suggestion and coca cola can range is 95 cm. Naw I need 60 Hz notch filter
program any info is appreciated.
Post by ahull » Sat Feb 10, 2018 12:29 am
How good is your trigonometry foo?
https://www.researchgate.net/post/How_t ... tch_filter
I presume you are trying to remove mains hum, but you haven't fully described your problem. You might find it easier to do your filtering with one or more R/C or L/C electronic filters. This would take some of the load off your processor. Sometimes it is simpler to throw a few op-amps and some passives at a problem than to try to compute the solution in real time. Especially since "mains hum" can have lots of lovely harmonics that trip you up too.
https://en.wikipedia.org/wiki/Band-stop_filter
