72 MHz dividing by 100 code
What are you developing?
ted
Post by ted » Mon Jan 01, 2018 1:59 am
STM32F103 is running at 72 MHz I believe the simple code can divide it by 100 which will give 0.72 MHz PWM output on pin, for example PA6. Maybe someone know how to write such code ?
int outputPin = PA6; //output pin
  pinMode(outputPin, OUTPUT);
  //or ?  pinMode(out1, PWM);
 // 72 MHz dividing by 100 code ???
//  Serial.println(   ???);
//  Serial.print (???);   //  print result of dividing, PWM on pin PA6
Re: 72 MHz dividing by 100 code
Post by dannyf » Mon Jan 01, 2018 5:15 pm
the simple code
which simple code?
one typical process would be to look up the datasheet and figure out how the clock division works.
another typical process would be to beg someone else to write it for you.
Post by Pito » Tue Jan 02, 2018 8:38 am
For example (I doubt this will work at exactly 720kHz, however), tested:
HardwareTimer pwmtimer(3);
uint16_t maxduty, duty;
uint32_t myperiod, mypulse;
  pwmtimer.pause();
  myperiod = 20; // PWM period in useconds, 20 -> freq = 50KHz
  maxduty = pwmtimer.setPeriod(myperiod);
  pwmtimer.refresh();
  pwmtimer.resume();
  pinMode(PA7, PWM);
mypulse =  5; // 0<=mypulse<=period, this is my High pulse length in useconds
duty = map((int32_t)mypulse, 0, (int32_t)myperiod, 0, (int32_t)maxduty);
pwmWrite(PA7, duty); // 0<=duty<=maxduty
while(1){};
You may try to access the timer registers directly to achieve faster results.
With a 72MHz input the timer resolution could be 13.88ns, thus you need 100 to load in (or something like that) to get 720kHz out.
Tested:
  pinMode(PA7, PWM);
  pwmtimer.pause();
  pwmtimer.setPrescaleFactor(1);       // Timer input clock Prescaler = 1 (= 72MHz input ?)
  pwmtimer.setOverflow(100-1);         // PWM Period width for 720.000kHz ?
  pwmtimer.setCompare(TIMER_CH2, 50);  // PWM High Pulse width is 50% duty (1:1)
  pwmtimer.refresh();
  pwmtimer.resume();
ted
Post by ted » Tue Jan 02, 2018 4:26 pm
What I should put in brackets serial ?
#include <SPI.h>
  SPI.setClockDivider(SPI_CLOCK_DIV128);
 SPI.setClockDivider(SPI_CLOCK_DIV16); // (72 MHz / 16 = 4.5MHz)
 The SPI1 works on APB2 (72 MHz). The maximum frequency that works the SPI1 is 72/2 =36 MHZ.
The SPI2 works on APB1 (36 MHz). The maximum frequency that works the SPI2 is 36/2 =18 MHZ.
The available dividers are:
CODE: SELECT ALL
SPI_CLOCK_DIV2
SPI_CLOCK_DIV4
SPI_CLOCK_DIV8
SPI_CLOCK_DIV16
SPI_CLOCK_DIV32
SPI_CLOCK_DIV64
SPI_CLOCK_DIV128
SPI_CLOCK_DIV256
ted
Post by ted » Tue Jan 02, 2018 4:35 pm
no tested - error
div_100_a:17: error: 'period' was not declared in this scope
duty = map((int32_t)mypulse, 0, (int32_t)period, 0, (int32_t)maxduty);
exit status 1
ted
Post by ted » Tue Jan 02, 2018 4:42 pm
output on PA7 = 550 Hz
Post by Pito » Tue Jan 02, 2018 4:54 pm
Updated the source - see above.
Also I've tested the first source and it works here on BluePill.
The second source under investigation.
ted
Post by ted » Tue Jan 02, 2018 5:05 pm
There is no reaction when I am changing the numbers in bracket
pwmtimer.setPrescaleFactor(4);       // Timer input clock Prescaler = 1 (= 36MHz input ?)
  pwmtimer.setOverflow(0.5);            // PWM Period width for 720kHz ?
ted
Post by ted » Tue Jan 02, 2018 5:11 pm
When I am compiling first version I have mentioned error
