PWM basic
What are you developing?
ted
PWM basic
Post by ted » Fri Jan 05, 2018 9:34 pm
There must be a simple code for this circuit - sine in sine out. Any solution welcome.
Re: PWM basic
Post by dannyf » Fri Jan 05, 2018 11:27 pm
yes:
1) connect the input to output;
2) run the following code in the mcu:
  while (1) {
ted
Re: PWM basic
Post by ted » Sat Jan 06, 2018 1:54 am
This is what I did, the code and error. I know what error is saying, don't know how to fix it.
input_output:17: error: 'Serial' does not name a type
 Serial.print(outputPin, value);
input_output:18: error: expected constructor, destructor, or type conversion before '(' token
 analogWrite(outputPin);
exit status 1
//analogWrite(outputpin);   analogRead(inputpin));
int inputPin  = PA6;  // analog input pin, inputPin = PB0;
int outputPin = PA7; //output pin
int analogOut;
  pinMode(inputPin, INPUT_ANALOG);
  pinMode(outputPin, OUTPUT);
  int8_t value = analogRead(inputPin);
  while (1) {
Re: PWM basic
Post by stevestrong » Sat Jan 06, 2018 8:26 am
Try this:
pinMode(outputPin, PWM); // instead of OUTPUT
Serial.print(value);
analogWrite(outputPin, value);
ted
Re: PWM basic
Post by ted » Sat Jan 06, 2018 5:41 pm
This is a new code and a new error.
input_output:26: error: expected constructor, destructor, or type conversion before '(' token
exit status 1
/*pinMode(outputPin, PWM); // instead of OUTPUT
analogWrite(outputPin, value);*/
int analogOut;
 // pinMode(outputPin, OUTPUT);
  while (1) {
//Serial.print(outputPin, value);
martinayotte
Re: PWM basic
Post by martinayotte » Sat Jan 06, 2018 5:47 pm
Why the analogWrite() is placed outside any scope ? ... :ugeek:
ted
Re: PWM basic
Post by ted » Sat Jan 06, 2018 6:20 pm
this is a draft, I am using those lines to make code work, thanks for pointing that.
New code and new error.
input_output:3: error: 'Serial' does not name a type
input_output:4: error: expected constructor, destructor, or type conversion before '(' token
exit status 1
int analogOut;
  while (1) {
//analogWrite(outputPin);
martinayotte
Re: PWM basic
Post by martinayotte » Sat Jan 06, 2018 6:34 pm
Again, you still have analogWrite() at line 4 outside any scope !
It must be inside either setup() or loop() ...
ted
Re: PWM basic
Post by ted » Sat Jan 06, 2018 7:09 pm
The error comes from this line - Serial' does not name a type , mentioned line is disabled by //'
ted
Re: PWM basic
Post by ted » Sat Jan 06, 2018 7:16 pm
new correction and error.
C:\Users\OWNER\Documents\Arduino\input_output\input_output.ino: In function 'void setup()':
input_output:14: error: 'outputpin' was not declared in this scope
exit status 1
int analogOut;
  while (1) {
Locked
