Time interval counter (13ns resolution)
What are you developing?
ddrown
Post by ddrown » Wed Jan 17, 2018 12:32 am
I wanted to compare two GPS modules, specifically the amount of time between the pulse per second of each of them. I used a STM32F103 as my hardware, and setup two channels on TIM3 as input capture. The timer is running at 72MHz so it has a 13ns resolution. I also setup TIM2 as a slave to count TIM3's overflow events, so I could use both 16 bit timers together as a pseudo 32 bit timer. The timestamps were sent via USB serial to a PC to log and graph.
The two GPS modules should be within +/-20 nanoseconds of each other, if everything went right.
From this graph, you can see they were not. I believe this was a configuration issue on one of my GPS modules as well as signal issue. I've ordered some more parts and will have to re-run this part of the test again.
An interesting part of the data shows the STM32F103's clock has a sawtooth pattern to it:
I think this sawtooth pattern is a combination of the HSE circuitry and the PLL. Has anyone seen this before?
Code: https://github.com/ddrown/stm32-cdc-pps/tree/tim3
Additional information: https://blog.dan.drown.org/gps-module-measurements/
Re: Time interval counter (13ns resolution)
Post by dannyf » Wed Jan 17, 2018 12:55 am
if there is something else going on on your chip - like another ISR on UART or ADC, a composite timer may show jitter consistent with the pattern shown in your measurement. Those chips allow chaining / master + slave pair of two timers, if input capture is used.
alternatively (not as good), you can use DWT - it is 32-bit.
plausible. two ways to test:
1) the same pattern would show up on HSIPLL vs. HSEPLL, and disappear on HSI vs. HSE.
2) a more affirmative approach is to use a non-PLL external oscillator and MCO on the STM32 and run the output via an XOR gate + R/C network. you should observe slow moving voltage on the capacitor, when PLL is used on the chip, and a steady voltage when HSE / HSI is used.
ddrown
Post by ddrown » Wed Jan 17, 2018 1:26 am
Since I'm using input capture, I'm not affected by interrupt latency. I actually measure interrupt latency/jitter from this data.
HSI is way worse than HSE
That tiny purple line is the full frequency difference of the HSE. The green dots at the bottom represent all the HSI frequency values.
By comparison, this is a STM32F031 with a TCXO (using bypass instead of the HSE oscillator circuitry)
Post by Pito » Wed Jan 17, 2018 7:56 am
The GPSes 1Hz tick is not precise short term, but long term. Based on module and conditions short term jitter could be XXns- Xuseconds. Thus the tick itself cannot be used as the base for a counter for example. You have to discipline a quality OCXO with the 1Hz tick to get precise output.
The sawtooth frequency stability of the 72MHz PLL - yes, I measured the same (72MHz BPill against OCXO base). Here the spread is 30Hz (72Mhz/2, last three digits shown):
BluePill 72MHz_half against OCXO.JPG (52.39 KiB) Viewed 309 times
It is most probably caused by the design of the phase comparator inside the PLL.
ddrown
Post by ddrown » Wed Jan 17, 2018 7:22 pm
Yup, the spec for these GPS modules is 20ns RMS jitter. That is roughly 0.020ppm uncertainty on each sample. That is a source of error, but it is tiny compared to the PLL or HSE.
Thank you for this data, that's in the same ballpark (60Hz vs 30Hz) as what I'm seeing with just the GPS. I wonder how much variation there is per chip/board design.
When you say 72MHz/2, were you measuring a 36MHz PWM?
ddrown
Post by ddrown » Fri Jan 19, 2018 11:59 pm
The GPS antenna arrived in the mail and I reran my tests, this time it (the offset between the two GPS modules) was much better:
I'll have to experiment with various changes (antenna swap, channel swap, etc) to see the impact to the offsets.
Post by mrburnette » Sat Jan 20, 2018 2:28 am
Short PDF doc on "jitter" that may be of interest to readers unfamiliar with the subject...
https://www.google.com/url?sa=t&source= ... MjCRhLRPIn
ddrown
Post by ddrown » Sat Jan 20, 2018 3:31 am
Thank you, I didn't properly define all my terms. I've probably confused a bunch of people with this post.
Post by Pito » Sat Jan 20, 2018 9:21 am
Those 30Hz were measured at 36MHz output. Thus with 72MHz it will be 60Hz. The OCXO was free running, none disciplining.
