OV7670, Generic STM32F103RC and ILI9341 display
What are you developing?
Re: OV7670, Generic STM32F103RC and ILI9341 display
Post by RogerClark » Wed Sep 27, 2017 6:44 am
I wrote some python code to read the image via serial
Its still very messy code at the moment, so I can't post it, but at least it works.....
Post by RogerClark » Sun Oct 08, 2017 3:40 am
Guys
I've committed the changes I had locally which allow readback of the LCD using Steve's code plus another function to read RGB24 bit (based on Steve's code)
I think perhaps I should add Steve's OV7670 lib that works for me, to the F1 libraries ??
konczakp
Post by konczakp » Wed Oct 11, 2017 9:59 am
Yes please do that .... I'm still waiting for my hardware but I cannot wait to test it too ....
Post by RogerClark » Wed Oct 11, 2017 10:33 am
OK
I will tidy up the code and post it at the weekend
PS also making a PCB for Blue Pill + OV767 + LCD
But I keep changing my mind about whether it also needs to connect to the SD pins or the touch screen pins on the LCD board
I think I will have to remove the part of the board that connects to the SD pins because it makes the board too large and costly.
So I will need to do a bit of redesign.
konczakp
Post by konczakp » Wed Nov 01, 2017 3:58 pm
I finally received all the hardware. Roger, did You post all changes with the ov7670 lib on the github? I wanted to start from the beginning.
Post by RogerClark » Wed Nov 01, 2017 8:00 pm
I will double check my code and what is on github
konczakp
Post by konczakp » Sat Nov 04, 2017 3:52 pm
please also add OV7670 lib to STM32F1 libraries to get full bundle
konczakp
Post by konczakp » Mon Nov 13, 2017 9:24 am
i bet that You forgot about me? Or maybe You posted it somewhere else then here https://github.com/rogerclarkmelbourne/ ... /libraries ?
zoomx
Post by zoomx » Mon Nov 13, 2017 10:34 am
Meanwhile you can test this binary
http://stm32duino.com/viewtopic.php?f=1 ... 260#p33895
using the connections described in the successive post if you have the same display.
Post by RogerClark » Thu Nov 16, 2017 10:29 pm
Can't you just add Steve's library to your Arduino Library folder ?
