Hi
I recently bought a "new" black pill board from Aliexpress. I see that is new because the pinout is slightly different from other boards.
https://es.aliexpress.com/item/4001157813131.html
Doc is in Chinese. Hope someone has more information.
That is my first STM32 board. I can use with arduino and download with DFU mode via USB (well it has a hard time getting into that mode sometimes), now I am researching to download with a bootloader. Any help would be appreciated.
New STM32F401CCU6 Black Pill
- STM32F401CCU6 Black-pill
- IMG_193018_1.jpg (58.45 KiB) Viewed 9543 times
- IMG_192956.jpg (33.47 KiB) Viewed 9543 times
- IMG_193948.jpg (64.3 KiB) Viewed 9543 times
Re: New STM32F401CCU6 Black Pill
No need for additional bootloaders.
Press both buttons, release reset, release boot 0. That should put you in dfu mode.
Yes I do!. My problem was that if usb serial is opened, they can't enter in DFU. So first close serial.
I hope with some downlader I can simplify process.
try using a st-link v2
https://octopart.com/st-link%2Fv2-stmic ... s-20057793
https://octopart.com/2548-adafruit+indu ... 88022?r=sp
it saves you the trouble of pressing the buttons.
but otherwise i'm simply using the button presses it is adequate for downloads.
the finger dance is
- press both reset and boot0
- release reset
- release boot0 1 sec later
and st-linkv2 is a SWD debugger - it is more useful than just downloading firmware
alternatively you can search for 'hid bootloader' using the search box on top of this web.
i've not used it. i'm happy with just st-link and the built-in usb dfu bootloader
the finger dance is
- release reset
I also have a couple of these unbranded Blackpills. (Black PCB, LED on PC13, 3 oval buttons on top and no logo on the botom side just a white box.)
I can program it using an ST-Link V2 in SWD ok. However, it is not detected as a DFU device neither by DFUSE-Demo v3.06 nor STM32CuBEProg. I do not see it as a USB device in 64 bit Windows 7 pro nor does USB-View appear to detect it.
DFuse-demo claims that there are no DFU device attached.
Similar for STM32CubeProg.
I have tried:
a) powerup / NRST - starts the fade program on LED PC13
b) press & hold boot0 + NRST - release NRST (Blue LED stops flashing, only RED pwr LED on) - still n -> similar resultot recognised as DFU device.
c) press & hold KEY + NRST ~ goes into key toggle of LED PC13. Hold for 1/2 S -> flashes then Blue LED extinguishes - still not detected as DFU.
Does the DFU bootloader exist in firmware in all STM32F401CC s or only in Flash / some variants?
Any ideas?
Peter
I have tried:
Any ideas?
Peter
step (b) is correct, that is the DFU mode
I have sorted the 'dfu' problem. - I had 2 x USB A - C cables that look the same. However, one has only 2 pins wired through and is a charge cable, the other has all the pins wired through and is a charge and data cable!
I now have a second issue.
Whereas the PC detects the 'dfu' as 'STM32 Bootloader' and STM32CUBEProg (V2.90) is happy to use it in DFU mode as USB1, DFuseDemo (v3.0.6) does not detect any 'dfu' devices present.
The PC sometimes reports the BlackPill as 'Unknown device' changing to a different USB port seems to solve the Windows detection issue and it again picks up the device as 'STM32 Bootloader'
Peter
Peter
