Hi from Melbourne, Australia
Please read this if you are new to the STM32
Message to all users
I've upgraded the forum (PHPBB) to version 3.1.10 which is the last stable release in the 3.1 tree.
As far as I can tell everything is still working OK, e.g. all posts look like they are there and the attachments are OK
If anyone has any problems please PM me.
PS. Don't PM the admin account as for some reason I still don't get email notifications of these PM's (but I never have ;-)
Re: Hi from Melbourne, Australia
Postby RogerClark » Tue Nov 01, 2016 5:31 am
is no problem with a maple mini
i.e Maple mini
(but this won't have enough GPIO for what you need as its a STM32F103CB)
Postby stevestrong » Wed Nov 02, 2016 8:25 am
Maple Mini clone and/or blue pill (generic C8T8).
BTW, you could use another blue pill over SPI to get the ADC values. In this case the pill that does the acquisition is SPI master, and the other is slave on SPI. The PA pins of the master would be then free to use for other purposes.
X71
Postby X71 » Sat Nov 12, 2016 1:16 am
Ok, so I ordered 2 x STM32F103Vet6 boards and they arrived yesterday. The blue light is blinking at 1Hz so I'm assuming it has the default blinking light "sketch" running.
It's not recognized as a USB device so I'm assuming it needs drivers or do I need create a USB profile for it?
I'm a little lost here at the moment.
Edit: I've installed Keil v5 as well but there were no drivers installed.
Postby RogerClark » Sat Nov 12, 2016 2:46 am
None of the generic boards come with a bootloader installed, so they won't appear as a valid USB device
You need to install the bootlader using a USB to serial adaptor
See the FAQ's Q's and A's
viewtopic.php?f=2&t=873
X71
Postby X71 » Sat Nov 12, 2016 5:55 am
Thanks Roger. Appreciate all the help :)
X71
Postby X71 » Sat Nov 12, 2016 11:23 am
Ok so looking at your video Roger, and looking over the schematics of my board, I've noted that my board has a J-Link header (GND, SWCLK, SWDIO, 3.3V), as well as TX / RX on pins A9 and A10.
So which adaptor should I use?
J-Link
http://www.ebay.com.au/itm/J-Link-OB-AR ... 1736125080
FT232
http://www.ebay.com.au/itm/5V-3-3V-FT23 ... 1970872590
I can also see that the MCU has SCK, MISO and MOSI pins (A5, A6, A7), so does that mean I could load a bootloader via an Arduino Mega or UNO which I already have?
danieleff
Postby danieleff » Sat Nov 12, 2016 12:09 pm
If you have an UNO where you can remove the atmega chip, you can use the USB-serial part of the board standalone way. I think.
Postby ahull » Sat Nov 12, 2016 1:05 pm
X71 wrote:Ok so looking at your video Roger, and looking over the schematics of my board, I've noted that my board has a J-Link header (GND, SWCLK, SWDIO, 3.3V), as well as TX / RX on pins A9 and A10.
J-Link
FT232
Given how little these adapters cost, I think an ST-Link V2 clone and any USB serial adapter would be all you need.
Postby RogerClark » Sat Nov 12, 2016 7:25 pm
Most people just flash the bootloader using USB to Serial.
Like Danieleff says, you can do this by taking the Atmega chip out.
You may be able to do the same by holding the uno in reset.
Any usb to serial converter should be fine.
We only have limited JLink support. I only added it a few weeks ago, and only 1 person uses it.
If you want to upload via swd, STLink is STM's official upload tool and you can by clones of Stlink for a few dollars from china.
Official JLink programmers cost $$$$. Jlink clones are not super cheap e.g. $20 and they dont all work, as Segger has been clamping down on them by modifying their software.
I recently had to help someone fix their Jlink clone which would not work with the latest Segger software and there are reports on the web of the clones getting bricked.
X71
Postby X71 » Sat Nov 12, 2016 9:51 pm
Thanks all.
So the FT232 adaptor I linked is all I would need then?
Return to “Welcome & FAQs”
Who is online
