Hi from Melbourne, Australia
Re: Hi from Melbourne, Australia
Post by RogerClark » Sat Nov 12, 2016 9:55 pm
If you install the bootloader with a FT232 or equivalent, then after that you can just plug the board straight into the PC and it will initially show up as a WinUSB DFU device, untill there is a valid sketch.
Then after you have uploaded a sketch, the sketch has the Serial USB in it
Ideally, you need to use a bootloader binary with the LED pin the same as on your board.
Do you know which pin the LED is on?
X71
Post by X71 » Sat Nov 12, 2016 10:48 pm
LED has PC13 printed underneath on the board, so I'm assuming it's pin C13 on the board.
STM32F103VET6-A.PDF
(163.68 KiB) Downloaded 38 times
STM32F103VET6-B.PDF
(164.31 KiB) Downloaded 28 times
Post by RogerClark » Sun Nov 13, 2016 12:17 am
If its on PC13 you need the PC13 bootloader
https://raw.githubusercontent.com/roger ... 0_pc13.bin
